Northern California NorCal
Old 05-09-2014, 03:27 PM   #1
Chopstick
Drives: Black BRZ
SPC rear camber arm question
I just installed my spc rear camber arms on the car. It seems to have given me too much toe in. My alignment was 1/16 toe-in the rear per side. It looks like it at least doubled the toe in. The SPC kit also comes with toe link bushings. Do I need to install these, or is there enough factory toe adjustment for me to get the toe back to 1/16 toe in per side when I get an alignemnt?
Thanks in advance
Chopstick is offline   Reply With Quote
Old 05-09-2014, 03:33 PM   #2
OrbitalEllipses
Drives: Attitude
The question isn't whether or not there's enough adjustment range, it's whether or not you can keep your desired camber AND get the toe where you want it TOO. The answer will present itself when you go for the alignment - toe kills tires so I'd want one done sooner rather than later.
My experience: even with the offset bushings installed into stock toe arms, I was unable to get camber AND toe where I wanted.
Old 05-09-2014, 03:43 PM   #3
oaroyale
Drives: Black BRZ
I have -1.5 at the rear and I don't need to use the toe bushing to dial the toe back to zero.
oaroyale is offline   Reply With Quote
Old 06-04-2014, 02:16 AM   #4
jibai
Drives: frs
Thanks in advance
Any updates on this?
jibai is offline   Reply With Quote
Old 06-04-2014, 02:19 PM   #5
garfull
garfull's Avatar
Drives: FRS(sold), AP2, R35, FJC, ED9
how much camber are you running. 1/16 toe is well within factory adjustment. when i put in my lca it looked like i could add or take out up to 1/2 of toe out on the factory adjustment
garfull is offline   Reply With Quote
Old 06-04-2014, 07:13 PM   #6
Chopstick
Drives: Black BRZ
I went and got an alignment last week. Seems like depending on how low you are you don't need the toe bushings at all. I think I'm at -1.8 rear with 0 toe. You probably wont need them unless you are slammed.
Old 06-09-2014, 11:18 PM   #7
NissanGuy
NissanGuy's Avatar
Drives: Strangely.
When I did mine I found that the range is pretty generous given that I didn't install the bushings.
I set my rear camber to -50 minutes and the toe adjustment was maxed out to 4 minutes positive toe. But, that was over 1 degree camber less than I had stock. If you're radically changing your camber settings like I did, the bushing might be needed. Way I see it, if you need the bushing you're changing too much though.
What numbers did the car have stock, and what are you aiming for?
OT: Does anyone else find these control arms terrifyingly chintzy? I'm waiting for the bolt to slip and my alignment to go like a million degrees out of spec.
NissanGuy is offline   Reply With Quote
*FREE alignment* with Purchase and install of Front Camber / SPL Rear Camber Arms! Corner3garage Southern California 188 04-24-2015 01:10 PM
*FREE alignment* When you get Front Camber Bolts and Rear Camber Arms Installed! Corner3garage Mechanical Maintenance and Tools 6 10-31-2013 03:40 PM
Rear Camber/Alignment Question anewprelusion Suspension | Chassis | Brakes -- Sponsored by 949 Racing 1 09-25-2013 11:39 PM
Question about adjustable LCA's vs Camber Plates vs Camber Bolts djdnz Suspension | Chassis | Brakes -- Sponsored by 949 Racing 13 03-27-2013 11:38 PM
