#4887 | |
Time Traveller
In California, adding 11oz of Torco Unleaded Accelerator to 1 full tank of CA91 pump gas improved the car dramatically across the entire power band. Granted it would to an NA car as well, but it really makes the Phantom ESC rocket. Logically, the Torco Accelerator also improved my logs too. The IAM stays nearly locked in at 1.0 and if/when it drops to say the .90 area, it recovers immediately. Whereas without the fuel additive it could drop extremely low and take a long time to recover back to 1.0. The car revs smoother, the torque dip is shorter, it has more power up top. The additive adds $8 to the cost of a fill up (or about $0.65 a gallon), and is worth every penny. Takes the car to roughly 93-95 octane. Wondering about taking the fuel up to 105 octane (max that Torco says the additive will do). I also have a TRD drop-in filter and catback. These were already on the car before the Phantom ESC so I can't say if they actually add anything to the ESCs performance. |
#4888 | |
Drives: '13 BRZ Limited WRB Phantom ESC 1.5
![]() To me, 0-60 is a nice measuring stick.
'13 BRZ Ltd MT WRB Phantom ESC 1.5
2012 Honda Accord Coupe 2006 Saab 9-3 2.0t 1997 Honda Accord Coupe 1995 Honda Prelude VTEC |
#4889 |
I'm guessing there are alternatives that may be more or less expensive/effective..?
Any specific reason you chose that one as opposed to any other, similar products.
#4890 | |
The car will just seem more eager to move. Sent from my HTC One using Tapatalk |
| The Following User Says Thank You to fenton For This Useful Post: | robwbright (04-30-2014) |
#4891 | |
Drives: Fiat Abarth
#4892 | |
Time Traveller
| The Following User Says Thank You to DAEMANO For This Useful Post: | robwbright (04-30-2014) |
#4893 |
Time Traveller
#4894 | |
Erected Member
Drives: frs
#4895 |
Drives: WR Blue BRZ, 240Z
K&N drop-in. The OEM airbox helps to support the compressor. Not the most expensive answer, but the right one.
Phantom ESC, ECUtek Tune, Nameless Front Pipe & Axle Back, Enkei RS+M 17x8 et35, OEM+Ref
#4896 | |
Drives: DGM BRZ 6MT
It'll be great if I can just go to the track and take advantage of the drag reduction without doing anything else (like flashing back to a stage 1 tune and or swapping back to stock intake tube).
#4897 | |
If im not mistaken when DR or no boost is being applied the car will run close to the stock or stage 1 fuel targets. This would mean it would run lean and not rich when no boost is detected. |
#4898 |
Erected Member
Drives: frs
Does SPM/DR come standard with every kit?
#4899 | |
Drives: Fiat Abarth
![]() Disclaimer: measured using Dynojet sniffer which seems to be directionally accurate when I've compared it to my OFT logs. Made basically the same power as stock, with a little less low end torque:
#4900 |
Drives: Fiat Abarth
| Circuit Motorsports - Vortech Supercharger FR-S Build + Full Perrin Exhaust & Extras | Circuit Motorsports | Member's Car Journals | 4 | 03-21-2013 04:45 PM |
| Subaru BRZ : Full Throttle, powerslide, hard revving & ride | ESBjiujitsu | BRZ Photos, Videos, Wallpapers, Gallery Forum | 20 | 05-30-2012 06:43 PM |
| 86 Full Throttle Video + another. | Aus86 | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 2 | 04-02-2012 07:07 AM |
