Sam Strano
Old 04-30-2014, 03:56 PM   #1093
jprice130
AutoX Nut
Drives: 2020 Toyota Supra
Originally Posted by Rexpelagi View Post
Awesome thanks!
I know it has been discussed before but what are people's thoughts on the 245/40R17 Rival vs. The 235/40R17 ZII? I'm a big fan of the ZII, but the potential for free tires vs. nothing has an appeal...
Did you happen to catch SeanRTR's build thread further down the page? Here's the link to page 2: http://www.ft86club.com/forums/showt...t=41955&page=2
He's running staggered BFG Rivals (Front: 225/45; Rear: 245/40). The 245/40 Rivals on the rear didn't seem to slow him down at the Wilmington Match Tour. Not sure how 245/40 Rivals would feel on the front, but it might be worth a shot! Especially for contingency purposes.
Edit: Upon further review, it appears you were there with him in your RX-8, so you may already know all of this....ha, ha!
jprice130 is offline   Reply With Quote
Old 04-30-2014, 04:30 PM   #1094
xwd
Originally Posted by 7thgear View Post
To DWX: Are the MCS dampers monotube? Did they come with their own bumpstops or you had to re-use yours? Do they have internal bumpstops?
They are monotube shocks. They do not have internal bumpstops. I ran them last year with no bumpstops. I used the ziptie trick every course on all four corners using 245/40/17 Hoosier A6s. It's not difficult to do that with the stock shocks, just have to remove the dust boots.
The MCS shocks I'm sure use more nitrogen pressure than stock so the effective spring rate is higher. I ran them around 115 PSI cold.
Old 04-30-2014, 04:35 PM   #1095
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
well yes, you can run them without bumpstops, there is roughly 3" of theoretical shaft
travel, which given my previous math would require roughly 700lb of weight transfer to use up (highly unlikely in a controlled environment)
the question was how often they are engaged?....
also, what was the highest that the ziptie moved from the base of the damper after a day of driving?
Old 05-02-2014, 11:49 PM   #1096
cactus
cactus's Avatar
Drives: 13 SWP BRZ
To those running the 245/40R17 size - do the tires clear the suspension with +48 wheels or do you need +42?
Yeah, they clear with the stock rims, ZII, and crash bolts.
I thought I heard some rub at lock when I first put them on, but didn't notice it again after ~250 street miles and 12 autox runs. /shrug
cactus is offline   Reply With Quote
Old 05-05-2014, 12:04 PM   #1097
G_Ride
G_Ride's Avatar
Drives: Some kind of Subaru
My co-driver and I finally got to try our 245/40/17 RS3 Version 2 this weekend. It was 70-71 degrees, sunny, and VERY WINDY (the ground stayed cold). Tire temps reached about 105 degrees at most, but there was still a lot of grip. We found the tires pretty responsive, too. We still need to make more adjustments now that we have A LOT more lateral grip. Overall, we were happy we went this route
G_Ride is offline   Reply With Quote
Old 05-05-2014, 05:17 PM   #1098
itzmik3
DBC Racing
itzmik3's Avatar
how did you feel the "cold" runs were? they are supposed to be better out of the box compared to before. just wanted to get your thoughts
thanks!
#194 SM
itzmik3 is offline   Reply With Quote
Old 05-05-2014, 07:24 PM   #1099
vroom4
If anyone is needing B6s or Koni Yellows, now is the time. Both are running really good sales. You can message me for more details.
I went with the konis because Im cheap, looking back, shouldve done the B6 probably.
vroom4 is offline   Reply With Quote
Old 05-05-2014, 08:21 PM   #1100
G_Ride
G_Ride's Avatar
thanks!
I've never driven on the old compound before since before this car I was a single driver and always has Star Specs/Z2's. My co-driver has driven on the old compound. Both of us felt there was good grip when cold. My co-driver said there's definitely more grip in the Version 2's cold and we'd have been sliding around on the old compound. It helped to daily the tires for a bit before the event to scrub the tires.
The Following User Says Thank You to G_Ride For This Useful Post:
itzmik3 (05-05-2014)
Old 05-06-2014, 11:58 AM   #1101
chucky12012
Drives: 2013 Asphalt Scion FR-S
I have uploaded my full video of the Sunday morning runs at the Mineral Wells pro solo this past weekend. I think Drew does a good job in the background with the announcing to help tell the story of the come from behind win in CS.
