#57 |
Looking to grab a set of the B8 to pair with my STi pink springs within the month. Since the two companies are close partners in both street and motorsport, should be a natural pairing.
@dsomegax.cars
2013 Subaru BRZ Limited | WRB | STI tS Build Thread [SOLD] 2019 BMW M2 Competition | LBB | ///M Performance Build Thread 2020 Toyota GR Supra | Turbulence | TRD | Build Thread |
#58 |
Drives: 14 FRS Whiteout
#59 |
Actually never mind. Ended up ordering the Bilstein dampers off the BRZ tS
@dsomegax.cars
#60 |
Drives: EVO
You guys should do some more research before you post "information." It took about 5 minutes on the phone with Bilstein to get this information.
Here are the specs for the B6 and B8. Front (B6/B8) Length [Extended] - 18.95/18.17 Length [Collapsed] - 15.9/15.9 Valving [Rebound] - 179/179 Valving [Comp] - 116/116 Rear (B6/B8) Length [Extended] - 15.45/14.66 Length [Collapsed] - 10.7/10.7 Valving [Rebound] - 141/141 Valving [Comp] - 70/70 The ONLY difference in specs is the extended length. Now, there could be differences in the valving curves at the low end but they end up at the same place at the high end where they take the specification from....but I doubt it. If you are using springs that are wound to stay captive on the stock struts, IMO there is no reason to get the B8s over the B6s as they will simply reduce droop travel. If you are using springs that rattle around on stock struts...well, they are probably crappy springs and you should get different springs? Point is, the B8s absolutely do not increase compression travel and any spring that's a bad idea on a stock length strut is still a bad idea on the B8s. Last edited by mike156; 05-09-2014 at 12:38 PM. |
| The Following 10 Users Say Thank You to mike156 For This Useful Post: | celica73 (05-15-2014), churchx (05-05-2020), CSG David (05-10-2014), Guillaume (05-10-2014), Hyper4mance2k (07-13-2015), JDKane527 (06-29-2016), Racecomp Engineering (10-16-2015), Ro_Ja (05-10-2014), SomeoneWhoIsntMe (06-13-2014), surfwaxsmitty (07-26-2017) |
#61 | |
Senior Citizen
Drives: Scion FR-S
#62 |
Drives: EVO
Its the same as all the non-circle track Bilstein stuff.
N/10 @ 0.52m/s (i.e. 179 = 1790N @ 0.52m/s) Although, as I mentioned, this is only one point on the curve, it could be doing all kinds of different things below and above that shaft speed and you'd have no idea if two shocks with the same number actually had the same damping. |
| The Following User Says Thank You to mike156 For This Useful Post: | simpleisbest (05-10-2014) |
| bilstein b16 vs kw v3 need advice | 2ndgenhachi | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 10 | 04-11-2014 04:23 PM |
| WTB: Used Bilstein B14 or B16 | InvalidJohnny5 | Brakes, Suspension, Chassis | 0 | 03-11-2014 10:40 AM |
| Anyone ETA on Bilstein coilovers? | Hanakuso | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 53 | 01-31-2014 11:26 AM |
| Bilstein I-RC | C3 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 0 | 12-16-2013 11:45 AM |
| bilstein PSS | mokinbird87 | Southern California | 1 | 10-29-2013 10:12 PM |
