#15 |
Drives: ZC6, Junk of ALL sorts
# 1. Always know where your towel is.
ZC6-CBS, is home |
#16 |
Drives: 2013 FRS / 2013 427 Vert
I would stop driving it while there is still a chance that the problem is top end only.
[SIGPIC][/SIGPIC]
2013 FR-S Asphalt BC Coils/Rev Works UEL header/HKS Front Pipe/Racing Brake BBK/Shorai LW Battery/ACT 6 Puck Clutch/FBM Radiator & Oil Pan/JR Oil Cooler/Jackson Racing High Boost C30/Rev Works Built Motor 2016 Audi TTS APR Tuned |
#17 |
Drives: 2014 Scion FR-S Monogram Series
P0011 is likely related to a variable valve timing cam gear problem. I have heard of some of the earlier engines having issues with the cam gears, some even getting engine swaps due to failures. Good luck with a warranty!!!
#18 | |
Drives: 2015 WRX
And people wonder why dealerships can be such a pain when dealing with legitimate warranty claims. Don't be a dirt bag. |
| The Following 22 Users Say Thank You to Malt For This Useful Post: | ATL BRZ (05-06-2014), chas3wba0 (05-07-2014), CK_Bladesmith (05-06-2014), Creole (05-05-2014), dawnst3ar (05-05-2014), Exhaust (10-11-2014), funwheeldrive (05-06-2014), illmatic (05-05-2014), jamesm (05-05-2014), Jyn (05-05-2014), Luis_GT (05-05-2014), Marchy (05-12-2014), mav1178 (05-05-2014), Mister (05-05-2014), NickFRS (05-06-2014), Pseud0logik (05-05-2014), Rampage (05-05-2014), raul (05-12-2014), strat61caster (05-05-2014), Tcoat (08-22-2014), XanRules (05-05-2014), xxscaxx (05-05-2014) |
#19 |
Drives: 2013 SWP BRZ
My advice:
Learn from your mistakes. Get new motor and pay out of pocket. These are things EVERY owner should be prepared for when throwing boost at a motor not meant for it. It was YOUR choice to put a turbo kit on it. Even if you pull the kit off, the dealer can still see you flashed your ECU, and will just most likely deny you anyway. If my motor blew tomorrow I would not try to get the dealer to fix it unless they were willing to with my current setup. If people aren't willing to gamble, they should never touch this car with F/I. |
| The Following 6 Users Say Thank You to xxscaxx For This Useful Post: | ATL BRZ (05-06-2014), Dipstik-sportech (05-05-2014), Rampage (05-05-2014), Sportsguy83 (05-05-2014), strat61caster (05-05-2014), XanRules (05-05-2014) |
#20 |
heres a TSB relating to the P0011 code and cam gear issue...
2013 Subaru BRZ F4-2.0L DOHC Vehicle » Engine, Cooling and Exhaust » Engine » Technical Service Bulletins » All Technical Service Bulletins » Engine - AVCS DTC's Stored In ECM Memory
NUMBER: 02-132-12R DATE: 08/21/12 *REVISED: 01/21/13* APPLICABILITY: 2012 and Later Impreza and XV Crosstrek NA Models (FB Engine) 2013MY BRZ (FA Engine) 2013MY Legacy and Outback Models (FB Engine) 2011MY and Later Forester NA Models (FB Engine) SUBJECT: Diagnosis and Repair for AVCS-Related DTCs P000A, P000B, P000C, P000D, P0011, P0014, P0021 and P0024 INTRODUCTION This Bulletin provides a procedure for diagnosis and determination of necessary part replacement in the event any of the "AVCS Slow Response" or "AVCS System Failure" DTCs listed above are found to be stored in the ECM memory. A possible cause of these conditions is contamination within the camshaft sprocket and / or oil control solenoid valve (OCV) mechanism. COUNTERMEASURE IN PRODUCTION Countermeasures were incorporated into production during July, 2012 starting with the VINs shown. SERVICE PROCEDURE / INFORMATION NOTES : Only the Intake-related DTCs are applicable to Legacy, Outback and Forester models. *DTC P0011 and P0021 are applicable to Forester models only.* ^ Using the SSMIII, determine which DTC is stored. ^ Determine the location of the suspect component using the DTC List ^ Swap the Oil Control Solenoid Valves side-to-side (intake to intake or exhaust to exhaust, not between intake and exhaust on same side) following the procedure in the applicable Service Manual. NOTE : The o-ring and nylon backer ring on the OCV must be replaced prior to reinstallation as they both are one-time use items. ^ Clear the ECM memory. ^ Perform *the model-specific Drive Cycle or Inspection Mode procedure for the corresponding DTC as shown in the chart. ^ Follow the applicable procedure below for locating either Inspection Mode or Drive Cycle instructions to coincide with the reference chart. 