#1569 |
in orbe terrum non visi
Drives: violent
I have no skid plates and no overheating issues
Sent from my SAMSUNG-SGH-I747 using Tapatalk
I have E85 where there isn't E85, that's my secret.
http://www.ft86club.com/forums/showt...t=reaper+build |
#1570 |
Much title. Wow.
Drives: 2013 BRZ Sport-Tech
I have skid plates. but I live in Canada.
༼ つ ◕_◕ ༽つI PUT A SPELL ON YOU ༼ つ ◕_◕ ༽つ
#1571 |
I'm not running mine and have had no issues up to 150+ mph
The Frozen North
#1572 |
NASA SpecE30 Racer
It isn't dangerous persay, but it ruins the hard work the Subaru/Toyota aero guys did giving this car a nice low cd.
- King Tut
Street/Track Car: 2006 Honda S2000 TT3 || Race Car: 1987 BMW 325is SpecE30 || Tow Vehicle: 2014 RAM 1500 EcoDiesel Sold Cars: 2012 BMW M3 || 2013 Subaru BRZ || 2012 Porsche Cayman R || 2009 Chevrolet Z06 || 2009 BMW M3 || 2004 BMW M3 || 2004 Nissan 350Z |
#1573 |
NASA SpecE30 Racer
I would argue the OEM ones seem to work just fine and mine didn't melt in over 15,000 miles with the FBM kit.
- King Tut
#1574 | |
I Love custom Turbo kits
Drives: Limited BRZ
People also need to calm down, and don't make this a mass hysteria huge issue. There is ONE failure of the mounts, in I bet over 50 installed Perrin mounts in the forum. Vibrant also sells mount heat blankets or you can wrap them with regular header wrap.
#1575 |
Drives: 2013 Scion FR-S, 2014 Lexus IS350
Same here. I've had good luck with the stock motor mounts. The onlything I see melting from the FBM kit is the FBM passenger side fan. I am going to try putting some DEI cool tape over the pastic that houses the fan motor to reduce melting... Maybe that will work haha.
#1576 | ||
PhoneFlash by EcuTeK
I think everyone is missing the point of what was being asked by the customer as we understood as requested by the customer. Maybe there was a communication error on my part as what was expected by the customer and I have no problem resolving it, but as I understood and please correct me if I am wrong (customer). 1. The customers number one priority was drivability, smooth reliable, perfect start, like a stock car. 2. The customer did not want to run E85 or more than wastegate pressure, just wastegate pressure of 15 PSI. 3. The customer did not mind what the final power number was as they wanted reliable, and safe to drive vehicle. With all this info I recommended stock injectors for perfect start and drivability every time you get in the car, because as people have stated if it is not exact it annoys me. Calm down, calm down... We have the ability to tune larger port injected based cars, and have tuned quite a few with great results. As quoted below... Quote:
Now back to the customers requests. When we took the vehicle off the dyno we had the customer test drive the vehicle, to see how the power felt and the reaction was it felt the same power as when it was tuned previously on 91 octane but a lot smoother and easier to drive. As the customer stated above, previously it made 353whp on a dynojet, so going from 353 to 270 whp (Maha) is quite a difference. That is a percentage difference of about 30%. So in order to hit 400+ hp on that particular dynojet a vehicle would need to make just about 310 hp on Mann Engineering Maha dyno. So either we are using a super low reading Maha dyno or an extremely high reading dynojet. You take your pick. There are a lot of miss information, a lot of jibber jabber from many people and a lot of darts being thrown just to confuse the conversation. This was an attempt to clear any misconceptions and to make an effort to work with the customer to clear any communication errors on our part and take care of them for the customer. Cheers, William Knose Delicious Tuning |
#1577 |
Much title. Wow.
#1578 | ||
Drives: Blue Subarus
I'm really just trying to figure out why it's so low. When you were done with the car we stood around discussing this for 10 minutes... You said the stock injectors weren't maxed, and suggested that the GTX3076R could be much less efficient than the GT2871R at 15psi, which doesn't seem to be true. Is this just because the stock injectors are maxed? Is the larger turbo really less efficient at 15psi? In the end I spent a lot of time and money to lose power, add turbo lag, for better drivability. I don't understand why I can't have power and drivability
'13 GBS BRZ 6MT | FBM 9:1 w/ GTX3076R| FBM oil cooler + catch-can + radiator + SPAL fans| Rays 57xtreme / PSS | Perrin 2.5" FP | Invidia 2.5" OP | Perrin 3" CBE | RCE T2s | Exedy Stg1
'15 STI LE | Cobb Stg1 |
#1579 |
Drives: Limited BRZ
Absolutely and unequivocally NOT true. The GTX3076R outshines the GTX28 throughout, but even moreso when approaching 15+ psi is when it REALLY shines.
#1580 | |
The Frozen North
#1581 |
I tuned a gtx2867r (similar to the 2871) and gtx3076r on the same (very heartbreaking mustang) dyno recently, at ~15psi oddly enough (actually a bit less, maybe closer to 14 psi). the 2867r made 357whp and the 3076r made something like 376 iirc. the 3076r, in my direct experience, makes more power at every boost level than the 2867, from 9-18psi and beyond. at least that's what i've seen... ymmv i suppose.
#1582 | |
| Tags |
| best company ever, big fuck off turbo, blown, bow chicka wow wow, fbm, full, owners, powaaaaaa!, thread, will work for turbo |
| AVO Turbo Kit Owners Topic | Sportsguy83 | Forced Induction | 1935 | 02-20-2023 10:46 AM |
| Full Blown FRS/BRZ Stage 1 Turbo Kit | FullBlown | Forced Induction | 456 | 09-27-2021 03:10 AM |
| FA20Club Turbo Kit Owners Topic | pixel67 | Forced Induction | 1531 | 09-09-2014 12:36 PM |
| Full Blown Turbo Kit! | Unleashed | Engine, Exhaust, Bolt-Ons | 70 | 10-09-2013 09:46 AM |
| WTB: Full Blown turbo kit (used) | whitefrs | Engine, Exhaust, Bolt-Ons | 12 | 03-29-2013 09:15 PM |
