Old 03-28-2012, 04:15 PM   #113
Tainen
Drives: First SWP BRZ-L
I apologize if this has already been posted, but I've got a shop telling me to break in my BRZ like this:
http://www.mototuneusa.com/break_in_secrets.htm
I am a little skeptical, like ahausheer. But I could be convinced with more hard data.
Tainen is offline   Reply With Quote
Old 03-28-2012, 06:19 PM   #114
Kunzite
Drives: Toyota Auris
It doesn't looks like a site I would trust. But this doesn't necessarily means they aren't right...
Kunzite is offline   Reply With Quote
Old 03-28-2012, 06:21 PM   #115
Zgrinch
Zgrinch's Avatar
Drives: 2013 Limited DGM BRZ
Agreed...but certainly the fun way to break in the car.
BRZGrincherhood
Zgrinch is offline   Reply With Quote
Old 03-28-2012, 06:25 PM   #116
sfwg
Drives: 2007 saturn ion(dd)
LMAO! I read the title and i thought out loud," House or car?"
2014 FRS
sfwg is offline   Reply With Quote
Old 03-28-2012, 06:26 PM   #117
OrbitalEllipses
Drives: Attitude
They've been around for a LONG time, hence the shitty 90s era web design. That said, a lot of motorcycle people use that routine and it's found its way into the car world. I won't be babying the car for 1000 miles. Aggressive acceleration, varying RPMs, and lots of engine-braking for 100-200 miles, then drive like usual. Maybe throw in an oil change, but I doubt it.
Old 03-29-2012, 12:40 AM   #118
adprokid
adprokid's Avatar
Drives: ZN6 / GDB-G
let the engine warm up before driving and let it cool down before you turn it off with the hood open, always drive it gently and shift and throw all gears, but try to keep revs up to 3k only, do that for the first 1000 miles and avoid hard braking.
adprokid is offline   Reply With Quote
Old 03-29-2012, 01:19 AM   #119
carbonBLUE
Reverse Burnouts
Drives: 2013 Argento FRS
im glad you think the same way, i filter the oil every 100-200 miles on the break in to catch straggling metal powder bits but thats about it, give it to her hard the first few times
2000 Carbon Blue Toyota Celica GTS 152000 miles
(wont forget you)
2013 Argento Scion FR-S
2011 Infiniti G37x
carbonBLUE is offline   Reply With Quote
Old 03-29-2012, 02:04 AM   #120
OrbitalEllipses
Drives: Attitude
Exactly. If during break-in the engine never sees the type of operation it's going to get...how can it adequately "prepare" to ever face those conditions?
Yeah you need a couple hundred miles to break in pads, rotors, etc.. I've specifically been talking about the engine though.
Old 03-31-2012, 02:42 PM   #121
Baldeagle
Drives: VW GLI 6MT
cars come with 2-3 miles on them from being dyno tested and partially broken in at the factory to make sure everything runs.
Does anyone know what really happens during those first few miles? Is there an actual “pre-break-in” procedure? Are those hard miles? Are they really monitored?
Baldeagle is offline   Reply With Quote
Old 03-31-2012, 04:30 PM   #122
Marrk
Drives: Honda Fit
This s a longstanding mystery, Bald. It's hard to believe that a volume manufacturer, like Toyota or GM, is bench testing and bench-breaking-in each and every one of the hundreds of thousands of engines that it produces each year. Maybe M-B or Porsche do it on some of their models. On the other hand, I suppose they could fire each engine up for a few seconds, once it reaches the end of the production line, just to look for major leaks, etc.
I do not know. This is akin to that other great mystery, i.e., Is there such a thing as break-in oil from the factory?
Marrk is offline   Reply With Quote
Old 04-04-2012, 08:34 PM   #123
mike18
Drives: prelude
Sounds like most ppl would break in their car hard and using conventional oil when Subaru manual say to keep it under 4k rpm while filling up with 0w20 synthetic. Yet I am leaning on the hard break in method rather than follow the engineers recommendation. I really want to keep this car for a longggg time so I wouldnt mind breaking it in correctly.
mike18 is offline   Reply With Quote
Old 04-04-2012, 09:14 PM   #124
serialk11r
Drives: '06 AM V8V Coupe
I don't understand why people want to second guess the OEM engineers when it comes to something as complex and with so many unknown details as an engine. Only they know what's done to the engines before they're put into the cars, and if they recommend something and back it up with a warranty, why are you going to try to undo everything Makes no sense.
It's not like an aero mod where you put a skirt here, put a cover there, it's a freaking engine that's worth more than any other part on the car.
Old 04-04-2012, 09:17 PM   #125
tranzformer
Delights in pure handling
tranzformer's Avatar
Drives: Zoom Zoom
tranzformer is offline   Reply With Quote
Old 04-04-2012, 10:20 PM   #126
Dimman
Kuruma Otaku
Dimman's Avatar
I don't know but there seems to be decades of support for the hard break-in gives best ring-seal (power).
Because titanium.
break-in
