Old 05-06-2014, 02:26 PM   #1
swpbrz
Drives: swp brz limited
downshift to first
I was watching a review of the brz where the driver mentioned doing a lot of downshifting to first on slow very tight corners to keep the power up.
I was curious ,so I've been noodling a little. I had always assumed it was bad for some reason because it was pretty difficult when I first started. But with some practice I can get a pretty consistently smooth downshift to 1st if I blip the throttle just right. At maybe 5 -15 mph.
If I do this and the shift feels smooth is there any other possible problem with downshifting to first? I hear a lot of people say never do it, but I'm not sure if it's just because itis a little trickier, or it is actually bad for the car to do it regularly.
swpbrz is offline   Reply With Quote
Old 05-06-2014, 02:31 PM   #2
AdrianG
Generally Well Liked
Drives: '08 STi Hatch, '11 Outback 3.6R
There is no problem with downshifting to first in this car. Some cars (particularly older ones) don't have a synchro on first gear, which is why a lot of people believe you need to be completely stopped before shifting into first. This transmission has a synchro on first, so it's safe to downshift as long as you are smooth.
AdrianG is offline   Reply With Quote
The Following User Says Thank You to AdrianG For This Useful Post:
DAN_BRZ (05-09-2014)
Old 05-06-2014, 02:32 PM   #3
cjsporl1996
Drives: WRB BRZ, Monte Carlo SS
I can't imagine it being great for the car in fact many people mentioned that it is very difficult to get it into first at those speeds. I have been forcing my car into first for sometime now and now the car has become so used to it that it shifts into first fluently at a little over 10 mph. It does make a noise when you try to force it into first. Anyway its up to your discrepancy.
cjsporl1996 is offline   Reply With Quote
Old 05-06-2014, 02:36 PM   #4
wheelhaus
wheelhaus's Avatar
It's perfectly fine, but it's such a short gear that the synchro has work a little harder if you're moving at speed, which is why you feel more resistance than normal. The slower you're moving the more easily it will engage. Rev matching will help smooth clutch engagement and prevent a lurch, but does nothing for the synchros unless you double clutch.
DC isn't required, but can help get into first easier.
Old 05-06-2014, 02:41 PM   #5
hmmmm...... if you can get it into first while rolling without grinding....I reckon it will not hurt anything.
However, unless you are going up a steep hill, around a hairpin curve, on a gravel road, at 14,000 ft, with a loaded car .... I don't see any reason to downshift that far .....
Old 05-06-2014, 02:51 PM   #6
executivekoala
executivekoala's Avatar
Drives: fr-s
1st gear has hardened syncros from factory, they are made to take abuse. Also just rev match and you are fine
executivekoala is offline   Reply With Quote
Old 05-06-2014, 02:51 PM   #7
wparsons
wparsons's Avatar
Tight autoslalom turns is why, if you're down to like 30km/h it's going to bog like crazy in 2nd.
I find that you almost have to double clutch the rev match to make it go smoothly, and the faster you're going the more true that is.
flickr
The Following 2 Users Say Thank You to wparsons For This Useful Post:
codesplice (05-06-2014), humfrz (05-06-2014)
Old 05-06-2014, 03:45 PM   #8
swpbrz
I'm definitely not talking about forcing it in. if I get any resistance I try another throttle blip or settle on 2nd if I'm in traffic. But there does seem to be a very smooth way to get into first if you nail the rev matching. its just more finicky I think because first gear is so high strung feeling. So if your not within a couple hundred rpms of the sweet spot for your speed it feels crunchy. I try not to force it then.
Old 05-06-2014, 09:29 PM   #9
Turdinator
Señor Member
Turdinator's Avatar
Double de-clutching will make it even easier to do but you may find there is enough clutch drag that just rev matching is good enough. I do it all the time in my car and have done it in numerous other cars I have owned without issue.
1974 TA22 Celica
2013 86 GT
Old 05-06-2014, 09:30 PM   #10
vividracing
vividracing's Avatar
I was taught never to so I never really tried.
vividracing is offline   Reply With Quote
Old 05-06-2014, 10:41 PM   #11
JimmyMac
JimmyMac's Avatar
Drives: 2013 FR-S, 2016 Miata Club
Been doing it. I find it helps in tight corners as well where 2nd gear will bog when you get on it.
JimmyMac is offline   Reply With Quote
Old 05-07-2014, 12:45 PM   #12
radroach
Drives: car
Had no problem downshifting to 1st at my last AutoX, just downshifted like normal because I needed the extra power!
Old 05-07-2014, 09:28 PM   #13
Gilwith1l
Gilwith1l's Avatar
Drives: stock brz. saving my money for ls1
I really don't see the taboo in downshifting to first. Do it all the time with no issues
Gilwith1l is offline   Reply With Quote
Old 05-07-2014, 09:33 PM   #14
ZionsWrath
Thanks
ZionsWrath's Avatar
Just learn the tach for first gear and you won't have any problems. The only time I have problem with first is if the gearbox is cold but then I'm not trying to when its cold
6th to 5th Downshift Crunch jcat5150 Issues | Warranty | Recalls / TSB 1 04-17-2014 04:41 PM
Rough Downshift (bog?) from 3rd to 2nd... enwave Issues | Warranty | Recalls / TSB 8 08-29-2013 01:01 PM
Downshift rattle?? driftartist Issues | Warranty | Recalls / TSB 17 08-03-2013 11:00 AM
Thump happened on downshift into 2nd husker741 Issues | Warranty | Recalls / TSB 11 07-19-2013 01:07 AM
transmission noise (when going to downshift) Hotlava86 Issues | Warranty | Recalls / TSB 5 09-03-2012 11:04 PM
