Old 05-06-2014, 01:35 AM   #1
SubaSteve
Captain Cocoa
Drives: CBS BRZ MT
Drive-ability Issue
I recently had an alignment done which was supposed to fix some of the issues I was having but now I have more problems....
When I get on the throttle the car wants to pull to the left, I mean changing lanes pull to the left. The car feels like its also dragging abit and I have to use a tad more throttle to keep it at a constant rate of speed.
Recent list of things done to the car.
-SS Brake lines
-Anti dive kit
-front roll center correction kit
-camber bolts
-rear control arm camber correction kit
I had issues with the anti dive kit which I replaced a part that was causing it to shift the lca forward. But for the most part I can't pinpoint the issue.
SubaSteve is offline   Reply With Quote
Old 05-06-2014, 01:37 AM   #2
gramicci101
Off Topic
Do you have the results of your alignment?
Old 05-06-2014, 07:55 AM   #3
wparsons
wparsons's Avatar
^^ This, without knowing the outcome of the alignment it's just wild guesses in the dark.
flickr
Old 05-06-2014, 09:53 AM   #4
SubaSteve
Captain Cocoa
Drives: CBS BRZ MT
Old 05-06-2014, 10:01 AM   #5
stugray
Drives: 2013 GBS BRZ Limited
Your description sounds almost as if the VSC is trying to compensate for something with the "electronic LS diff" type of behavior.
No chance the VSC lights are blinking as it does this?
Other people have had issues after suspension or brake work because the traction control sensors (wheel speed sensors) were upset or damaged.
Old 05-06-2014, 10:04 AM   #6
SubaSteve
Captain Cocoa
Drives: CBS BRZ MT
This was the alignment I got before I fixed the problem with the anti dive kit. The front drivers side is where the issue was.
Old 05-06-2014, 10:07 AM   #7
SubaSteve
Captain Cocoa
Drives: CBS BRZ MT
I'm going to go swap the two front tires and see if it still pulls to the left.
Old 05-06-2014, 10:20 AM   #8
wparsons
wparsons's Avatar
It's not the TC/VSC unless you're getting wheelspin or the slip indicator light is coming on. If any of the wheel speed sensors aren't working right for any reason the TC/VSC gets disabled since the ECU can't trust the sensors to work right.
When you did the brake lines did you also pull the calipers and pads? Are the pads binding in place and not releasing fully? Is the caliper sticking on the slider pins? I'm assuming you properly bled the system after replacing the lines (right rear, then left rear, then right front, then left front - for a LHD car)? Is the fluid level good?
flickr
Old 05-06-2014, 10:48 AM   #9
SubaSteve
Captain Cocoa
Drives: CBS BRZ MT
We did bleed the lines but I have a feeling that we did it wrong, and yes the fluid level is good. Just to factor the brakes out what would you suggest I do if I did it wrong.
Old 05-06-2014, 10:51 AM   #10
wparsons
wparsons's Avatar
If you didn't pull the pads off the car in the process, chances are they aren't snagging in their mounts unless they were before as well.
If there is too much air in the lines it might cause the pads to drag a bit, but I would think you would feel a VERY soft pedal before that would happen.
flickr
Old 05-06-2014, 10:56 AM   #11
SubaSteve
Captain Cocoa
Drives: CBS BRZ MT
Just finished swapping the two front wheels and it still pulls to the left under acceleration. The thing that's driving me nuts is the fact that it goes in a straight line with 0 throttle.
Old 05-06-2014, 11:02 AM   #12
SubaSteve
Captain Cocoa
Drives: CBS BRZ MT
Could one of the rear brakes be causing this?
Old 05-06-2014, 11:26 AM   #13
ZDan
ZDan's Avatar
Drives: '23 BRZ
Swap rear tires left/right. Direction of pull changes => bad tire.
You have checked the pressures, right?
Old 05-06-2014, 11:36 AM   #14
SubaSteve
Captain Cocoa
Drives: CBS BRZ MT
Checked the front and swapped those going to try the rears now.
ecutek ability to adjust to different % of E85 Mars2 Software Tuning 2 12-15-2013 01:04 PM
How do you judge your driving ability? CSG Mike Tracking / Autocross / HPDE / Drifting 50 07-09-2013 01:06 PM
BRZ Audio Unit - Flash Drive (USB) & indexing issue Space Boy Matt Electronics | Audio | NAV | Infotainment 3 12-08-2012 10:29 PM
BRZ Stock Audio Video System / USB Drive Issue Space Boy Matt Electronics | Audio | NAV | Infotainment 0 10-23-2012 01:19 PM
Corner entry ability hotaka Scion FR-S / Toyota 86 GT86 General Forum 24 08-18-2012 09:27 AM
