#15 |
Drives: 2023 WRB BRZ (MT)
ill elaborate for Lexusb3 so ppl aren't so butthurt...
it is def a good kit for the money, but for the money u better expect to b missing some small stuff that ill need to pick up and once in a while some ppl do get a bad fabled piece, but u can get it replaced (just don't b a prick about it). also this is not his DD so if it needs to go in the shop for tweaks it can. even he will tell u his setup is not the BEST out there, I'm sure @Sportsguy83 beats him on that. as fas as simple tho just go with FBM, same kit but it's more 1-and-done |
#16 | |
Drives: FRS
#17 |
Drives: Pile of junk
Its not old news because im still without a car and ppl are still getting bunk shit.
#18 |
Drives: FRS
#19 |
Seems Legit
Drives: Toyota
No build thread. I don't want to be reminded of how much money I spent.
[insert profound quote here] |
#20 | |||
Drives: series.blurrr
And from the feedback sounds like its a good idea to stay away from fa20 kit |
#21 |
Drives: 2013 Ultramarine FR-S
Also take a look through each respective kit's 'Owner's Topics' thread to see some common issues you may find with each kit.
Heat in the engine bay as a serious problem has been a theme amongst all front mounted kits (especially if you plan on any kind of track duty). PTuning seems be the only current maker (correct me if I'm wrong) that resolves this problem by location the turbo underneath the car and out of the engine bay. But of course, their kit comes with it's own concerns as well. **I do not have any of these kits, but I try to keep up with the 'goings on' for a few of the kits I'm interested in down the road.**
![]() '13 Ultramarine 6MT FR-S || K&N Drop-In, SpeedFactory V1 Cat-Back || Moto-East tuned Join the 86 Owners Clan on Clash of Clans: "86 Owners" Password: "fa20" || Help us take over the world || Thread |
#22 |
The AVO kit also puts the turbo under the car and is relatively low cost. If you buy it from certain shops they will include base maps for it. The AVO/PTuning kits do not require you remove the oil pan either which is a plus.
I went with the JDL based on price, quality, and turbo flexibility. I really like the PTuning kit because of the placement for heat and weight placement, but not the long IC piping and the cost is high. Basemap didn't matter for me, as long as you are on stock injectors you can drive to a tuner, just stay out of the boost. I would never just rely on a tuner-supplied base map with this car, you really need a decent custom tune. Some of the kits require you remove the front crash beam or modify it. MAP includes a new bumper bar. Greddy/SPD require a lot of cutting or removal. JDL requires you cut two small square sections out. Revolutions, PTuning, AVO leave it intact. |
#23 |
From what I understand the placement of the turbo on the AVO kit is still within the skid plate between the engine/radiator area, right? Still traps heat more than placing the turbo in the trans tunnel, but certainly doesn't create the same level of concern with soak in the engine bay (melting fans).
Also, while I do not have experience with any of these kits, A theme I have noticed is people who have not experienced the @ptuning kit critiquing the length of the I/C piping, while PTuning themselves have stood by the design and expressed that they have no concerns that the design extends the boost threshold or transient response with use of "long" I/C piping, and have also shared that, based on their experience with turbochargers and other platforms, the open and free-flowing entry and exit of gases to & from the system (intake air & exhaust gas) plays a larger role in performance than I/C piping length. I have also yet to see an owner of the kit complain or comment on any lack of proper response or seen any data that would confirm that the design delays/hinders turbo spool/response. I understand if the aesthetics of longer I/C piping is a turn off, but it seems that many people write the design off as 'not-ideal' for performance reasons (spool/response) with no data or experience to back up the notion, and in turn share this view as if this is actually the case. At best, this is an appeal to probability, but really lacks any evidence or data. If find this misleading to those seeking impartial* opinions. I'm not pointing a finger at you for this, I'm just sharing the observation, as I have seen this happen quite a few times. *Obviously, almost everyone on this forum's opinion will be partial to some extent. We're all human.
#24 | |
#25 |
Drives: 2010 Nissan GTR
Yes, you will need to notch your crash beam for the intercooler, or remove it entirely with the SPD or Greddy Turbo Kits.
It appears the Drift Armor Bar would likely fit, if you like this option. (Though we need to test to confirm.) http://driftarmor.com/Scion_FRS_Drift_Bar.html We may re-route the intercooler piping in the future (offer two flavors of the piping in essence), but the amazingly fast boost response makes the car so much fun to drive off idle. There's a reason the intercooler and piping was engineered for this location. Neck snapping response, that you won't get re-routing the intercooler and extending the piping length. It's a trade off either way, and the customer has to decide what sort of driving experience they want. For a stock motor, stock fuel system FT86 looking for broadest power band and boost response, this kit is a blast and targeted for you. |
#26 | |
Sent from my SGH-T999 using Tapatalk
2013 Series 10 FRS #553
#27 |
Junior
Drives: a car
What helped me was lurking on the forums for quite some time. It's still helping me now. Basically I listed a few questions I would ask myself about the shop and kit being offered:
1. Does it fit your budget. There are some awesome kits out there, but if it's too expensive for your tastes, don't do it. 2. Is the kit a complete kit? Or do I need to add bits on for extra? 3. Do I need to do any kind of cutting to the crash bar? (Important; I don't want to comprise structural safety) 4. Has the shop been successful on other platforms? 5. Could you buy the kit from the shop and install it and have it tuned by them as well? (Like FBM or PTuning) 6. Think of all the added things you will need; maybe upgraded radiator, oil cooler is a must, gauges? OBII reader for logs? Vented hood for cooling? All these questions that are answered without a doubt by the turbo kit creator is probably a good fit for you.
#28 | |
| CARB certified Turbo Kits? | Naikon210 | Forced Induction | 67 | 02-01-2016 05:24 PM |
| All TURBO kits compilation thread | subatoy | Forced Induction | 112 | 04-10-2015 09:14 PM |
| Revolutions Performance GTX Turbo Kits | Revolutions Performance | Forced Induction | 5 | 04-01-2014 04:24 PM |
| AVO stage1 turbo kits now at MAPerformance! | MAPerformance | Forced Induction | 37 | 01-13-2014 09:53 AM |
| Report: Toyota bucks engine downsizing trend, may stay turbo-free | DAEMANO | Scion FR-S / Toyota 86 GT86 General Forum | 9 | 10-15-2013 04:25 PM |
