Old 05-04-2014, 03:16 AM   #225
Griever423
Drives: 2020 BRZ PP
I agree with the original post. My first impression getting deep into a corner with the BRZ was shocking. I was blown away with the turn in and how the car "bites" into the corner. Honestly I'm afraid to mess with the suspension because it's so good the way it is.
Griever423 is offline   Reply With Quote
Old 05-04-2014, 06:41 AM   #226
dradernh
Drives: Used to Drive:Grand-Am GS #54 E36M3
"Automotive industry research has found building a complete car out of spare parts could cost more than five times its original value..."
Going forward, I'll revise my estimates accordingly.
Outstanding! Now you can spend your money learning to drive instead of throwing parts at it without knowing exactly what they're going to do for you, an individual driver with his own individual needs. That's a win-win in this hobby.
Later, after you're getting the max out of the OEM components, you can choose what to upgrade based upon what you've learned through experience, once again maximizing your bang for the buck. The fastest amateurs I know are guys with relatively undeveloped cars but, man, are they fast for what they're driving.
dradernh is offline   Reply With Quote
Old 06-10-2014, 12:45 AM   #227
CSG Mike
CSG Mike's Avatar
Originally Posted by gramicci101 View Post
So for ~$1400, would you rather go with springs and struts, or coilovers?
I'd go camber plates, rear control arms, and springs.
Old 06-10-2014, 06:45 AM   #228
Panman
Panman's Avatar
Drives: 86 GTS
So which Camber plates would you recommend (Price/Performance), the options for standard shocks+springs seem to be:
Whiteline (Non adjustable, some concerns around QC)
Raceseng
HVT
Any other (reasonably priced) options?
Panman is offline   Reply With Quote
Old 06-10-2014, 07:08 AM   #229
CSG Mike
CSG Mike's Avatar
Raceseng
HVT
We think the RaceSeng camber plates are the best option, and SPL LCA for the rear.
The Following 3 Users Say Thank You to CSG Mike For This Useful Post:
CB390248 (06-11-2014), Panman (06-10-2014), Pseud0logik (06-14-2014)
Old 06-10-2014, 09:29 AM   #230
gramicci101
Off Topic
Keeping the OEM struts?
Old 06-10-2014, 02:24 PM   #231
fooddude
Drives: 04 Toyota Tacoma Prerunner Reg Cab
I think he's just trying to say alignment is more important for him at that price point, than new springs/dampers/coilovers.
fooddude is offline   Reply With Quote
The Following User Says Thank You to fooddude For This Useful Post:
CSG Mike (06-10-2014)
Old 06-10-2014, 02:34 PM   #232
fooddude
Why are SPL LCA's your top choice? ..or are they just the best bang for the buck and still good quality for the money?
Old 06-10-2014, 03:25 PM   #233
CSG Mike
CSG Mike's Avatar
Top notch quality at a competitive price?
A company that actually races and uses/tests their own product on track? I'll take it. A company like this is rare.
fooddude (06-10-2014), WillRacer1jz (06-13-2014)
Old 06-11-2014, 06:06 AM   #234
Fizz
Senior Addict
Fizz's Avatar
Drives: 86 GT
Hi Mike, perhaps it was you or someone else, but I thought you said the SPC arms are known to have alignment creep?
Fizz is offline   Reply With Quote
Old 06-11-2014, 11:04 AM   #235
Efferalgan
Drives: 2025 BRZ, ex-2012 GT86
I went through the entire topic (just to realise that I need to read tons of other stuff and try at least something with own buttdyno before buying something) and came to understanding that KW V3s are most commonly used as a single reference point for something worthwhile under $2.5k which allows for small (0.75-1.5'') drop (while keeping things overall not worse than stock) and comfortable DD (with proper damping) and still capable enough for occasional non-pro track use. Ohlins R&T seems to be a similar "golden standard" for $800-1000 more.
@CSG Mike what do you think about Japanese stuff: HKS HiperMAX IV GT, Tanabe Sustec Z40, Cusco Street Zero-A? Are they in the same league as KW V3 for reasonably comfortable DD on not particularly perfect roads + occasional track events?
Efferalgan is offline   Reply With Quote
Old 06-13-2014, 02:06 AM   #236
CSG Mike
CSG Mike's Avatar
The low end japanese stuff is not any better than any other low end product, for the most part. The high end stuff, however, is great.
Efferalgan (06-13-2014)
Old 06-13-2014, 02:40 AM   #237
Sypher
Sypher's Avatar
Drives: '13 Ultramarine FR-S M/T
@CSG Mike i was looking at fortune auto 500's with the swift spring upgrade. what do you think about these as 95%DD with 6-8 autox events and 2-4 track events a year. Mind you i'm not really shooting to win anything. just lower the car while picking up a little adjust ability and performance.
Mod List:
FT86SF Catted header / Nameless combo pipe with cat and res/ FT86SF V1 CBE / GrimmSpeed Intake / OFT STG 1 GS Tune / Fortune Auto 500's
Sypher is offline   Reply With Quote
Old 06-13-2014, 09:26 AM   #238
TrogDor the Burninator
TrogDor the Burninator's Avatar
Drives: 2013 Hot Lava FR-S 6 MT
[COLOR=black][FONT=Verdana]I went through the entire topic (just to realise that I need to read tons of other stuff and try at least something with own buttdyno before buying something) and came to understanding that KW V3s are most commonly used as a single reference point for something worthwhile under $2.5k which allows for small (0.75-1.5'') drop (while keeping things overall not worse than stock) and comfortable DD (with proper damping) and still capable enough for occasional non-pro track use. Ohlins R&T seems to be a similar "golden standard" for $800-1000 more.
I am a HUGE fan of the KW V3s ...
I know they aren't "Racing spec only" coilovers, but I really think they nailed the valving, and more importantly, the softer front end spring rate compared to the rear (340 front and 400 rear) ...
Combined with some Raceseng CasCam plates I couldn't be happier with my car's performance at my recent NASA event. While I do have a bit of body roll, I never felt like I was losing grip from it, and could always go with a wee bit more of stiffness in the front or rear bars.
They are also VERY streetable for daily drivers ... While my girlfriend complains somewhat about the ride (she drives a a super smooth new Honda Accord) it is usually because I have left the track settings in place. You can definitely alter the compression and rebound settings to get a smoother ride, rivaling the stock suspension but with a bit more preciseness due to the stiffer springs.
2013 Scion FR-S Hot Lava 6MT Current Mods: KW V3 Coilovers - Raceseng CasCam Plates - Volk TE37SL Black Edition 18x9 +45 - Dunlop Direzza ZIIs 255/35 - Tomei Expreme Ti 60S - FT86 SpeedFactory UEL Catted Header
TrogDor the Burninator is offline   Reply With Quote
The Following User Says Thank You to TrogDor the Burninator For This Useful Post:
Mike's CS FR-S build mikef Member's Car Journals 6 04-25-2013 09:11 AM
Some observations Nardi330 AUSTRALIA 20 02-07-2013 06:18 AM
90 Day Anniversary ..some Observations Scooby South BRZ First-Gen (2012+) — General Topics 6 09-03-2012 11:17 AM
Mike's track videos. CSG Mike Tracking / Autocross / HPDE / Drifting 2 08-16-2012 04:00 AM
First Payment sent, Observations after 6 weeks. Scooby South BRZ First-Gen (2012+) — General Topics 27 08-01-2012 02:02 PM
