Old 05-06-2014, 12:06 PM   #1541
Deadspool
Much title. Wow.
Deadspool's Avatar
Drives: 2013 BRZ Sport-Tech
My overflow is indeed low.
I can smell it strongly as the rad fans are spinning up. The turbo is oil cooled, so as far as modification to the cooling system, only a relocation bracket for the overflow tank.
Poking my head around above ground, the only strangeness I saw was a few droplets on the drivers side lower rad support. When the car cools down, i will verify its origin.
༼ つ ◕_◕ ༽つI PUT A SPELL ON YOU ༼ つ ◕_◕ ༽つ
Deadspool is offline   Reply With Quote
Old 05-06-2014, 12:08 PM   #1542
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
How are your cooling fans mounted? Any chance one of the zip ties has worn through the radiator core and damaged it?
Old 05-06-2014, 12:10 PM   #1543
Deadspool
Much title. Wow.
Deadspool's Avatar
Thats pretty much exactly what I was thinking! The ones towards the turbo are fine, I will have to take the bumper cover off and inspect the other mounts.
mounted with the slim fan kit that came with.
Old 05-06-2014, 12:12 PM   #1544
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Yeah I damaged my OEM radiator when I removed those to install my Full Blown radiator. It doesn't take much strain or a slightly wrongly placed zip tie to wear through. With that being said I have had a slim fan mounted with those on my racecar for 5 years now with no issues.
Old 05-06-2014, 12:15 PM   #1545
Deadspool
Much title. Wow.
Deadspool's Avatar
Truth, all my previous cars having slim fans posed no issues.
Seems replacing this rad is unavoidable, be it overheating issues, or frailty. I will know for sure tomorrow morning. Preparing the car for a 5500km drive across country, a fine time to have coolant issues.
Old 05-06-2014, 12:20 PM   #1546
King Tut
NASA SpecE30 Racer
King Tut's Avatar
I wouldn't even justify calling it a radiator. It is really an A/C condensor that they decided to use as a radiator. It is the thinest frailest radiator I have ever seen.
The Following 3 Users Say Thank You to King Tut For This Useful Post:
Deadspool (05-06-2014), shiro (05-07-2014), Sportsguy83 (05-06-2014)
Old 05-06-2014, 12:21 PM   #1547
Deadspool
Much title. Wow.
Deadspool's Avatar
haha! I thought the exact same thing when I first saw it.
Old 05-06-2014, 01:41 PM   #1548
blackfireball5
blackfireball5's Avatar
Drives: Scion FRS Firestorm
Soooo, I can smell coolant in my engine bay, but my exhaust is clean as a whistle.
Almost smells as though it is coming from the radiator. But its not consistent.
Check your coolant line going to the turbo. I just experienced a leak there this past weekend. About 3 or 4 pages back i posted pictures. Tube was brittle where it met the AN fitting. Just a suggestion. It started as a slow undetectable leak and kept getting worse.
Wheelwell Profile
Use code TWW-BOO5TED when shopping at Wheelwell to receive 10% off your order.
blackfireball5 is offline   Reply With Quote
Old 05-06-2014, 01:53 PM   #1549
pmccut
Drives: Blue Subarus
Originally Posted by Reaper View Post
Why did you go with 9:1? You could have made more power on a stock bottom end.
Sent from my SAMSUNG-SGH-I747 using Tapatalk
I wanted to make more power on CA91 fuel. I have E85 nearby but anytime I take a trip or any track I'd frequent is only going to have 91 fuel. @FullBlown tuned the car to 353whp on 91, and after seeing the many posts about the GTX3076R (my housing is .63) and similar sized turbos making excellent numbers, I decided to make the switch.
