| DIY (Do-It-Yourself) Guides For all DIYs. |
#29 | |
Drives: 2016 STI DGM
![]() BTW, I like the cam you have... Was it a diy?
Subaru STI :![]() |
#30 |
Drives: 2013 10 series FRS #944
It will be tough to put this into the spoiler since you need to tie the nut in the back end and with the spoiler, you might have to drill another hole at the bottom so you can access to the nut to tie up the camera.
| The Following User Says Thank You to #944_10_Series_FRS For This Useful Post: | Kimsey47 (08-05-2013) |
#31 |
Diesel Tech
Drives: 2013 FR-S Hot Lava 6MT
I've been super busy and kind of abandoned the finishing touches of mine. I used 18 gauge wire throughout. There isn't much of a power draw to worry about needing larger. I tapped power from the radio amplifier like the DIY, just because of location convenience. Don't know if I'm the only one, but this seems to be a bad idea. If the radio is on, there is too much of a voltage draw to run the camera properly. When I get back from my trip, I'm going to power it right from the battery, with a 5amp fuse. This makes sure there's no fluctuation in the voltage or amperage.
#32 | |
10 Series Fanatic
Drives: Scion FR-S 10
Did you not go with the beatsonic? This DIY is way harder than installing the beatsonic.
#33 |
StatusLow
Drives: 2013 10 Series FRS
#34 |
Drives: Scion FR-S
So i wired up like this is written. bought the video adapter from svx guy, ran the reverse wire from the driver side kick panel to the harness in slot two and powered it from my amp for 12+ power and the camera kicks on when the head unit turns on. once i start playing music it wont go back on the camera mode, i need it to turn on when i put it into reverse.
#35 | |
Professional Smartass
Drives: White Out FRS
#36 |
Bump, this still works on all 2014 FRS's!!! I know because I just installed the 2014 headunit in my car and the camera works perfectly.
#37 |
Drives: '14 Whiteout FR-S
Holy thread revival!!!
Did anyone ever figure out what size terminal was required for properly adding the pin to the 28-pin connector? And is it true that the camera must be powered when the car starts up? The camera I have has built in lights around it so I was hoping to power it only with reverse. Guess that won't work if this is the case.... |
#38 | |
How ya gonna keep 'em down on the farm once they've seen Karl Hungus? |
#39 | |
Drives:
2014 6-speed Monogram (37J) |
#40 |
DrivinginDreams...Cloud86
Drives: Toyota GT86
Not sure if anyone has done this yet, but instead of mounting the camera below, possibly it could be mounted directly into the rear fog light housing for a more stealth and oem look. It could even be colored red to match.
#41 |
Drives: 2013 Firestorm FRS
You could, but I think the reverse cameras give you better view/perspective when mounted higher up. Also, my reverse camera is pretty darn oem looking, IF you even noticed it.
But, it doesn't hurt to explore |
#42 | |
Scion FR-S
Drives: Scion FR-S 2013
Ok so nothing is working. I have tried everything on the original post. All wires are the same. I have the bespoke premium head unit and took it to 2 audio shops. For some reason today the camera decided to work. It worked for about 6 minutes. Later on the day it stopped working. What is going on? Why isn't it working on my headunit???? Help. Do I needed this adapter? I have a scion FR-S 13 with bespoke premium headunit. Any help will help. Thx. Do I need to order this?? -1 Backup Camera Harness(Includes connections for 12-volt jumper harness, 16-pin head unit connection, Composite Video input, Relay, and 12-volt output lead) -1 12-Volt splice harness(T-harness) -1 Relay (6-volt input coil) -1 Butt connector to connect 12-Volt output from harness to the backup camera |
| Scion FRS Bespoke Backup Camera, What do I need? | post_break | Electronics | Audio | NAV | Infotainment | 8 | 07-02-2016 09:55 PM |
| Kenwood CMOS-210 Backup Camera Install | TSY | Electronics | Audio | NAV | Infotainment | 34 | 12-10-2014 01:18 PM |
| Running Backup Camera Wire | Tony Mac | Electronics | Audio | NAV | Infotainment | 9 | 12-04-2013 11:28 PM |
| Beat-Sonic Backup Camera & Adapter for FR-S (Bespoke) & BRZ Special Price | Beat-Sonic | Audio/Visual, Electronics, Infotainment, NAV | 60 | 07-15-2013 03:58 PM |
| Backup Camera Help | husker741 | Electronics | Audio | NAV | Infotainment | 2 | 02-13-2013 01:04 AM |
