#1079 | |
Drives: 2024 GR86/ 2015 FRS
I like how early you turned in for everything,....just need to find a way to get rid of the understeer now. Simmons
2024 GR86 71 STR/ 2015 FRS 71 STX
Sponsors Xero-Limit//Karcepts |
#1080 |
Im fighting the same animal. Im turning in early, which leads to a slightly early apex, which leads to push on corner exit.
Just need to pound it in my brain to carry a little deeper into the corner before braking I guess. |
#1081 |
Drives: 2013 Subaru BRZ
To those running the 245/40R17 size - do the tires clear the suspension with +48 wheels or do you need +42?
-John L.
2011 BMW M3 - 57 FS 2007 Ford SGT - 57 FS 2013 Subaru BRZ - Sold |
#1082 | |
i'm sorry, what?
Drives: Canada
talk to yourself when coming up to the key turns "wait for it, wait for it, wait for it",
#1083 |
Drives: Whiteout FRS- autocross ready
In most cases- late apex, late apex, late apex.
#1084 | |||
i'm sorry, what?
Drives: Canada
To DWX: Are the MCS dampers monotube? Did they come with their own bumpstops or you had to re-use yours? Do they have internal bumpstops? To AustinTX, you say “opinions”, this is not a matter of opinion, this is a matter of simple math. There is only one answer. I decided to take a step back from the discussion because, admittedly, I did not have my own empirical evidence, but a few weeks ago, as a prerequisite for a side project, I took apart the rear OEM coilover and re-installed the damper sans spring and dust boot and then leveling the car to its OEM height (reference measurements of which were taken before) My measurements indicate roughly 3/8” of free travel before bumpstop engagement. Drawing from the available info on spring rates and motion ratios, we’re dealing with around 240lb/in of spring resistance to movement That means that the rear corner can only handle roughly 90lb of weight transfer before the progressive bumpstop becomes an integral part of the spring rate calculation. Merely getting on the gas really hard is enough to do this, and is also why the car with a suitcase in the trunk and a person or two in the back handles noticeably different than when you’re alone... and why the SCCA rules would prohib them being longer. I've yet to do the front of the car but from my personal experiences with MacStruts (VW's and Imprezas) i'm not expecting to be surprised by inches worht of free travel. I predict around 3/4 at the very most. If my measurements are incorrect then please point to a possible error in my procedure. But at this time i'll revert back to my statements that you are in fact engaging your bumpstops to some degree quite often, even during a daily drive.
| The Following User Says Thank You to 7thgear For This Useful Post: | Shankenstein (05-06-2014) |
#1085 | |
The Stig's German cousin
My first reaction was "hey, we actually get more spring rate out of the car than we thought!" ![]() But really, do you think we should be cutting the bump stops and by how much? I'm personally happy with how the car drives, I'm hesitant to go try and fix it 'til it's broken. |
#1086 |
AutoX Nut
Drives: 2020 Toyota Supra
I haven't tried any of the street tire offerings in 245/40, but back in 2012 I ran 245/40 Hoosier A6s on the stock wheels and did not have an issue with inbound clearance. It was close up front, but it still cleared the spring perch just fine (this was with the OEM crash bolts too). Might not hurt to keep some 3mm slip-on spacers handy for the front just in case.
| The Following User Says Thank You to jprice130 For This Useful Post: | Rexpelagi (04-30-2014) |
#1087 | |
i'm sorry, what?
Drives: Canada
bumpstops are often cut to facilitate lowering springs, whose spring rate would be overriden entirely by compressed bumpstop approeaching infinity. but i was merely showing support that bumpstops in general are an integral part of most modern suspension systems. A lot of people still seem to think as "bumpstops" as the hard stop that prevents damper bottoming and that the only time they hit the bumpstops is when they "BANG"... when the fact is that when they BANG is when both the spring and the bumpstop are overloaded into infinity at a super rapid rate and the shock is transfered directly into the chassis of the car. for all practical purposes, the FRS comes stock with a "progressive roll resistance" mechanism that comes in the form of the 2.5" bumpstop (in the rear anyway.. i haven't gotten the front)
| The Following 2 Users Say Thank You to 7thgear For This Useful Post: | renfield90 (04-30-2014), Shankenstein (05-06-2014) |
#1088 | |
Drives: Some kind of Subaru
#1089 |
Off Topic
How does ECU tuning play into the CS class rules? For instance, an OFT stage 1 flash.
Also, I saw that suspension bushings are not allowed; what about drivetrain bushings such as the shifter, transmission insert, rear subframe, and diff lock collar bushings? I'm not concerned with what class I end up with, because I'll be there to learn and have fun, not beat everyone else. But I should probably know what to tell them when I get there, so I don't look completely clueless. |
#1090 | |
i'm sorry, what?
Drives: Canada
if a mod is not on there, that means you can't do it and even a single non authorized mod will bump you up.
| The Following User Says Thank You to 7thgear For This Useful Post: | gramicci101 (04-30-2014) |
#1091 | |
DBC Racing
even on full lock and a big tire such as the yokohama
#194 SM
| The Following User Says Thank You to itzmik3 For This Useful Post: | Rexpelagi (04-30-2014) |
#1092 |
Awesome thanks!
I know it has been discussed before but what are people's thoughts on the 245/40R17 Rival vs. The 235/40R17 ZII? I'm a big fan of the ZII, but the potential for free tires vs. nothing has an appeal...
-John L.
| Cinco De Mayo SCCA SOLO | Ryeong86 | NY / NJ / CT / PA | 0 | 04-23-2013 05:22 PM |
| Koni Sports in SCCA SOLO | Ryeong86 | Tracking / Autocross / HPDE / Drifting | 4 | 04-22-2013 12:58 PM |
| 2013 Preliminary SCCA SOLO and PRO SOLO National Schedule | Scooby South | Tracking / Autocross / HPDE / Drifting | 13 | 12-05-2012 08:08 AM |
| Houston SCCA Solo #9 - 5 FRS, 1 BRZ | hankster | Tracking / Autocross / HPDE / Drifting | 0 | 10-09-2012 01:35 PM |
| SCCA Solo Car Class for the FR-S/BRZ? | MrVito | Scion FR-S / Toyota 86 GT86 General Forum | 31 | 06-15-2012 10:03 AM |
