Old 03-31-2012, 11:06 PM   #1
Sasquachulator
Pavement Grey
About the LED strip on the GT86
Is that for DRLs or does it work as high beams or what?
Cuz on the FRS And 86 the headlight is projector beam style, but the FRS has the high beams where the LED strip would be, but the 86 just has the LED strip.....and i never noticed where high beams would be....
Was wondering how a swap would work if that's the case (or rather, what to do with the LED strip) Its also looking like the NA spec DRL's might either be low intensity high beams or where the amber turns signals are (i actually never noticed where it would be).
Old 04-01-2012, 12:02 PM   #2
Kiwi
Drives: Volkswagen Golf GTI
The LED's are used as DRL.
The main HID's are used as low and high beams.
Kiwi is offline   Reply With Quote
Old 04-01-2012, 12:04 PM   #3
tranzformer
Delights in pure handling
tranzformer's Avatar
Drives: Zoom Zoom
Correct, the LED's are DRL. However only the BRZ comes with HIDs. The FRS does not.
tranzformer is offline   Reply With Quote
Old 04-01-2012, 12:08 PM   #4
Jeff Lange
Jeff Lange's Avatar
Drives: 1986 AE86 GT-S, 2011 Lexus IS250 6M
On the 86/FR-S: The halogens have the projector low beam and reflector high beam. Halogen high beam is run at half-wattage for DRL.
On the 86/BRZ: The HID's are bi-xenon projectors (low and high in a single projector). The LED's/Light Strip are for DRL.
Jeff
2011 Lexus IS350 F-Sport 6MT with LSD
1986 Toyota Corolla GT-S Supercharged
Jeff Lange is offline   Reply With Quote
Old 04-01-2012, 12:17 PM   #5
Spaceywilly
ZC6A2B82KC7J
Spaceywilly's Avatar
Drives: 2002 WRX
Jeff
There is a "shield" that flips up to cut off the top portion of the light output for low beams. When you switch to high beams the shield drops out of the way. So only one bulb is used for both high and low beams, the other lights are just DRL. The frs has separate lights for high and low beam. For the frs and gt86, the headlights should be swappable, but you would also need to add the switch for the aiming motor. The BRZ also has the turn signal in the headlight housing so it may not be swappable.
Straights are for fast cars. Turns are for fast drivers.
Spaceywilly is offline   Reply With Quote
Old 04-02-2012, 11:51 AM   #6
tripjammer
tripjammer's Avatar
Drives: WRB BRZ limited 6MT
That's what I was thinking too...it's best to get the Toyota 86 HID lights to replace the FR-S lights...
and hope that these guys make some stuff for the FR-S stock lights...
http://www.clearcorners.com/products/scion/
tripjammer is offline   Reply With Quote
Old 04-02-2012, 12:04 PM   #7
Saibot
Saibot's Avatar
Drives: 01 Toyota Corolla / Porsche 911 C2
uhh i hope not. im not paying 1.5k for a pair of lights!!!
Saibot is offline   Reply With Quote
Old 04-02-2012, 10:42 PM   #8
Kiwi
For that kind of price why not just buy OEM headlights?
And I'm not sure if I'm reading this right, but $300 for a pair of led license plate lights!?
Old 04-02-2012, 10:52 PM   #9
Xdragonxb0i
Drives: ex500r
i think we evidence that scion will be offering HID lights. so hopefully its the same one from the 86 or the BRZ headlights
Xdragonxb0i is offline   Reply With Quote
Old 04-03-2012, 03:02 AM   #10
Jeff Lange
Jeff Lange's Avatar
Scion will not be offering HID headlights, at least not for the first model year.
Jeff
Old 04-03-2012, 07:27 AM   #11
colHolm
Default User Title
colHolm's Avatar
Jeff
This.
colHolm is online now   Reply With Quote
Old 04-03-2012, 10:07 AM   #12
tripjammer
tripjammer's Avatar
Clearcorner maybe expensive, but they are top stuff. You really think factory HIDs are going to be less than $1500 a pair? First of all the BRZ HIDS will probably not fit and so you are going to have to buy some from the European based 86, because the JDM ones are for right hand drive cars, so expect to pay a grip for some HID lights, unless you go straight aftermarket.
Plus the reason why the clearcorners are so expensive is because they use way more LEDS in their lights. More than anybody.
Old 05-14-2012, 11:16 PM   #13
Bristecom
Bristecom's Avatar
Drives: 2017 Subaru BRZ PP
Something I noticed is that for the Japanese model, those LED's don't seem to be DRL. But when you look at the European model, they are always on when the engine is on.
Here is an example:
[ame="http://www.youtube.com/watch?v=YboJWdt06wM"]http://www.youtube.com/watch?v=YboJWdt06wM[/ame]
Toyota + Subaru =
Bristecom is offline   Reply With Quote
Old 05-15-2012, 12:07 AM   #14
tripjammer
tripjammer's Avatar
Here is an example:
I believe you can turn the DRL off or on.
