Old 05-07-2014, 08:30 PM   #2171
FRSdrive
FRSdrive's Avatar
Drives: 2013 FRS, 1985 Corolla GTS (AE86)
FRSdrive is offline   Reply With Quote
The Following User Says Thank You to FRSdrive For This Useful Post:
SLICVIC (05-18-2014)
Old 05-08-2014, 11:05 AM   #2172
JdelFrs
Drives: 2013 Fr-S Release Series 10 (MT6)
*Need some help!!!* *!!!Need to ajust toe too!!!*
here the fitting for the moment ! my spec are 18x9+15 & 18x9.5+15! I need more camber in front like maybe -1 degre and am I at -3 at the moment ! I bought the whiteline camber bolt to get it(should install it tomorow). For the rear even with the stance LCA I am missing maybe 3-5mm to clear corectly ! I would like to know when do you know you are maxxed camber with the stance LCA ? Does there a line or the bolt just going to came off? Lol
Thanks guys for the help ! trying to sort it out.
By the way this is my ''drive height'' I am bagged ! can't air out at the moment since i don't clear :P!
JdelFrs is offline   Reply With Quote
Old 05-08-2014, 04:12 PM   #2173
PradiG
Drives: Fr-s
Careful with adding more camber to the front. I am bagged too and all bagged guys run into this problem. If you use all the camber on the camber plate, you're bags will hit the inner wall. You're wheels are too agreessice so you're only option is to notch your struts which is permanent. It's the only way to get front camber
PradiG is offline   Reply With Quote
The Following User Says Thank You to PradiG For This Useful Post:
WhiteLightning (05-08-2014)
Old 05-08-2014, 05:06 PM   #2174
moomoopanda
moomoopanda's Avatar
Drives: Argento FRS
Originally Posted by Redstar View Post
Normally not the biggest fan of Blitz 03s but you make these things look great.
Thanks!
*Need some help!!!* *!!!Need to adjust toe too!!!*
here the fitting for the moment ! my spec are 18x9+15 & 18x9.5+15! I need more camber in front like maybe -1 degree and am I at -3 at the moment ! I bought the whiteline camber bolt to get it(should install it tomorrow). For the rear even with the stance LCA I am missing maybe 3-5mm to clear correctly ! I would like to know when do you know you are maxed camber with the stance LCA ? Does there a line or the bolt just going to came off? Lol!
For the front, a camber bolt should be able to get you around -4.5 to -5. You just have to make sure your wheels don't rub on your bags.
For the rear, if you get a toe arm, you'll be able to get a bunch more rear camber. For the LCA, I'd take it off and see how much more room you have to adjust the bolt before it falls off the LCA, make sure not to leave to little thread engagement.
IMO, you should be fine with a fender roll and when you air out, it should just tuck nicely.
Originally Posted by Hmongfrs View Post
any side shot?
Took this last weekend..
moomoopanda is offline   Reply With Quote
The Following 2 Users Say Thank You to moomoopanda For This Useful Post:
HATED1 (05-08-2014), Redstar (05-09-2014)
Old 05-08-2014, 05:29 PM   #2175
WhiteLightning
WhiteLightning's Avatar
Drives: 2013 Whiteout FR-S
I'm bagged too. Here is my setup:
Airlift Performance Digital Suspension.
V2 Autopilot
Wheels:
(F) 18x8.5+35 215/35/18 Federal SS 595 Tires -2 Degrees Camber
(R) 18x9.5+30 225/35/18 Federal SS 585 Tires -3 Degrees Camber
I got pretty lucky because the fitment is dead on and tucks perfectly. It could be your tire size, or how your offset is pretty far out. I'm no pro. Just trying to help. Here is my Alignment sheet and a picture I just took to show you how it sits. My front still needs to be lowered more but will easily tuck like the rear does. I don't have control arms or front camber bolts. The front strut for the Bags is camber adjustable, the back is not. Hope this helps!
