Old 05-08-2014, 12:22 PM   #15
labskaus
labskaus's Avatar
Drives: Toyota GT86
depending on the effect you want ... I worked with a mix of materials to reach my aim (dead door). Only alubutyl is not always the right choise. I used heavy foil, some thin alubutyl and foam foil.
Some one other will tell you, that some L-profil alu bars will be needed.
For normal usage the door kit should be enough to make a complete one layer on inner door, replace the watershield foil plus the inner door cover. Maybe some additional foam foil would the good between door cover and door.
labskaus is offline   Reply With Quote
Old 05-08-2014, 06:51 PM   #16
djmm
djmm's Avatar
Drives: toyota
Cool thanks. Looks like I'd be better off buying bigger pack one.
djmm is offline   Reply With Quote
Sealing And Deadening the Doors WolfSongX Electronics | Audio | NAV | Infotainment 77 04-08-2020 03:35 AM
What are you using for sound deadening ? mashal Electronics | Audio | NAV | Infotainment 108 11-06-2015 01:51 PM
SOUND DEADENING White64Goat BRZ First-Gen (2012+) — General Topics 7 04-22-2013 02:36 AM
Sound deadening yomchi1989 Electronics | Audio | NAV | Infotainment 16 01-02-2013 03:08 PM
Sound deadening yomchi1989 AUSTRALIA 9 12-27-2012 10:09 PM
