| CANADA Canada |
Drives: 2014 BR"ZED" Sport-tech DGM MT
Oil Filter Wrench?
Hi guys.
I'm looking for a bit of adviceon what you are using as a wrench on our oil filters. I have the tried and truebelt style but have found not enough room to get the proper leverage with it andended up driving a screwdriver through the top of it to get it off. I've beentrying to find the cap style wrench but every where I have looked I found Ifelt like Goldilocks where they have been too big or too small and not justright. I think that would be my preferred style as I could use my socket wrenchhandle with it. I'm hoping to pick something up locally but any suggestionswould be welcome. Thanks |
#2 |
DADA
Drives: 2013
Just a basic oil filter wrench is what I use, the filter that the car came with from Toyota was on extremely tight, slipped a few times. Wrapped a cloth around the filter and the wrench did its work
#3 |
Mine broke. The factory filter felt like it was glued on.
#4 |
DADA
Drives: 2013
What broke? Yeah that first one was a B*tch to get off.. I was about to give up and drill right through and twist it off with a screwdriver
#5 | |
#6 |
DADA
Drives: 2013
Just go get a new one at the automotive shop. Try it again, make sure the filter is completely dry, no grease on the filter or you will keep slipping
#7 |
Dances with Cones
Drives: 2013 Scion FR-S Raven
I use K&N filters with the nut on the top. Solves that problem really easily.
2013 Scion FR-S - Raven
2011 Scion tC - Cement - SOLD |
#8 |
I wanted to stick with OME filters until the warranty expired.
#9 |
Drives: Whiteout Scion FR-S
This one from a local big box home improvement store:
https://www.channellock.com/209-Oil-...PVC-Plier.aspx Since I have a FilterMag installed, there is very little access. With this wrench, I can grab the oil filter from the top and unscrew it without any problems. You could go for a larger one for more versatility, but I have found that the smaller one works just fine for our filters and fits better in the tool box.
My cars always dress formally. They all wear black tires.
| The Following User Says Thank You to Black Tire For This Useful Post: | FLYFISHR (04-30-2014) |
#10 |
Drives: '13 BRZ Limited WRB Phantom ESC 1.5
Sears/craftsman has one.
http://www.sears.com/craftsman-unive...p-02820523000P Appears to be the same one cheaper at KMart. http://www.kmart.com/craftsman-unive...1&blockType=G1
'13 BRZ Ltd MT WRB Phantom ESC 1.5
2012 Honda Accord Coupe 2006 Saab 9-3 2.0t 1997 Honda Accord Coupe 1995 Honda Prelude VTEC |
#11 |
Drives: DGM BRZ 6MT
After the first oil filter change from factory, all future oil filters should be removable by hand. I only tighten them handtight + slightly more pressure. Lube the o-ring for easier removing in the future.
#12 |
That's what my dad taught me to do and the way I still do it. Thanks
#13 | ||
Drives: 2013 BRZ Limited WRB
Sent from my SGH-I337M using Tapatalk
#14 |
Drive From Home
Drives: BRZ STI Performance
Interesting I just got my first ever oil change and the factory oil filter came off by hand.
| Recomend torque wrench | jflogerzi | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 29 | 06-08-2017 06:38 AM |
| Craftsman Universal Oil Filter Wrench, Auto-Adjustable $6.99 free in store pickup | robwbright | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 7 | 03-13-2014 11:07 PM |
| OEM Subaru engine air filter + cabin air filter | autobrz | Mechanical Maintenance and Tools | 6 | 03-09-2014 09:28 PM |
| Hex wrench on FRS is it 3/4" ? | dssence | Scion FR-S / Toyota 86 GT86 General Forum | 5 | 02-28-2014 02:20 PM |
| Drop In filter test! Stock, Apexi, No filter | RallySport Direct | Engine, Exhaust, Transmission | 14 | 06-25-2012 02:40 PM |
