Old 05-02-2014, 02:58 PM   #239
DeliciousTuning
PhoneFlash by EcuTeK
DeliciousTuning's Avatar
Originally Posted by Calum View Post
Welcome to the forums Zach. I'm glad to see DT is expanding. Good luck with the new gig.
Here's a secret, I've been here In addition, this is actually my second job. Butttt I'm getting used to it. Also, replied to your pm.
Sincerely,
The Following 2 Users Say Thank You to DeliciousTuning For This Useful Post:
Calum (05-02-2014), whataboutbob (05-09-2014)
Old 05-02-2014, 04:47 PM   #240
qtwre
Drives: White FR-S
The product page for the flash and go tune states the boost controller is coming but it seems like people already have it. Is the page just out of date?
qtwre is offline   Reply With Quote
Old 05-02-2014, 05:31 PM   #241
protpibe
protpibe's Avatar
Drives: 4-Runner Sport - 13' BRZ SportTech
They're prototypes. From what I understand they're not very pretty and don't come with any of the mounting hardware, vacuum lines, or installation instructions.
Top Tier Imports - Check out my build journal HERE
protpibe is offline   Reply With Quote
Old 05-02-2014, 05:41 PM   #242
DeliciousTuning
We're slowly easing them in a controlled release so as to make sure there are no issues. You can IM me privately to see what we can do about getting one out to you
Sincerely,
The Following User Says Thank You to DeliciousTuning For This Useful Post:
DeliciousTuning (05-10-2014)
Old 05-02-2014, 05:43 PM   #243
DeliciousTuning
I wouldn't say it's not pretty It simply doesn't come with all of the mounting brackets and vacuum lines quite yet. As of right now it's what we would affectionately call a "tuner kit".
Sincerely,
Old 05-02-2014, 06:26 PM   #244
vaderbloke
Drives: 2014 Subaru BRZ
Just installed my DT stage2 93 tune, stock apart from K&N air filter. Initial impressions are VERY positive. I can barely detect any torque dip. I was disappointed with a tune form another supplier (PM me if you want the name), so I decided to spring another $300 to see if it was just my car which runs fine on the stock ROM.
Now I am thinking of getting an E85 map, but draining the tank concerns me. Any opinions on how much residual fuel between swaps is OK? Also any flex-fuel systems with the DT maps?
vaderbloke is offline   Reply With Quote
The Following User Says Thank You to vaderbloke For This Useful Post:
Old 05-02-2014, 07:13 PM   #245
protpibe
protpibe's Avatar
Just curious, but isn't a Stage 2 NA type of tune for something that would have something like a header and catback?
Old 05-02-2014, 08:58 PM   #246
DeliciousTuning
Hey Vader,
Happy to hear that you're enjoying the new tune! As far as draining the tank, we do like to see you get her down to the gas light, however I'll tell you that for awhile I was paranoid about running out of gas and would rather fill up with E85 just before the light came on. This isn't good practice, but it worked out fine for me. In the end, even normal 91 octane can vary between 0 and 10% ethanol, and E85 varies between 60-85%, so it's never a perfect science. Try to get it down to the gas light, and let the ecu sort out the rest in fuel trims. The octane of the ethanol is high enough that you won't run into knock.
We do have Flex Fuel and E85 maps available, the flex fuel kit required to run the flex fuel map is what we're working on finalizing. In the meantime, I'd be happy to set you up with an E85 map if you don't already have a flex fuel kit. Feel free to pm me for details.
Sincerely,
Old 05-02-2014, 08:59 PM   #247
DeliciousTuning
You'll definitely get the most potential out of the car with a well designed header such as one of the offerings from JDL, Nameless, or PPE, but our Stage 2 will work with a stock manifold and a simple drop in intake filter as well. As far as anything behind the header goes, on an NA car, it really won't make a difference. Buy a quality header and add catback to suit your aural taste.
Sincerely,
Old 05-02-2014, 09:45 PM   #248
vaderbloke
Sincerely,
Zach
I decided to go to stage 2 after talking to William. It runs really well just with a drop in K&N. Really noticeable torque throughout and for patching over the "dip".
Old 05-03-2014, 12:23 PM   #249
qtwre
Drives: White FR-S
Sincerely,
Zach
Thanks
Another question... Purchasing a tune includes updates by minor version within the same major release number. So how often is a major version released? Once it's released, if we want to update do we pay the full price again, or is there a discount for current customers?
Old 05-03-2014, 12:27 PM   #250
DeliciousTuning
Thanks
Basically pretty soon here we're gonna be changing how we roll out the tunes. We're to a point that many of the tunes, specifically the Innovate kit, aren't going to get much better because they are so refined. Every tune purchased will include revisions to the individual right off the bat to suit their particular vehicle. As far as major updates go, I'll have to get back to you on that later today. The important part to the end consumer is that we're getting to a point where the tunes we're rolling out will only require minor, initial revisions before the tune is perfect.
Sincerely,
Old 05-03-2014, 12:42 PM   #251
Cal3000
Drives: Panda FR-S
Got my Flex Fuel installed with my Vortech at Infamous Performance and tuned by Bill.
242whp w/ 91 octane on the Mustang (one of the highest he has seen for a SC with a similar setup ~280whp on another dynojet he tunes on)
The E85 tune came out to 284whp (~320-330whp on dynojet )
This is all on stock headers and overpipe w/ the 9psi pulley. All I have is the Invidia front pipe and N1.
Thanks Bill for the awesome tune
The spike is the stock clutch slipping :P
Vortech SC on 9psi Pulley, Invidia Catless Front Pipe, Invidia N1 Catback Exhaust
242whp/197ft-lb on Mustang Dyno (91 octane water)
284whp/223ft-lb on Mustang Dyno (E85)
Cal3000 is offline   Reply With Quote
The Following User Says Thank You to Cal3000 For This Useful Post:
Old 05-03-2014, 01:10 PM   #252
fooddude
Drives: 04 Toyota Tacoma Prerunner Reg Cab
When the 200whp-91oct tune becomes available.. To save money- can I just buy the license and the tune from you, without buying the $300 cable (ie: you flash it for me)? I am local of course.
I kinda see it pointless to buy the cable and only use it once or twice (not to mention I only use Macs and really don't wanna install the buggy and huge Windows Boot Camp just for this).
fooddude is offline   Reply With Quote
Delicious Tuning: Offering Innovate Supercharger Stage 1 "Tuner" EcuTeK Maps DeliciousTuning Engine, Exhaust, Bolt-Ons 24 09-20-2013 03:04 PM
Delicious Tuning: EcuTeK Stage 1 or 2 on 91, 93 or E85 fuels DeliciousTuning Engine, Exhaust, Bolt-Ons 1 09-19-2013 05:58 PM
Delicious Tuning - Dyno Tuning Weekend at Mann Engineering's (San Jose, CA) DeliciousTuning Announcements, Contests, Giveaways 6 09-19-2013 05:55 PM
Delicious Tuning: FlexFuel Innovate Supercharger EcuTeK Maps DeliciousTuning Engine, Exhaust, Bolt-Ons 1 09-13-2013 01:34 AM
Delicious Tuning and HG Motorsports: 86Fest Only Special - Take $100 off EcuTeK DeliciousTuning Announcements, Contests, Giveaways 5 08-26-2013 02:33 PM