Originally Posted by sales@delicioustuning.com View Post
It could be a great many factors weighing in here. For one, given the same conditions and just changing compression, the lower compression motor will always make less power. That said, his motor is actually slightly lower compression than yours at 9:1 vs 9.5:1. Not sure if that is really such a huge factor with such a minute change. Where they both may be 91 octane, CA 91 performs much closer to an 89 from every other state here in the US. Not only that, your turbo is actually the larger of the two if we're looking at wheel size here. Your PTE5858 uses a 58mm inducer vs his 51, and 58mm turbine wheel vs his 54. I don't know where this larger turbo statement came from. Moral of the story here is there are far too many fine details to consider and no reason at all to point fingers. If pmccut wants to make more power now he is more than welcome to come back and we'll swap in the larger injectors. When Bill says the larger injectors sacrifice a bit of drivability, that's the perfectionist side of him talking. You or I would likely not notice a hit in that area at all, and instead be enjoying all the extra power to be gained.
Sincerely,
Zach
When we had the same size turbo, on the same fuel, at the same boost levels, same tuner, same dyno, with slightly different compression, we made about the same power.
Where are you seeing 51 for the inducer wheel? The GTX3076R shows 58 as well. Turbine wheel is 60mm. The turbo sizes are basically the same from what I can tell, so we should have very similar results. I think I'm just limited by the port injectors, but Bill hasn't specifically said that.
'13 GBS BRZ 6MT | FBM 9:1 w/ GTX3076R| FBM oil cooler + catch-can + radiator + SPAL fans| Rays 57xtreme / PSS | Perrin 2.5" FP | Invidia 2.5" OP | Perrin 3" CBE | RCE T2s | Exedy Stg1
'15 STI LE | Cobb Stg1
pmccut is offline   Reply With Quote
Old 05-06-2014, 02:01 PM   #1550
King Tut
NASA SpecE30 Racer
King Tut's Avatar
His turbo isn't water cooled, just oil cooled.
The Following 2 Users Say Thank You to King Tut For This Useful Post:
blackfireball5 (05-06-2014), Deadspool (05-06-2014)
Old 05-06-2014, 02:05 PM   #1551
blackfireball5
Whoops, never mind.
Old 05-06-2014, 02:06 PM   #1552
blackfireball5
Haha, I just noticed the tags on this thread... Made me lol.
Old 05-06-2014, 02:52 PM   #1553
DeliciousTuning
PhoneFlash by EcuTeK
DeliciousTuning's Avatar
I was looking at your tag for the gt28, didn't realize you had upgraded to the gtx3076r. Essentially that's exactly what's happening with the port injectors. That said I wasn't there and don't know the full extent of your build, and I'll talk to Bill later about it. Keep in mind a bigger turbo at the same boost is going to push much more air and if the injectors can't flow the fuel to match, you won't make as much power. Plain and simple. We may have misinterpreted your needs as far as the balance between drivability and outright power, and do invite you to pm us so we can work it out and get you to a point where you are more than happy with your tune and the power.
Sincerely,
Zach
The Following User Says Thank You to DeliciousTuning For This Useful Post:
pmccut (05-06-2014)
Old 05-06-2014, 03:08 PM   #1554
jamesm
IMHO there should be no balance between drivability and outright power. Nothing about aftermarket injectors necessitates subpar drivability. Not trying to be an ass or anything, but people shouldn't take that impression away from this thread. Calibrated properly, you absolutely can achieve better-than-stock drivability with anything up to 1000cc injectors (never tried larger). @Sportsguy83 how's your drivability on 1000s?
The Following 4 Users Say Thank You to jamesm For This Useful Post:
Dipstik-sportech (05-06-2014), pmccut (05-06-2014), Reaper (05-06-2014), Sportsguy83 (05-06-2014)
best company ever, big fuck off turbo, blown, bow chicka wow wow, fbm, full, owners, powaaaaaa!, thread, will work for turbo
AVO Turbo Kit Owners Topic Sportsguy83 Forced Induction 1935 02-20-2023 10:46 AM
Full Blown FRS/BRZ Stage 1 Turbo Kit FullBlown Forced Induction 456 09-27-2021 03:10 AM
FA20Club Turbo Kit Owners Topic pixel67 Forced Induction 1531 09-09-2014 12:36 PM
Full Blown Turbo Kit! Unleashed Engine, Exhaust, Bolt-Ons 70 10-09-2013 09:46 AM
WTB: Full Blown turbo kit (used) whitefrs Engine, Exhaust, Bolt-Ons 12 03-29-2013 09:15 PM
