Old 05-04-2014, 07:52 PM   #393
Prog
Prog's Avatar
Drives: 2016 Cadillac CTS
Hey @SHIFTER, I can't figure out how to wire up this aux port adapter. The car harness currently has blue-yellow, white-blue, and orange wires that would respectively connect to white, red, and black on the adapter. I'm really not sure how to repin the adapter.
Size:  86.1 KBName:  ImageUploadedByTapatalk1399247551.830371.jpg
Prog is offline   Reply With Quote
Old 05-04-2014, 08:02 PM   #394
DC2R
Drives: 2014 Scion FR-S
Got shipping info! Said shipping label was created may 1 but also some jazz about holiday and delays...plus weekend I assume. How long from shipping label did yours take to hit your door @SHIFTER?
Sent from my SM-N900T using Tapatalk
DC2R is offline   Reply With Quote
Old 05-04-2014, 08:23 PM   #395
SHIFTER
SHIFTER's Avatar
Drives: Scion FR-S
Originally Posted by ir1064 View Post
for you guys information, there maybe software update from Ca-Fi in coming days. my unit has suffer "This unit has insufficient space" error and i can't download anything from either play store or browser, the only way i can install new app is to side load them, and make it much harder to update any app... just to be clear, i have plenty of space in cache, internal storage and micro SD card, and i already try to reset download manager, play store app and play service, nothing help and i even reset the unit...
go into the file manager - you'll find a ton of APK files in the root of the C or D drive - i noticed for some reason when installing apps from the play store, it retains the install APKs.
Once you delete them, you'll be good.
PLEASE post if they give you an update for the unit though
Andrew
2013 Scion FR-S MT (Silver)
2011 Toyota Rav4 Sport V6 4wd (Silver)
SHIFTER is offline   Reply With Quote
Old 05-04-2014, 08:24 PM   #396
SHIFTER
SHIFTER's Avatar
Drives: Scion FR-S
3 days, literally.
This is a new unit though, don't be surprised if they're backed up with orders - so it may be a few days.
Andrew
The Following User Says Thank You to SHIFTER For This Useful Post:
DC2R (05-04-2014)
Old 05-04-2014, 08:26 PM   #397
SHIFTER
SHIFTER's Avatar
Drives: Scion FR-S
Attachment 77397Attachment 77398
I vaguely remember the brown, orange and pink/green where the wires you need. But its literally been a year since i wired mine up.
I won't have a chance to pull my stereo for a few days - but i'll do it when i can to verify.
Andrew
Prog (05-04-2014)
Old 05-04-2014, 09:11 PM   #398
Prog
Prog's Avatar
That is a temporary solution indeed, but when the device has gigabytes of free space, cleaning up 50 MB of APK files shouldn't really matter, and yet, it does. Something is wrong there.
Old 05-04-2014, 09:23 PM   #399
ir1064
Drives: 6MT, C7P
thx for your advice but it doesn't help neither... and you can count on me for the update news from Ca-Fi
here's what Will told me.
....The engineer team is still working on it. We will try to release a software update to fix this problme early next week. Please give us some more days....
ir1064 is offline   Reply With Quote
The Following User Says Thank You to ir1064 For This Useful Post:
Prog (05-04-2014)
Old 05-04-2014, 09:35 PM   #400
SHIFTER
SHIFTER's Avatar
Drives: Scion FR-S
Won't lie I had the same issue as youre explaining, it seemed to have gone away after I did a system restore though so i chalked it up to a rogue app I installed. I still go delete the APKs after installing new apps though.
Will is definitely gonna take care of us though, so def. let us know when you hear back
Andrew
Old 05-04-2014, 09:39 PM   #401
SHIFTER
SHIFTER's Avatar
Drives: Scion FR-S
Originally Posted by xjohnx View Post
anyone try adding the google now launcher via this method?
http://lifehacker.com/how-to-get-the...ing-1568796521
I did.
the stock ca-fi launcher still sits atop it (the one that you can pick the stock radio app and such from).
I decided it was easier to stick with their stock launcher and such. So far no complaints.
Andrew
Prog (05-05-2014)
Old 05-05-2014, 01:27 AM   #402
BennyBRZ
Drives: 14 BRZ Limited - DGM
Got my tracking number and cleared customs. Shouldn't be more than a couple days now.
BennyBRZ is offline   Reply With Quote
Old 05-05-2014, 10:54 AM   #403
Mehster
Drives: Firestorm 2013 Scion FR-S
Mine just came in this morning. I'm going to try to install it tonight. Wish me luck!
I ordered it April 25th. It shipped May 3rd and arrived May 5th. Not too shabby.
Mehster is offline   Reply With Quote
The Following User Says Thank You to Mehster For This Useful Post:
Prog (05-05-2014)
Old 05-05-2014, 03:29 PM   #404
Deathalo
Drives: 2013 WR Blue Limited Manual BRZ
Installing mine today as well, good luck to ye!
Deathalo is offline   Reply With Quote
Old 05-05-2014, 06:51 PM   #405
SHIFTER
SHIFTER's Avatar
Drives: Scion FR-S
Congrats guys! welcome to the club
Andrew
Old 05-05-2014, 07:00 PM   #406
Deathalo
Ok, so far, I've hooked things up but not installed permanently due to a few issues. First, can't get the backup camera working, I have a rydeen duo with an RCA output and a red power cable that is supposed to get power when shifting into reverse. This worked on my stock BRZ HU with the help of SVXdc's harness. I hooked that power cable to the "Back" brown wire coming from the Ca-Fi's black harness and tried both the Reverse Video In and regular Video In with no image when shifting to reverse.
The other issue is the aux port, I'm getting audio, but it's very quiet and lacking depth. I looked at where the wires were hooking up to the AUX harness in the back and I used the blue/orange and blue/yellow pins for the white and red wires respectively and the blue/white pin for the ground (I also tried the orange for ground, no difference heard). I noticed, @SHIFTER, you mentioned you tapped into the pink/green wire, not sure if it's different on the FR-S, but I didn't see the pink wire going to the AUX port. Maybe the AUX port just sounds like crap in general, I'll live with it. But really want to get the backup camera sorted out tonight.
REVIEW: Ca-Fi Toyota Universal - Stock Fitment ANDROID Stereo SHIFTER Electronics | Audio | NAV | Infotainment 16 06-13-2017 06:23 PM
Android, bluetooth, Music, and the FR-S stock pioneer stereo JayNutter Electronics | Audio | NAV | Infotainment 27 12-18-2014 03:54 AM
How to: Torque on an android powered stereo with no hacking v. Ca-Fi Dashlinq4 SHIFTER Electronics | Audio | NAV | Infotainment 29 04-07-2014 04:58 AM