[ame]http://youtu.be/t_s5WIAnVLo[/ame]
chucky12012 is offline   Reply With Quote
The Following 4 Users Say Thank You to chucky12012 For This Useful Post:
autoXracer (05-06-2014), Biggins (05-08-2014), DylanFRS (05-06-2014), itzmik3 (05-06-2014)
Old 05-06-2014, 10:24 PM   #1102
autoXracer
Drives: 2013 WRB BRZ
Congrats! Well deserved after the car trouble you had at Texas Championship Tour last March. Good job also considering that you were up against the 370Z that won C-Stock Nationals last year (driven by its new owner).
autoXracer is offline   Reply With Quote
The Following User Says Thank You to autoXracer For This Useful Post:
chucky12012 (05-06-2014)
Old 05-06-2014, 11:13 PM   #1103
engee
Drives: Subaru
Here are my runs from the NJ Championship tour. I drove horribly on day 1 going too hot into some sections.
I was able to clean it up on day 2 but still could not get close to the Mark Andy. Still have a lot to learn to be able to drive faster.
Day 1:
[ame="https://www.youtube.com/watch?v=reOv9AmFHqM"]NJ Championship Tour - Day 1 #67 CS - YouTube[/ame]
Day 2:
[ame="https://www.youtube.com/watch?v=unu8gQwB0rg"]NJ Championship Tour - Day 2 #67 CS - YouTube[/ame]
engee is offline   Reply With Quote
Old 05-08-2014, 05:23 PM   #1104
Getagrip
Getagrip's Avatar
Drives: SWP BRZ
I'm clearing with OEM wheels and OEM crash bolts with ZIIs 245/40-17.
I was also clearing with Rota 17x8 +48 and crash bolts and same tires.
SWP BRZ
Getagrip is offline   Reply With Quote
Old 05-23-2014, 12:30 AM   #1105
Kido1986
Dodging cones
Kido1986's Avatar
Drives: 2013 BRZ Limited, 93 Z28
Calling @Sccabrz192
Googling some shirts,I found this - http://www.redbubble.com/people/thej...rid&style=mens
Interesting story behind this?
Originally Posted by trevorovert View Post
Originally Posted by mrbillclintong View Post
If you guys spot any riced frs/brz post them here just for laughs no hating please.
Isn't there already a thread like this? It's called aggressive wheels or summat...
C Street Build/Progress Questions about C Street Autocrossing?
Kido1986 is offline   Reply With Quote
Old 05-23-2014, 09:03 AM   #1106
Sccabrz192
Detroit Region, MI
Sccabrz192's Avatar
Drives: 13 BRZ, 13 Volt, 02 WRX
Originally Posted by Kido1986 View Post
Calling @Sccabrz192
This one is better:
http://www.redbubble.com/people/thej...rk_portfolio_1
And no, not really. Just an idea... taken to the next level about 15 different times over beers. Apparently this infinity shirt thing is a trend now??
You should definitely buy one and wear it to the Toledo Pro.
Detroit / NWOR SCCA Member
2005-06: #192 ES 91 MR2 N/A Hardtop
2007-08: #54 STX 05 WRX Sedan
2009-12: #92 BSP/ASP 07 Solstice GXP
2013-14 : #192 CS 13 Subaru BRZ
Sccabrz192 is offline   Reply With Quote
Cinco De Mayo SCCA SOLO Ryeong86 NY / NJ / CT / PA 0 04-23-2013 06:22 PM
Koni Sports in SCCA SOLO Ryeong86 Tracking / Autocross / HPDE / Drifting 4 04-22-2013 01:58 PM
2013 Preliminary SCCA SOLO and PRO SOLO National Schedule Scooby South Tracking / Autocross / HPDE / Drifting 13 12-05-2012 09:08 AM
Houston SCCA Solo #9 - 5 FRS, 1 BRZ hankster Tracking / Autocross / HPDE / Drifting 0 10-09-2012 02:35 PM
SCCA Solo Car Class for the FR-S/BRZ? MrVito Scion FR-S / Toyota 86 GT86 General Forum 31 06-15-2012 11:03 AM
