Old 05-06-2014, 08:26 PM   #15
TestaRossa
TestaRossa's Avatar
Drives: 2013 DGM BRZ
Originally Posted by Calum View Post
That's where I started. I clicked the link for our cars and that's what came up. I probably missed something thought, those number just don't make any sense.
Hmm...don't know where you find those numbers but on my end spring rates shows up as F:8k R:9k
Saorri for mah bad English
TestaRossa is offline   Reply With Quote
Old 05-06-2014, 09:32 PM   #16
Calum
That Guy
Drives: 2013 asphalt FRS MT
I clicked this Tein's product matrix from above.
Next I clicked on mono sport
Then lineups click here
Finally I clicked the photo beside BRZ.
But I was wrong, those specs were for the stech springs. Why clicking a link professing to be a picture of the monoflex kit would bring me to the specs for the stech spring is beyond me.
Old 05-07-2014, 01:56 AM   #17
TestaRossa
TestaRossa's Avatar
Pretty sure that's the product line up page for the car, if you scroll down u should be able to see other springs and coilovers
The Following 2 Users Say Thank You to TestaRossa For This Useful Post:
Calum (05-07-2014), CSG Mike (05-07-2014)
Old 05-07-2014, 03:15 PM   #18
GTHachiRoku
Big in Japan
GTHachiRoku's Avatar
Drives: turBRZ
I like the Japan price better. If they'd been out a bit sooner I could have picked some up
GTHachiRoku is offline   Reply With Quote
Old 05-07-2014, 03:51 PM   #19
ATL BRZ
TEQSPORT Brand Manager
ATL BRZ's Avatar
Drives: '24 GR86 + '16 FR-S
How much are they in Japan? You going back any time soon?
Old 05-07-2014, 03:53 PM   #20
CSG Mike
CSG Mike's Avatar
We do too, but transporting them here isn't free and it's not a mass produced product of Chinese origin...
Old 05-07-2014, 03:55 PM   #21
GTHachiRoku
Big in Japan
Drives: turBRZ
I think I was quoted about $300 less than the US msrp.
I'll be back there in October probably! I need to figure out what else to get while I'm there.
The Following 2 Users Say Thank You to GTHachiRoku For This Useful Post:
2013GTRNate (04-18-2015), ATL BRZ (05-07-2014)
Old 05-07-2014, 03:58 PM   #22
GTHachiRoku
Big in Japan
Drives: turBRZ
Yeah, I love my Teins. I'll probably pick up the edfc active pro in October.
2013GTRNate (04-18-2015), fooddude (05-14-2014)
Old 05-14-2014, 12:05 PM   #23
ATL BRZ
ATL BRZ's Avatar
Any updates @CSG Mike , @CSG David ?
I'm still interested in hearing more about these. Not just one liners
Could you at least humor us with a tentative release date?
Feel free to PM.
The Following 3 Users Say Thank You to ATL BRZ For This Useful Post:
Anthonytpt (05-14-2014), DAEMANO (05-14-2014), fooddude (05-14-2014)
Old 05-14-2014, 01:55 PM   #24
CSG Mike
CSG Mike's Avatar
Feel free to PM.
IIRC it should be within the next 4 weeks; it depends on when the container makes it through the port, so it's +- 2 weeks.
Essentially, this is an updated Monoflex, that uses newer components, and also comes in at a lower price point due to the exchange rate with the Yen being more favorable now.
The damper curves are a reflection of the feedback based on the Monoflex, and are designed for more street comfort without compromising performance. Additionally the range of adjustment has been increased to accommodate a larger range of spring rates, and some crosstalk has been intentionally engineered in to allow simultaneous compression and rebound adjustment
The Following 3 Users Say Thank You to CSG Mike For This Useful Post:
Anthonytpt (05-14-2014), ATL BRZ (05-14-2014), DAEMANO (05-14-2014)
Old 05-14-2014, 02:04 PM   #25
DAEMANO
Time Traveller
Hi Mike,
Would you recommend and increased travel rear top mount like the Robispec or Raceseng top mounts for these? Or are the provided rear mounts sufficient for occasional (1x e/o month) track duty at circuits like Buttonwillow & Big Willow?
Old 05-14-2014, 02:07 PM   #26
ATL BRZ
ATL BRZ's Avatar
Thanks Mike.
Basically I'm wanting to know your public opinion on these as being a good fit for a car like mine and a driver like me seeking a good value coilover with good street-ability and good track-ability. I really like the idea of turning one knob for simultaneous C&R adjustment over a wide range. I am not a suspension tuning expert and I'd really prefer the ease of adjustment that the Mono Sport has over a two-way adjustable damper.
I also really like the included camber adjustable top mounts on the fronts; two less things to worry about buying separately. I can't find anything wrong with these for my application and so I'm really excited about them. The EDCS compatibility sounds like icing on the cake.
Old 05-14-2014, 02:24 PM   #27
fooddude
Drives: 04 Toyota Tacoma Prerunner Reg Cab
Spring Rates?
Good for track use?
fooddude is offline   Reply With Quote
Old 05-14-2014, 02:30 PM   #28
CSG Mike
CSG Mike's Avatar
Originally Posted by DAEMANO View Post
Hi Mike,
If you're going to be dropping the car a lot, YES!
The dampers are designed to be used on the stock mount points, but adding more compression travel can help if you're lower than intended. Keep in mind that this comes at the cost of droop travel, but that can be mostly mitigated with a clutch type LSD (OSG, Cusco, Kaaz)
How well suited these are for you will depend on how fast you're driving around the track, and if you're using the berms aggressively or not.
"dEAD CLICKS" ON TEIN ST FLEX Khánh Suspension | Chassis | Brakes -- Sponsored by 949 Racing 11 03-10-2019 02:36 PM
"Clicking" or "knocking" caused by rear seat pull down lever. husker741 Issues | Warranty | Recalls / TSB 6 11-27-2013 02:30 PM
"My Dealer told me {insert dumb idea}" (was "Toyota/Subary Partnership Cancelled?") levifig BRZ First-Gen (2012+) — General Topics 48 08-09-2013 06:34 PM
Anyone else try running "square" tires on "staggered" wheels? hamlet Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 21 12-19-2012 12:59 PM