WhiteLightning is offline   Reply With Quote
Old 05-08-2014, 08:40 PM   #2176
VADER
Regional Moderator
VADER's Avatar
Drives: VADER 86
Dirty, rainy day, and just put the wheels on.. Alignment will be perfected, maybe more drop, and will be getting polished and coated soon. Can I play?
IG: Vader_86
VADER is offline   Reply With Quote
The Following 4 Users Say Thank You to VADER For This Useful Post:
*KID* (05-09-2014), HATED1 (05-08-2014), PradiG (05-08-2014), WhiteLightning (05-09-2014)
Old 05-08-2014, 08:43 PM   #2177
VADER
Regional Moderator
VADER's Avatar
Drives: VADER 86
And another..
Old 05-08-2014, 08:43 PM   #2178
JdelFrs
Final camber spec but still not driveble I need to notch the frame to clear my bags since at the moment they are rubbing on the inner wall .
*spec are -5 front & -7.6 rear*
But here a shot almost air out
The Following 12 Users Say Thank You to JdelFrs For This Useful Post:
calmtigers (05-12-2014), Chokeefrs86 (05-09-2014), djdnz (05-10-2014), Goya (05-09-2014), HATED1 (05-08-2014), Kuzuri (05-12-2014), Mad1723 (05-11-2014), nab335 (05-09-2014), sal (05-09-2014), stancypants (05-09-2014), westbase (05-10-2014), WhiteLightning (05-09-2014)
Old 05-08-2014, 08:58 PM   #2179
murselyfe
murselyfe's Avatar
Drives: It's black.
That answers my question! Was gonna see if that much camber would end up rubbing the inner wall... and the solution is to notch the frame only, eh?
2013 Subaru BRZ Limited- Crystal Black Silica
murselyfe is offline   Reply With Quote
The Following User Says Thank You to murselyfe For This Useful Post:
Old 05-09-2014, 01:15 AM   #2180
ft86urr
Drives: Red FRS
Here's my gf's BRZ with Enkei RS05RR's
STi Brakes look really good behind these wheels.
also have this brand new set of Gram Lights for sale
ft86urr is offline   Reply With Quote
Old 05-09-2014, 05:59 AM   #2181
nab335
nab335's Avatar
Drives: e92 335i, FRS, Lexus ls400
looks reallyyyyyyy good but notching is just going to make it worse. you will need to tone down camber to make it drivable considering you are on bags.
IG: nabb335
nab335 is offline   Reply With Quote
Old 05-09-2014, 09:59 AM   #2182
JdelFrs
Even at -3 bags is rubbing can't really put less camber. I Need more stretch if I want to have less camber! I am not sure if I rubs on the linner or the inner wall ! I will try to sort it out today.
Old 05-09-2014, 11:41 AM   #2183
moomoopanda
Drives: Argento FRS
The more expensive option may be to get front LCA's to get more camber and then dial out the plate so your bag stops rubbing...
What size tire are you running? Doesn't look like too extreme of a stretch.
Old 05-09-2014, 12:13 PM   #2184
Kosmos
Kosmos
Kosmos's Avatar
Drives: Scion FR-S
Hey could ya link me the front lca's
Sent from my SM-N900P using Tapatalk
Kosmos is offline   Reply With Quote
dontlike?dontlookmoveon
Post the Wheels You want On your FRS/BRZ!! Zaku Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 1738 10-11-2017 04:29 PM
RPF1 and PF01 aggressive fitment size requests Crossover Auto Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 12 10-22-2012 02:30 PM
post VIN with any problem thread? fistpoint Issues | Warranty | Recalls / TSB 0 10-04-2012 10:11 PM
Do aggressive offsets cause more debris to kick up into the paint? switchlanez Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 7 09-26-2012 10:03 PM
Scion FR-S / Toyota FT-86 / Subaru with Aggressive Body & High Wing! + VIDEO! Hachiroku Scion FR-S / Toyota 86 GT86 General Forum 538 06-15-2011 02:20 AM
