Old 04-24-2014, 10:09 PM   #85
mike the snake
Any stronger aftermarket pressure plate will put extra loads on the crank bearings.
One thing we can do to help lower any possible crank walking is to use the clutch as little as possible, namely, don't sit at stop lights, in-gear, with the clutch pushed in for extended periods.
Old 04-25-2014, 08:35 PM   #86
mike the snake
I have a feeling that a lot of the issues people are having with trouble getting into 1st are mainly due to the clutch adjustment.
I think the dimensions might be slightly different, and when the ACT clutch is installed, it needs to be adjusted to engage further from the floor.
Mine is new, and my shop installed it, but didn't adjust anything, and the clutch began grabbing juuust off the floor. One hair lower and it would have shown the same signs of hard engaging gears.
My clutch was adjusted today, and it now engages normally.
Old 04-26-2014, 10:53 PM   #87
Dustin
Twin Screw You
Dustin's Avatar
Drives: 2013 Supercharged Whiteout FR-S
I installed mine today and have 2 issues. The clutch seems to be engaging at the very end of the stroke. Same characteristics as @mike the snake. Looks like an adjustment is needed. Also, when idling, if the clutch is engaged everything is fine. But if I'm in neutral and take my foot off the clutch there is a rattleing noise. I'll have to check on it to see if there as anything I installed incorrectly. Pretty sure I didn't but there's always that chance.
Dustin is offline   Reply With Quote
Old 04-27-2014, 03:41 AM   #88
kiichiro
corolla specs/GTR looks
Drives: ooh oooh pretty tail lights
How many of you guys with issues with your ACT have modified your clutch grab adjustment or hydraulics? I never modified either.
Modded and happy
SOLD THEM BOTH
Hers: 2007 987S
Mine: 2012 991S
That was fun, thanks Hachi
kiichiro is offline   Reply With Quote
Old 04-27-2014, 09:21 AM   #89
mike the snake
A lot of aftermarket clutches will chatter when in neutral. Do a search, you'll find many reports of noise. It's fairly normal.
Old 04-27-2014, 11:06 AM   #90
Dustin
Twin Screw You
Dustin's Avatar
I've read about the chatter before. This one just seems excessive although I've never heard the chatter personally so maybe it is the norm. I wasn't asking for anyone to diagnose my problem just giving my feedback on the ACT clutch. Thank you though for trying to help. I still plan on checking it out. I'd rather double check and it be the normal chatter than not check and it be something else.
Old 04-27-2014, 05:30 PM   #91
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
Normal, although mine only did it with the A/C on.
Old 04-27-2014, 08:42 PM   #92
Pneub
Drives: Dark Grey BRZ
Mine as well
Pneub is offline   Reply With Quote
Old 05-05-2014, 09:46 AM   #93
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Wasn't it in this thread people had spoken about having trouble getting into gears after their ACT clutch warmed up??
I've been having a little bit of problems with it when warmed up, and I'm fearing its the TOB.....
Old 05-05-2014, 10:11 AM   #94
mike the snake
Mine was close to not fully disengaging, but I adjusted the clutch tighter and it works perfectly now.
I've had TOB's go bad, usually, they die quickly once they start to go.
Any noise or grumbling when you push the clutch pedal?
Old 05-05-2014, 11:10 AM   #95
Sportsguy83
Drives: Limited BRZ
Yes, I'm getting the creaking noise with the pedal
Old 05-05-2014, 11:14 AM   #96
w00t692
Drives: 2008 Civic Si
Whatever you do, don't preload the clutch pedal. There's a bypass valve built into the master cylinder that releases pedal pressure. If you adjust too much and there's no freeplay in the pedal you will get "pedal pump up" which is where it doesn't allow the pressure to subside, resulting in a clutch that's basically halfway depressed ALL THE TIME.
The way to check is to make sure the slave cylinder can be depressed when your clutch pedal is at resting state.
w00t692 is offline   Reply With Quote
Old 05-05-2014, 11:34 AM   #97
Sportsguy83
Drives: Limited BRZ
And this happens when you adjust the clutch to grab really low correct?
Old 05-05-2014, 11:48 AM   #98
enjoyminutemaid
enjoyminutemaid's Avatar
Drives: Subaru BRZ Limited WRB Manual
How is this done?
enjoyminutemaid is offline   Reply With Quote
Exedy Clutch KAR Engine, Exhaust, Transmission 28 01-03-2016 07:27 PM
exedy clutch questions ft86me Engine, Exhaust, Transmission 8 02-13-2014 09:58 PM
Lets talk about clutches charged86 Engine, Exhaust, Transmission 26 08-30-2013 04:13 PM
Clutches... Synack Engine, Exhaust, Transmission 19 12-16-2012 04:15 PM
Exedy BRZ specs sheet ayau BRZ Photos, Videos, Wallpapers, Gallery Forum 2 11-07-2012 09:56 PM
