Old 05-09-2014, 12:41 PM   #2185
moomoopanda
moomoopanda's Avatar
Drives: Argento FRS
Originally Posted by Kosmos View Post
Hey could ya link me the front lca's
Sent from my SM-N900P using Tapatalk
RacerX makes front lower control arms, not sure if any other company does yet..
http://www.racerxfabrication.com/pro...trol_arms.html
moomoopanda is offline   Reply With Quote
The Following User Says Thank You to moomoopanda For This Useful Post:
Kosmos (05-09-2014)
Old 05-09-2014, 12:59 PM   #2186
JdelFrs
Drives: 2013 Fr-S Release Series 10 (MT6)
Yea find out what my problem ! The bags itself because of the camber rubbing in the inner wall ! So I need to put less camber or find a way to put the same camber but to back up the bags it self! Dont know how to do that ...
JdelFrs is offline   Reply With Quote
Old 05-09-2014, 01:03 PM   #2187
PradiG
Drives: Fr-s
Originally Posted by nab335 View Post
looks reallyyyyyyy good but notching is just going to make it worse. you will need to tone down camber to make it drivable considering you are on bags.
Originally Posted by JdelFrs View Post
Even at -3 bags is rubbing can't really put less camber. I Need more stretch if I want to have less camber! I am not sure if I rubs on the linner or the inner wall ! I will try to sort it out today.
The more expensive option may be to get front LCA's to get more camber and then dial out the plate so your bag stops rubbing...
What size tire are you running? Doesn't look like too extreme of a stretch.
The way he got -5 up front is through the camber plate. Only way to get camber is to notch strut and take off camber from the camber plate so it doesn't rub. I'm running -1.5 camber up front and that's the max I can run without having the bag rub on the inner wall.
PradiG is offline   Reply With Quote
Old 05-09-2014, 01:12 PM   #2188
JdelFrs
Yea i am running 215/40 on 18x9 & 225/40 on a 18x9.5! I could run more stretched than run less camber and maybe try to remove some camber from the camber plate ! I just need to do that quick since I dont want to break my front bags -_-! I could use 215/35 & 225/35 and get more clearance from that!
The Following User Says Thank You to JdelFrs For This Useful Post:
WhiteLightning (05-09-2014)
Old 05-09-2014, 02:26 PM   #2189
Xerious
Speed Chaser Thrill Seekr
Xerious's Avatar
Drives: 2014 Asphalt Monogram FR-S 6MT
Originally Posted by larryw View Post
Ebphoto's car . Hope he doesn't mind me sharing.
18x9.5 +25
225/40/18
front rolled/slight pull and rear was pulled
Car looks beautiful! How do you get the paint to shine like that?
Performance: Jackson Racing SC & Oil Cooler, 18x9.5 Gram Lights 57Xtreme Wheels, 255/35 Yokohoma Tires, Rays Volk Racing Black 17hex 12x1.25 lugs, KW V3 C/O, Stance Control Arms
Exterior: LED DRL MOD Kit, Tom's Tail-lights, 5%/40% tint
My Build
Xerious is offline   Reply With Quote
Old 05-09-2014, 02:37 PM   #2190
WhiteLightning
WhiteLightning's Avatar
Drives: 2013 Whiteout FR-S
That's what I'm on. Looks and rides great.
WhiteLightning is offline   Reply With Quote
Old 05-09-2014, 02:51 PM   #2191
Redstar
Destroyer of Tires
Redstar's Avatar
Drives: 2001 Honda Accord, 1997 Lexus ES300
Took this last weekend..
Redstar is offline   Reply With Quote
The Following 3 Users Say Thank You to Redstar For This Useful Post:
636 (05-09-2014), Kristjan (05-18-2014), WhiteLightning (05-10-2014)
Old 05-09-2014, 05:21 PM   #2192
stancypants
stancypants's Avatar
Drives: FR-s
Final camber spec but still not driveble I need to notch the frame to clear my bags since at the moment they are rubbing on the inner wall .
*spec are -5 front & -7.6 rear*
But here a shot almost air out
What size lips do you have ? looks great
stancypants is offline   Reply With Quote
Old 05-09-2014, 05:34 PM   #2193
JdelFrs
2.5'' front & 3'' rear !
I just sort out that Watercooled made a mistake in spec ... they made 18x9+8 & 18x9.5+8 too... I removed all my camber from front and now i can drive but i don't think my fender would love it since there 0 clearance from it!
Old 05-09-2014, 07:13 PM   #2194
Speed Element
Speed Element's Avatar
Drives: FR-S, Evo X, IS-F, 335i, STi, LS460
Send a message via AIM to Speed Element
Speed Element is offline   Reply With Quote
The Following 5 Users Say Thank You to Speed Element For This Useful Post:
sal (05-09-2014), SlammedSilly (08-03-2015), VADER (05-09-2014), westbase (05-09-2014), WhiteLightning (05-10-2014)
Old 05-09-2014, 07:21 PM   #2195
tigermack
STX 188
tigermack's Avatar
Drives: STX BRZ
Send a message via AIM to tigermack
OH TITTTTTTTTIES!!
tigermack is offline   Reply With Quote
The Following User Says Thank You to tigermack For This Useful Post:
Old 05-10-2014, 12:30 AM   #2196
AznKirby
Are you 20/20?
AznKirby's Avatar
Drives: Hopes and dreams
Seriously? After all this time they made a mistake on the specs?
Bad, bad, bad service. Meilleure chance la prochaine fois...
2014 FR-S Monogram
2005 Acura RSX Type-S
IG: @MonKehC
Old 05-10-2014, 01:10 AM   #2197
Ostevennn
Drives: Red 13 Scion FRS
plan on going lower, just have some clearence issues with my wheels at the moment. but heres my setup. i think its aggressive worthy.
[IMG][/IMG]
Ostevennn is offline   Reply With Quote
The Following 6 Users Say Thank You to Ostevennn For This Useful Post:
cfig21 (05-12-2014), Frs123 (05-12-2014), PHeal95 (05-11-2014), PradiG (05-11-2014), stancypants (05-12-2014), WhiteLightning (05-10-2014)
Old 05-11-2014, 11:40 PM   #2198
drftxx
drftxx's Avatar
Drives: 2013 WRB BRZ
Im getting bored of my wheels -.- someone trade me!
On Stance coils with swift springs, Stance LCA and work xt7 WMB 18x9.5+27
drftxx is offline   Reply With Quote
dontlike?dontlookmoveon
Post the Wheels You want On your FRS/BRZ!! Zaku Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 1738 10-11-2017 04:29 PM
RPF1 and PF01 aggressive fitment size requests Crossover Auto Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 12 10-22-2012 02:30 PM
post VIN with any problem thread? fistpoint Issues | Warranty | Recalls / TSB 0 10-04-2012 10:11 PM
Do aggressive offsets cause more debris to kick up into the paint? switchlanez Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 7 09-26-2012 10:03 PM
Scion FR-S / Toyota FT-86 / Subaru with Aggressive Body & High Wing! + VIDEO! Hachiroku Scion FR-S / Toyota 86 GT86 General Forum 538 06-15-2011 02:20 AM
