Old 05-04-2014, 07:21 PM   #407
CSG Mike
CSG Mike's Avatar
Question. The air filter. When I want a new one what do I get. I had everything written down but my kid threw it out by accident. To lazy to search
It's a cleanable filter, but if you really want a new one, you can order one using the part number mentioned above.
sklimo (05-05-2014)
Old 05-05-2014, 02:50 AM   #408
Poodles
Drives: 2015 Series.Blue
Originally Posted by normancw View Post
Thanks!
No I didn't - the TF backing plate moves the hub outwards a bit.
It would have moved the rotor out a bit, relative to the caliper. The new brake pads are a tight fit and I wasn't sure if they would fit if the rotor wasn't aligned with the caliper.
Instead, I used the passenger side APR brake duct to route air towards cylinder #1, to cool coilpack 1. Maybe this will help prevent coilpack 1 failures
Could space the mounting bracket the same distance from the spindle.
Originally Posted by ATL BRZ View Post
That first pic looks familiar!
I've had no issues fitting new pads on my stock calipers/rotors with the same thickness backing plates.
I doubt you'd have issues with pad fitment with the backing plate installed and if you did, you could always shave the pads down a bit...
Wouldn't do that. Stock brakes are floating, he's got a radial mounted caliper.
The Following 2 Users Say Thank You to Poodles For This Useful Post:
ATL BRZ (05-05-2014), CSG Mike (05-05-2014)
Old 05-05-2014, 09:09 AM   #409
Liebot
Liebot's Avatar
Has anyone posted an optimal build of supporting mods with this kit? I'm sort of a "put everything on my car all at once" kinda guy.
Liebot is offline   Reply With Quote
Old 05-05-2014, 09:31 AM   #410
ATL BRZ
TEQSPORT Brand Manager
ATL BRZ's Avatar
Drives: '24 GR86 + '16 FR-S
So did @Touge Factory not do any pre-production testing on their backing plate for the AP rotor to see if the pads would fit correctly knowing the differences in the way the calipers are mounted? They just fabbed it up and sent it straight to you without fitting it on a shop car first to ensure it works correctly without modification? Seems strange and uncharacteristic of the guys at TF Works.
Sorry for going off-topic... I really want this to work for you without much headache. Maybe that's why the Endurance BBK exists
Old 05-05-2014, 02:51 PM   #411
CSG Mike
CSG Mike's Avatar
@normancw: If your brakes are not overheating without ducts, then don't put on the ducts.
The ducts are a "hack" to bring the equilibrium temperature down, but it comes at the cost of larger, more frequent temperature swings. The temperature swings are what cause rotors to crack earlier.
Old 05-05-2014, 02:52 PM   #412
CSG Mike
CSG Mike's Avatar
"optimal" is subjective.
What's your budget for supporting mods on top of the kit + tune?
I can certainly point you in the right direction.
Sportsguy83 (05-05-2014), Xerious (05-05-2014)
Old 05-05-2014, 04:16 PM   #413
gbrz
ah the wait is killing me
gbrz is offline   Reply With Quote
Old 05-05-2014, 04:38 PM   #414
Xerious
Speed Chaser Thrill Seekr
Xerious's Avatar
Drives: 2014 Asphalt Monogram FR-S 6MT
Love to hear your recommendations Mike.
Sent from my SAMSUNG-SM-N900A using Tapatalk
Performance: Jackson Racing SC & Oil Cooler, 18x9.5 Gram Lights 57Xtreme Wheels, 255/35 Yokohoma Tires, Rays Volk Racing Black 17hex 12x1.25 lugs, KW V3 C/O, Stance Control Arms
Exterior: LED DRL MOD Kit, Tom's Tail-lights, 5%/40% tint
My Build
Xerious is offline   Reply With Quote
Old 05-05-2014, 04:41 PM   #415
CSG Mike
CSG Mike's Avatar
You haven't seen any updates on the CSG BRZ because we've been toying with supporting mods to see what works, but we don't expect to be done for another ~6 months or go. We want to do some heavy stress testing in the summer months.
Old 05-06-2014, 11:17 AM   #416
sdlynx
sdlynx's Avatar
Drives: 2013 Scion FR-S - Firestorm
Just finished installing my kit. It went fairly smoothly. While I've installed Superchargers and other FI kits to other people's cars, I've not done my own until now. Funny how, when it is your own car, you become a little more paranoid than usual.
sdlynx is offline   Reply With Quote
The Following 4 Users Say Thank You to sdlynx For This Useful Post:
*LongFella (05-06-2014), CSG Mike (05-06-2014), CxG (04-03-2018), tahdizzle (05-09-2014)
Old 05-09-2014, 12:49 PM   #417
bacon_cheese_beer
bacon_cheese_beer's Avatar
Drives: Fr-S
About 98% done! 16 hours in wish me luck guys
"mr.Balloon hands, no way, get real..."
bacon_cheese_beer is offline   Reply With Quote
The Following 4 Users Say Thank You to bacon_cheese_beer For This Useful Post:
*LongFella (05-09-2014), JonAvalon (05-09-2014), sklimo (05-09-2014), spitz (05-09-2014)
Old 05-09-2014, 12:54 PM   #418
sklimo
:cheer s:
bacon_cheese_beer (05-09-2014)
Old 05-09-2014, 12:57 PM   #419
*LongFella
*LongFella's Avatar
Drives: 2014 Scion FR-S|Whiteout
The pipe coming from your MAF to the intake manifold looks different???
Is that the right part?
Mines a rubber hose and that looks like it's metal and powder coated black???
My 2014 FRS build thread: http://www.ft86club.com/forums/showthread.php?t=52071
“You might be poor, your shoes might be broken, but your mind is a palace.” - Frank McCourt
*LongFella is offline   Reply With Quote
Old 05-09-2014, 12:59 PM   #420
*LongFella
*LongFella's Avatar
Here's what mine looks like:
The Following 3 Users Say Thank You to *LongFella For This Useful Post:
CxG (04-03-2018), ramiram1984 (05-09-2014), sklimo (05-09-2014)
Jackson Racing Rotrex Supercharger System Info and Discussion Jackson Racing Forced Induction 827 04-06-2020 04:56 PM
Jackson Racing Supercharger Press Release and Info CounterSpace Garage Forced Induction 110 01-03-2017 09:04 PM
jackson Racing engine oil cooler - modular to fit the Jackson Racing Supercharger! CSG Mike Forced Induction 24 04-27-2016 12:59 PM
Jackson Racing supercharger NoppyNop Forced Induction 241 06-26-2014 03:05 PM
Jackson Racing Supercharger Pre-Order Sale, $200 off! Xero-Limit Forced Induction 2 03-05-2014 04:14 PM
