CANADA Canada
Old 04-29-2014, 03:28 PM   #1
FLYFISHR
FLYFISHR's Avatar
Drives: 2014 BR"ZED" Sport-tech DGM MT
Oil Filter Wrench?
Hi guys.
I'm looking for a bit of adviceon what you are using as a wrench on our oil filters. I have the tried and truebelt style but have found not enough room to get the proper leverage with it andended up driving a screwdriver through the top of it to get it off. I've beentrying to find the cap style wrench but every where I have looked I found Ifelt like Goldilocks where they have been too big or too small and not justright. I think that would be my preferred style as I could use my socket wrenchhandle with it. I'm hoping to pick something up locally but any suggestionswould be welcome.
Thanks
Old enough to know better but young enough to do it again
FLYFISHR is offline   Reply With Quote
Old 04-29-2014, 03:31 PM   #2
mashal
DADA
mashal's Avatar
Drives: 2013
Just a basic oil filter wrench is what I use, the filter that the car came with from Toyota was on extremely tight, slipped a few times. Wrapped a cloth around the filter and the wrench did its work
mashal is offline   Reply With Quote
Old 04-29-2014, 03:38 PM   #3
FLYFISHR
FLYFISHR's Avatar
Mine broke. The factory filter felt like it was glued on.
Old 04-29-2014, 03:43 PM   #4
mashal
DADA
mashal's Avatar
Drives: 2013
What broke? Yeah that first one was a B*tch to get off.. I was about to give up and drill right through and twist it off with a screwdriver
Old 04-29-2014, 03:55 PM   #5
FLYFISHR
FLYFISHR's Avatar
The pin that held the strap. I even tried some rubber strapping around the filter to give the wrench a better grip on it. You can guess how well that worked out.
Old 04-29-2014, 04:01 PM   #6
mashal
DADA
mashal's Avatar
Drives: 2013
Just go get a new one at the automotive shop. Try it again, make sure the filter is completely dry, no grease on the filter or you will keep slipping
Old 04-29-2014, 08:08 PM   #7
that_guy
Dances with Cones
that_guy's Avatar
Drives: 2013 Scion FR-S Raven
I use K&N filters with the nut on the top. Solves that problem really easily.
2013 Scion FR-S - Raven
2011 Scion tC - Cement - SOLD
that_guy is offline   Reply With Quote
Old 04-29-2014, 11:34 PM   #8
FLYFISHR
FLYFISHR's Avatar
I wanted to stick with OME filters until the warranty expired.
Old 04-29-2014, 11:39 PM   #9
Black Tire
Black Tire's Avatar
Drives: Whiteout Scion FR-S
This one from a local big box home improvement store:
https://www.channellock.com/209-Oil-...PVC-Plier.aspx
Since I have a FilterMag installed, there is very little access. With this wrench, I can grab the oil filter from the top and unscrew it without any problems. You could go for a larger one for more versatility, but I have found that the smaller one works just fine for our filters and fits better in the tool box.
My cars always dress formally. They all wear black tires.
Black Tire is offline   Reply With Quote
The Following User Says Thank You to Black Tire For This Useful Post:
FLYFISHR (04-30-2014)
Old 04-29-2014, 11:59 PM   #10
robwbright
Drives: '13 BRZ Limited WRB Phantom ESC 1.5
Sears/craftsman has one.
http://www.sears.com/craftsman-unive...p-02820523000P
Appears to be the same one cheaper at KMart.
http://www.kmart.com/craftsman-unive...1&blockType=G1
'13 BRZ Ltd MT WRB Phantom ESC 1.5
2012 Honda Accord Coupe
2006 Saab 9-3 2.0t
1997 Honda Accord Coupe
1995 Honda Prelude VTEC
robwbright is offline   Reply With Quote
The Following 2 Users Say Thank You to robwbright For This Useful Post:
djdnz (04-30-2014), FLYFISHR (04-30-2014)
Old 04-30-2014, 12:48 AM   #11
TM
TM's Avatar
Drives: DGM BRZ 6MT
After the first oil filter change from factory, all future oil filters should be removable by hand. I only tighten them handtight + slightly more pressure. Lube the o-ring for easier removing in the future.
TM is offline   Reply With Quote
Old 04-30-2014, 01:16 AM   #12
FLYFISHR
FLYFISHR's Avatar
That's what my dad taught me to do and the way I still do it. Thanks
Old 04-30-2014, 01:38 AM   #13
Simon99
Simon99's Avatar
Drives: 2013 BRZ Limited WRB
What he said, I don't think more torque than elbow grease will help in anyway. Of courae dealerships dont get that
Sent from my SGH-I337M using Tapatalk
Originally Posted by VesperLynn
This car has allowed car enthusiasts to come from all different walks of life, car cultures, and brands. Just as a panda is black, white, and Asian; the 86 is Toyota, Subaru, and downright fucking sexy.
Simon99 is offline   Reply With Quote
Old 04-30-2014, 06:37 AM   #14
krayzie
Drive From Home
krayzie's Avatar
Drives: BRZ STI Performance
Interesting I just got my first ever oil change and the factory oil filter came off by hand.
krayzie is offline   Reply With Quote
Recomend torque wrench jflogerzi Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 29 06-08-2017 06:38 AM
Craftsman Universal Oil Filter Wrench, Auto-Adjustable $6.99 free in store pickup robwbright Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 7 03-13-2014 11:07 PM
OEM Subaru engine air filter + cabin air filter autobrz Mechanical Maintenance and Tools 6 03-09-2014 09:28 PM
Hex wrench on FRS is it 3/4" ? dssence Scion FR-S / Toyota 86 GT86 General Forum 5 02-28-2014 02:20 PM
Drop In filter test! Stock, Apexi, No filter RallySport Direct Engine, Exhaust, Transmission 14 06-25-2012 02:40 PM
