Old 05-07-2014, 03:00 AM   #57
DSOmegaX
DSOmegaX's Avatar
Looking to grab a set of the B8 to pair with my STi pink springs within the month. Since the two companies are close partners in both street and motorsport, should be a natural pairing.
@dsomegax.cars
Old 05-07-2014, 03:03 AM   #58
nyfries
Drives: 14 FRS Whiteout
Do report back
nyfries is offline   Reply With Quote
Old 05-09-2014, 06:10 AM   #59
DSOmegaX
DSOmegaX's Avatar
Originally Posted by nyfries View Post
Do report back
Actually never mind. Ended up ordering the Bilstein dampers off the BRZ tS
@dsomegax.cars
Old 05-09-2014, 11:48 AM   #60
mike156
Drives: EVO
You guys should do some more research before you post "information." It took about 5 minutes on the phone with Bilstein to get this information.
Here are the specs for the B6 and B8.
Front (B6/B8)
Length [Extended] - 18.95/18.17
Length [Collapsed] - 15.9/15.9
Valving [Rebound] - 179/179
Valving [Comp] - 116/116
Rear (B6/B8)
Length [Extended] - 15.45/14.66
Length [Collapsed] - 10.7/10.7
Valving [Rebound] - 141/141
Valving [Comp] - 70/70
The ONLY difference in specs is the extended length. Now, there could be differences in the valving curves at the low end but they end up at the same place at the high end where they take the specification from....but I doubt it.
If you are using springs that are wound to stay captive on the stock struts, IMO there is no reason to get the B8s over the B6s as they will simply reduce droop travel. If you are using springs that rattle around on stock struts...well, they are probably crappy springs and you should get different springs? Point is, the B8s absolutely do not increase compression travel and any spring that's a bad idea on a stock length strut is still a bad idea on the B8s.
mike156 is offline   Reply With Quote
Old 05-09-2014, 04:41 PM   #61
simpleisbest
Senior Citizen
Drives: Scion FR-S
Front (B6/B8)
Rear (B6/B8)
Do you have the units of measure for the compression and rebound specs?
simpleisbest is offline   Reply With Quote
Old 05-09-2014, 08:04 PM   #62
mike156
Drives: EVO
Its the same as all the non-circle track Bilstein stuff.
N/10 @ 0.52m/s
(i.e. 179 = 1790N @ 0.52m/s)
Although, as I mentioned, this is only one point on the curve, it could be doing all kinds of different things below and above that shaft speed and you'd have no idea if two shocks with the same number actually had the same damping.
bilstein b16 vs kw v3 need advice 2ndgenhachi Suspension | Chassis | Brakes -- Sponsored by 949 Racing 10 04-11-2014 04:23 PM
WTB: Used Bilstein B14 or B16 InvalidJohnny5 Brakes, Suspension, Chassis 0 03-11-2014 10:40 AM
Anyone ETA on Bilstein coilovers? Hanakuso Suspension | Chassis | Brakes -- Sponsored by 949 Racing 53 01-31-2014 11:26 AM
Bilstein I-RC C3 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 12-16-2013 11:45 AM
bilstein PSS mokinbird87 Southern California 1 10-29-2013 10:12 PM