1. For BRZ: Using the Service Diagnostics tab on the STIS home page, enter your vehicle search parameters (example: 2013 > BRZ). Next, using the DTC tab, enter P0021 for INTAKE-related DTCs or P0024 for EXHAUST-related DTCs. Select the applicable link from your search result (example: P0021: Camshaft Position "A" - Timing Over-Advanced or System Performance (Bank 2)). Follow the diagnostic outline down to TEST DRIVE (for Drive Cycle) information. 2. For All Other Models: Using the Service Diagnostics tab on the STIS home page, enter your vehicle search parameters (example: 2013 > Outback). Next, enter specific DTC into the search term box. Select the applicable link from your search result (examples: ENGINE (DIAGNOSTICS) (H4DO) > Drive Cycle > PROCEDURE or ENGINE (DIAGNOSTICS) (H4DO) > Inspection Mode > PROCEDURE).* DTC LIST Does the suspect component / problem location change to the opposite bank of the engine by resetting the applicable DTC? ^ YES- Replace the suspect OCV with a new part (including a new o-ring and backer ring). ^ NO- Replace the suspect camshaft sprocket with a new part. (It is not necessary to return OCVs to their original positions.) IMPORTANT : After any component replacement, perform the applicable *Drive Cycle or Inspection Mode procedure again* to confirm the repair. WARRANTY / CLAIM INFORMATION For vehicles within the Basic New Car Limited and/or Powertrain Warranty period, this repair may be claimed using the information shown. NOTE : These labor times include all the Drive Cycle or Inspection Mode procedures as needed and all SSMIII use. |
| The Following User Says Thank You to Haeb For This Useful Post: | Cross (07-06-2014) |
#21 | |
Drives: 2013 Whiteout Scion FR-S 6MT
#22 |
Drives: 2015 WRX
| The Following 3 Users Say Thank You to Malt For This Useful Post: |
#23 |
Drives: 2005 Toyota Camry
#24 |
Drives: 1997 Eagle Talon TSi AWD
Typically bad tunes with timing/fuel errors happening during cruise. There was a tooooner up here in Canada tuning EvoX at one point and blew 5 cars (needless to say he's out of business). 3 of the 5 cars blew during cruising for ultra lean conditions
| The Following 3 Users Say Thank You to Jason@DSG For This Useful Post: |
#25 | |
NASA SpecE30 Racer
- King Tut
Street/Track Car: 2006 Honda S2000 TT3 || Race Car: 1987 BMW 325is SpecE30 || Tow Vehicle: 2014 RAM 1500 EcoDiesel Sold Cars: 2012 BMW M3 || 2013 Subaru BRZ || 2012 Porsche Cayman R || 2009 Chevrolet Z06 || 2009 BMW M3 || 2004 BMW M3 || 2004 Nissan 350Z |
#26 |
Drives: Fast
Once you put FI on it is very easy to tell the car has been modified.
You can't fool the dealer. |
#27 | |
i'm sorry, what?
Drives: Canada
Pedal to the floor, boost gauge spinnin in circles and yo flo boards be flyin n shit, like, Doc and Marty better sit this one out cuz they never seen such powa
| The Following 2 Users Say Thank You to 7thgear For This Useful Post: | 4Running Daily (05-11-2014), mav1178 (05-05-2014) |
#28 | |
Drives: First SWP BRZ-L
First white BRZ in the country
![]() Limited SWP BRZ, 35% tint, clear bra, Nameless Performance downpipe, axelback, headers |
| CEL - Engine Blown!!!!!!! | rapidcars | Issues | Warranty | Recalls / TSB | 65 | 12-10-2014 09:32 PM |
| Transmission problems, oil leaks and detonation problems.. | turboviper | Issues | Warranty | Recalls / TSB | 4 | 06-18-2014 04:01 PM |
| BRZ Blown engine question | Mujen84 | Forced Induction | 118 | 04-02-2014 05:04 AM |
| Initial d blown engine | be6sti | Other Vehicles & General Automotive Discussions | 6 | 10-15-2012 09:16 PM |
| Engine problems | Gerri | Engine, Exhaust, Transmission | 2 | 08-14-2012 07:14 AM |
