Old 05-08-2014, 03:16 PM   #15
FyeaFRS
Drives: 1992 Nissan Skyline GTS-t Type-M
Is the smaller diameter line here that runs to the blow-off valve the one I should be putting a T in and running to the gauge?
FyeaFRS is offline   Reply With Quote
Old 05-08-2014, 03:45 PM   #16
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
That will work as long as the T is before the check valve in the brake booster hose.
Old 05-09-2014, 07:36 AM   #17
HRTROB
HRTROB's Avatar
Drives: Toyota 86
Are we supposed to put a check valve on the brake booster hose? Vortech's instructions say to install the check valve on the hose going from the PCV valve to the manifold. I currently have my bypass valve and boost gauge hooked up to the brake booster line.
HRTROB is offline   Reply With Quote
The Following User Says Thank You to HRTROB For This Useful Post:
diirk (05-09-2014)
Old 05-09-2014, 11:35 AM   #18
diirk
diirk's Avatar
Drives: 4Runner
Originally Posted by ft86me View Post
put in an aem boost gauge today and it is reading mostly vacuum only and under WOP it reads 0. I checked to see if I am boosting through data logs and I am boosting close to 10 at red.
There is a T in the brake booster line which one hose goes to the bypass valve. I T'd off onto the hose that is going to the bypass valve and here i am with my issue.
ideas/solutions please.
So not to digress too much, but where in the logs are you finding this info? I have no idea how to find any of that data in the logs. I had my laptop hooked up but didn't see anything obvious.
And to keep this on subject, I am following this because I'll be ordering a guage shortly.
diirk
waiting on a Neptune Premium MT
diirk is offline   Reply With Quote
Old 05-09-2014, 11:37 AM   #19
diirk
diirk's Avatar
Drives: 4Runner
According to the RallySport Direct install FAQ, they also installed the T-fitting for their boost guage after the factory check-valve on the line running to the brake booster. I didn't see one...
diirk
Old 05-09-2014, 01:22 PM   #20
qtwre
Drives: White FR-S
Does anyone has a picture of the factory check valve? I didn't notice one in my brake booster line.
qtwre is offline   Reply With Quote
The Following User Says Thank You to qtwre For This Useful Post:
diirk (05-09-2014)
Old 05-09-2014, 01:31 PM   #21
diirk
diirk's Avatar
Drives: 4Runner
Here's an image from the FSM
diirk
The Following 2 Users Say Thank You to diirk For This Useful Post:
HRTROB (05-09-2014), qtwre (05-09-2014)
Old 05-09-2014, 01:52 PM   #22
qtwre
Drives: White FR-S
Looks like I cut my hose awfully close to that. I'm glad it has a valve though. I've only been boosted for a week but I was wondering what people were doing about getting positive pressure into the booster.
Old 05-09-2014, 02:05 PM   #23
diirk
diirk's Avatar
Drives: 4Runner
I'm going to have to go back and verify. I cut mine close to the engine side to keep the fitting hidden. I'm hoping I'm below the check valve.
diirk
Old 05-09-2014, 02:51 PM   #24
HRTROB
HRTROB's Avatar
Drives: Toyota 86
Guys there's no need to cut that brake booster line. You can pull off the end that goes to the engine side, tee into that, and connect the tee to the engine side with a short length of 5/32" hose.
diirk (05-09-2014)
Old 05-09-2014, 05:14 PM   #25
FyeaFRS
I'm a pretty visual person and hopefully this helps, but are well looking at needing to put in the T in at 'A' or 'B' here?
Base on Vortech's directions, I'm willing to bet most people cut the line, like I did, at B to run the hose that goes to the BOV. If I understand correctly, this will not work for the purposes of vacuum/boost readings?
Now, I have an extra oem hose for the break booster line. If I cut it at A and run the line to the BOV, can I then put a T in that line, between the BOV and break booster hose, and then run that to the gauge?
Or do I have the positions backwards...?
Old 05-09-2014, 05:44 PM   #26
FyeaFRS
So would this work?
Old 05-09-2014, 05:45 PM   #27
HRTROB
HRTROB's Avatar
Drives: Toyota 86
You have it backwards. You want to tee off the line at position B, after the check valve. I have my boost gauge teed in there and I get proper vaccuum and boost readings.
Old 05-09-2014, 05:50 PM   #28
FyeaFRS
So would we need to add in another T in-line with the one that goes to the vortech BOV? Or would the setup above work?
Or something like below:
Vortech Supercharging System Update - More boost, more POWER! Brian@Vortech Forced Induction 337 03-12-2016 03:42 PM
DIY - Defi 60mm Boost Gauge Install in AC Vent msile DIY (Do-It-Yourself) Guides 55 02-27-2016 01:10 PM
Which boost gauge? Bigmaxy Forced Induction 3 07-07-2013 07:11 PM
Memorial Deal!!White MaxTow 30 PSI Boost/Vacuum Gauge Tubano-shop Interior Parts (Incl. Lighting) 0 05-27-2013 07:47 AM
Temperature Gauge a dummy gauge? bambbrose BRZ First-Gen (2012+) — General Topics 40 08-19-2012 04:29 PM
