Old 05-08-2014, 01:07 AM   #15
Shiv@Openflash
Shiv@Openflash's Avatar
Drives: 2013 FRS
Originally Posted by tnle View Post
I've sent it through, thanks!
Got it. Forwarded it to my programming team. Hope to have a resolution by tomorrow
Shiv@Openflash is offline   Reply With Quote
The Following User Says Thank You to Shiv@Openflash For This Useful Post:
tnle (05-08-2014)
Old 05-09-2014, 12:55 AM   #16
AL008
Drives: Celica 04
I have exactly the same error... 0x63
This only happens on one of my laptops, other computers seem to work.
On another laptop however, when I go to upload it has the error:
"DEV121.DLL error"
"1"
"CTRL1"
"Checksum error"
I even tried applying Windows 8 patch, didn't work.
AL008 is offline   Reply With Quote
Old 05-09-2014, 02:10 AM   #17
Shiv@Openflash
Drives: 2013 FRS
The only problem is, I can't connect to my Tablet.
I keep running into "Error 0x63 while communicating with the device" every time I click on "Download Data" or "Upload Data"
After looking through your log file, this is what happened:
1) You read the ECU successfully and the OFT generated OTS maps for you.
2) You wrote the Stage 1 A01G OTS map to your ECU.
3) You connected OFT to OF Manager and overwrote the modfile database file. While it was uploading, you clicked on the download section at the same time causing a communication stoppage between between the software and the OFT which generated corrupt files that are now stored in the OFT.
Which unfortunately means that your OFT needs to be replaced In the next user software release, we will make other sections un-clickable while an upload is in progress. You should have already received an email by Robert@vishnu. If not, shoot him an email tomorrow and we can arrange the next step. Sorry for the inconvenience.
Regards,
shiv
The Following 2 Users Say Thank You to Shiv@Openflash For This Useful Post:
tnle (05-09-2014), zc06_kisstherain (05-09-2014)
Old 05-09-2014, 04:03 AM   #18
tnle
Drives: Toyota 86 13'
Regards,
shiv
I've shot him an email
thanks
tnle is offline   Reply With Quote
Old 05-09-2014, 10:41 AM   #19
Tromatic
Hmm. I had something similar happen to me. My problem seems to have been related to a bad install of a required Microsoft bit of software. My tablet was bricked as well. I reinstalled Win 7 and just the OFT manager. I made sure C++ installed correctly and was able to get access to the tablet to erase and start over.
Old 05-09-2014, 02:27 PM   #20
zc06_kisstherain
zc06_kisstherain's Avatar
Drives: SWP BRZ
Regards,
shiv
This is every company's customer should be.
now i know i Must not click anything when OFT processes something. haha
I've fixed my Bluetooth connection issue! Superhatch Issues | Warranty | Recalls / TSB 34 04-15-2015 02:15 AM
USB / Aux connection Sporran Electronics | Audio | NAV | Infotainment 9 04-20-2014 06:22 AM
FRS iphone 5s bluetooth connection issue Gank61 Electronics | Audio | NAV | Infotainment 2 04-03-2014 09:19 AM
FRS 28 pin stereo connection Sparky fire Electronics | Audio | NAV | Infotainment 2 02-07-2014 03:32 PM
USB connection ScottKR Electronics | Audio | NAV | Infotainment 5 07-30-2013 12:54 PM
