Old 05-07-2014, 10:03 PM   #449
Mehster
Drives: Firestorm 2013 Scion FR-S
If you are having trouble with your faceplate sitting flush, you might be using the wrong holes on the side of your unit to mount your brackets.
I had mine like this:
I just couldn't get my dash trim piece to snap in. I trimed a tiny bit off the front edge of my brackets and I managed to get the bracket to move forward a notch.
My dash piece went on perfectly!
I'm really happy with the unit so far! All I have left to get working is the aux jack and thanks to the handy chart that Deathalo posted I don't think that is going to be too bad. Thanks for all the wonderful tips guys.
Mehster is offline   Reply With Quote
The Following 4 Users Say Thank You to Mehster For This Useful Post:
Deathalo (05-08-2014), HATED1 (05-23-2015), microbionic (05-07-2014), SilverlightPony (07-02-2014)
Old 05-08-2014, 12:02 AM   #450
SHIFTER
SHIFTER's Avatar
Drives: Scion FR-S
Your after pics are exactly how it should be bolted on
Andrew
2013 Scion FR-S MT (Silver)
2011 Toyota Rav4 Sport V6 4wd (Silver)
SHIFTER is offline   Reply With Quote
Old 05-08-2014, 12:04 AM   #451
SHIFTER
SHIFTER's Avatar
Drives: Scion FR-S
Originally Posted by t.chk View Post
Anyone try wiring up steering wheel controls with this? Have links to someone who has? (even if it is non-BRZ/FRS/GT86)
for what car? it will do steering wheel controls on the right car. of course the supplied harness isn't wired as such. but it DOES work if you wire it up.
Andrew
Old 05-08-2014, 12:12 AM   #452
Deathalo
Drives: 2013 WR Blue Limited Manual BRZ
Thanks for the pics, I have mine like your first pic, so time to trim it a bit!
Deathalo is offline   Reply With Quote
Old 05-08-2014, 12:31 AM   #453
DC2R
Drives: 2014 Scion FR-S
Disappointed that the app storage is only 600megs. Maybe they can get us a Rom that partition s it differently
Sent from my GT-N5110 using Tapatalk
DC2R is offline   Reply With Quote
Old 05-08-2014, 05:09 AM   #454
Onelifeliveit
Drives: Toyota 86 GTS
I just bent the front part of the bracket a little bit, say 1-2mm outwards with a pair of pliers. easier than trimming
Onelifeliveit is offline   Reply With Quote
The Following User Says Thank You to Onelifeliveit For This Useful Post:
Old 05-08-2014, 10:26 AM   #455
Prog
Prog's Avatar
Drives: 2016 Cadillac CTS
Yeah, that does blow. Someone in this thread actually already contacted Ca-Fi and they said they'd issue an update.
Prog is offline   Reply With Quote
Old 05-08-2014, 10:47 AM   #456
DC2R
Tronsmart ships their Android hdmi sticks the same way. People have made flashing methods so you can decide how much you want to allocate to apps and how much to "sdcard".
Would definitely like to see root so we can edit build.prop to make it look like a nexus 7 or something in play store. Many apps don't show up for me.
Also sorry if this has already been answered but if I want to try a USB modem it would HAVE to go in place of the Wi-Fi module. Can't have both right?
One more thing: anyone been able to turn off auto dim? Seems to be either headlight or time linked. Both dim it way too much at 7-9 am. Two solutions I might try is install an backlight control asp like Lux or cut the headlight wire....
Sent from my SM-N900T using Tapatalk
Old 05-08-2014, 11:12 AM   #457
t.chk
Drives: Subaru BRZ Limited
Yea, I asked them about a compatibility list for this particular unit...and they did not understand my question.
t.chk is offline   Reply With Quote
Old 05-08-2014, 12:37 PM   #458
Deathalo
There's a setting I remember seeing in the car settings that lets you turn that off if I remember correctly.
Old 05-08-2014, 01:05 PM   #459
DC2R
Mine only lets me toggle head light or time of day
Old 05-08-2014, 04:05 PM   #460
Prog
Prog's Avatar
I'm not having any issues with brightness with the headlight feature turned on (dims head unit when headlights are on), but you guys that aren't satisfied with that can always pay a couple bucks for Tasker and set brightness according to the time of day.
Old 05-08-2014, 05:25 PM   #461
xjohnx
Grip>Slip
xjohnx's Avatar
any of you guys have any luck getting DashCommand to work with this head unit yet? Under the DashCommand settings when i try to select the OBD2 adapter (that i have paired with the head unit already), it won't let me select it.
For those of you that are unfamiliar with DashCommand, It's similar to torque, but much easier on the eyes. You can watch the video below to see how the default interface and layout looks.
[ame="https://www.youtube.com/watch?v=7DIh4u0bAgY"]Pioneer Appradio3 Dashcommand by Palmer Performance - CES 2014 - YouTube[/ame]
Old 05-08-2014, 08:21 PM   #462
ir1064
Drives: 6MT, C7P
still haven't hear anything from Ca-Fi yet, but i'll post here as soon as i get the update news.
does any one able to use DoubleTwist on their unit? all i want is a music player that can sync my iTunes playlist.
ir1064 is offline   Reply With Quote
REVIEW: Ca-Fi Toyota Universal - Stock Fitment ANDROID Stereo SHIFTER Electronics | Audio | NAV | Infotainment 16 06-13-2017 07:23 PM
Android, bluetooth, Music, and the FR-S stock pioneer stereo JayNutter Electronics | Audio | NAV | Infotainment 27 12-18-2014 04:54 AM
How to: Torque on an android powered stereo with no hacking v. Ca-Fi Dashlinq4 SHIFTER Electronics | Audio | NAV | Infotainment 29 04-07-2014 05:58 AM
