#421 | |
Drives: 2013 WR Blue Limited Manual BRZ
#422 |
Drives: 2013 Subaru BRZ
Does this support video in for an AUX source ... such as dashcam? ... or is the video in only for reverse cam...? ...
#424 |
| The Following User Says Thank You to Deathalo For This Useful Post: | microbionic (05-06-2014) |
#425 |
Because Racecar
Drives: 2013 Lightning Red Subaru BRZ
#426 | |
Drives: 2016 Cadillac CTS
| The Following User Says Thank You to Prog For This Useful Post: | ProTekk (05-06-2014) |
#427 | |
Drives: Whiteout FR-S
#428 |
So I got it all working, I attached both the "Back" wire coming from Ca-Fi and the power wire coming from my Rear camera to one single pin and plugged that into the SWC harness with my AUX port wires. It hit's pin 2, the brown/silver wire and it every time I go into reverse, the image pops up nicely. The only other issue I encountered was that the stock brackets have 2 bumps that are supposed to line up with holes on the HU so you can line it up to the correct screw holes. It didn't seem to fit in any way where I could screw it in correctly, so I drilled out the top bump on each bracket and was able to secure all 4 screws easily. The face plate didn't go on as easy as I thought it did on stock HU, might be sticking out just a millimeter farther than it should? Oh well, it's all up and running and really nice. Oh, and my AUX port works great now after the pin swaps I made via the diagram I linked.
#429 |
#430 |
Drives: 2014 Scion FR-S
Anyone know how to remove stock GPS module?
Sent from my SM-N900T using Tapatalk |
#431 | |
Drives: Scion FR-S
I could do it for a fee.
Andrew
2013 Scion FR-S MT (Silver) 2011 Toyota Rav4 Sport V6 4wd (Silver) |
#432 | |
Drives: Scion FR-S
you may have used the wrong bolt holes. The mounting bracket should be right up against the front of the unit.
Andrew
#433 |
Drives: Scion FR-S
Ill throw this out there for any of you guys. If you want me to handle the wiring for you on the installation - for $20 bucks I'll wire the antenna, Aux jack, reverse camera, and have it be 100% plug and play for you without screwing around.
I'm NOT a business, but since a few of you are having issues - I just want to offer my help for anyone that needs it. All you would need to do is send me your aux adapter, antenna adapter and Ca-Fi harness. I'll turn it around in just a few days for you.
Andrew
#434 | |
Drives: Scion FR-S
![]() Cool - sorry guys I haven't had an opportunity to yank mine to confirm all of this yet (busy at work). Looks like you got the answers here though!
Andrew
| REVIEW: Ca-Fi Toyota Universal - Stock Fitment ANDROID Stereo | SHIFTER | Electronics | Audio | NAV | Infotainment | 16 | 06-13-2017 06:23 PM |
| Android, bluetooth, Music, and the FR-S stock pioneer stereo | JayNutter | Electronics | Audio | NAV | Infotainment | 27 | 12-18-2014 03:54 AM |
| How to: Torque on an android powered stereo with no hacking v. Ca-Fi Dashlinq4 | SHIFTER | Electronics | Audio | NAV | Infotainment | 29 | 04-07-2014 04:58 AM |
