View Poll Results: Would you want a FR-S phone holder?
Yes, a high quality one that is slightly more expensive. 22 35.48%
Yes, a lower quality one that is somewhat cheap. 3 4.84%
Yes, but possibly a different design/look. 8 12.90%
No 29 46.77%
Voters: 62. You may not vote on this poll
Old 04-28-2014, 08:05 PM   #1
krt72012
Drives: Black Scion FR-S
Phone Holder for FR-S Middle Console
I've designed and created a personal phone holder that fits in the useless rectangle in the middle console of the FR-S. I've had trouble finding a good place to put my phone to use GPS and control music, so I made this.
If a decent amount of people are interested in them, I'm looking to sell them to anyone else who could use one!
Let me know if you're interested below. I have several different designs and this is just a special one with low density hex filling.
The example is also a low quality test prototype.
Also I'm fairly new here, but I have a black FR-S with a custom amp/subwoofer addition and custom footwell lighting!
Here are some pictures:
krt72012 is offline   Reply With Quote
The Following User Says Thank You to krt72012 For This Useful Post:
bluesman (04-29-2014)
Old 04-28-2014, 10:29 PM   #2
poison1916
Drives: Scion FR-S Hot Lava
I'm bad. I've got a suction cup mount on the passanager airbag area. Tilted so it's easy to see the screen while driving. I have an NFC sticker to connect the Bluetooth in this area. I wanted to put the mount on this area but its too small.
Sent from my HTC6525LVW using Tapatalk
poison1916 is offline   Reply With Quote
Old 04-28-2014, 10:31 PM   #3
J_kennington
Drives: 2013 asphalt scion FRS
The basic design is nice, but it looks like it would be difficult with a 6mt.
2013 raven frs(dd/grocery getter)
1990 mitsu eclipse gsx(street/strip car)
1995 gmc 1500 4x4(off road toy)
2005 Yamaha yz250f
J_kennington is offline   Reply With Quote
Old 04-29-2014, 06:23 AM   #4
phobos512
phobos512's Avatar
Drives: 2014 FR-S 6MT Whiteout
I'm not seeing any pictures?
Matt | '14 FR-S 6MT Whiteout | '13 Sonata Hybrid | '11 CBR1000RR
phobos512 is offline   Reply With Quote
The Following User Says Thank You to phobos512 For This Useful Post:
Teclis (09-05-2015)
Old 04-29-2014, 09:53 AM   #5
neutron256
neutron256's Avatar
Drives: '13 GBS Subaru BRZ
I like the idea, but it wouldn't work with my BRZ since my heated seat controls are there.
Old 04-29-2014, 10:24 AM   #6
CruiseZen
CruiseZen's Avatar
Drives: 2014 Ultramarine 6MT FR-S Monogram
The same goes for Monograms.
Borla axleback exhaust * mud guards * Michelin Pilot Super Sport tires * Opti-Coat * BRZ trunk lid liner * Rexpeed Wide Mirrors (heated)
CruiseZen is offline   Reply With Quote
Old 04-29-2014, 10:59 AM   #7
extrashaky
Drives: 2014 BRZ Limited
I agree. That looks like it would put my phone right in the way when shifting.
I was also having trouble finding a good place for my phone, so I made this:
I am NOT making these or selling them, but I wouldn't object at all to someone using my design or improving on it.
The Following 4 Users Say Thank You to extrashaky For This Useful Post:
bluesman (04-29-2014), mxrcmxlendon (04-29-2014), rojas93 (04-29-2014), Scaldy (04-29-2014)
Old 04-29-2014, 11:03 AM   #8
MokSpeed
Granny Shifter
MokSpeed's Avatar
Drives: 2014 FR-S
I'm fine without an actual place for it. The small crevice between the middle compartment and the cup holder tray works fine for me. If I want luxury I'll bring out the Lexus.
MokSpeed is offline   Reply With Quote
The Following 2 Users Say Thank You to MokSpeed For This Useful Post:
Annahra (04-29-2014), Jyn (04-29-2014)
Old 04-29-2014, 11:13 AM   #9
Annahra
Annahra's Avatar
Drives: 2014 WRB BRZ LTD
^ This is where I keep mine, if I understand what you are describing, and I have it connected via Bluetooth. That tiny little slot is still accessible with the Zeta armrest and it's a perfect fit.
Still, props to the op for ingenuity!
Sent from my SPH-L720 using Tapatalk
Annahra is offline   Reply With Quote
Old 04-29-2014, 01:02 PM   #10
mweidner311
Drives: N/A
Nice job! That looks exactly like a custom pro-fit bracket. We used to install them back in my college days working at Circuit city roadshop. I like it made me look them up
http://www.pro-fit-intl.com/Adobe/SC-51-05-L.pdf
think this bracket would work for us if you dont want to custom build one. Ill be picking one up myself.
http://www.pro-fit-intl.com/scion.htm
mweidner311 is offline   Reply With Quote
Old 04-29-2014, 01:06 PM   #11
1Cor10:23
1Cor10:23's Avatar
Drives: '13 Whiteout FR-S (M/T)
Have you guys checked out the iMagnet? I use it in the little triangular window at the front of driver side. I have a quick write up here where i use it for my OFT. I typically put my nexus 5 here, albeit in landscape.
http://www.ft86club.com/forums/showthread.php?t=64634
1Cor10:23 is offline   Reply With Quote
Old 04-29-2014, 03:02 PM   #12
extrashaky
Unless I'm looking at the wrong page, that bracket for the tC doesn't look like it will work on the twins, at least not without drilling holes. I just used 18 gauge aluminum from Home Depot and a $9 metal seamer from Harbor Freight to make the bends. It mounts to the existing bolt that holds the stereo in and doesn't alter the car itself at all.
I had an old Samsung Note I was no longer using, and I also had the car mount for it, so I rooted it and made it my engine monitor. I'm using that same piece of triangular glass you're using. It makes me a little nervous there, because it's right in the way of the A-pillar airbag and could become a projectile in a crash, but the location is almost perfect otherwise.
By the way, I noticed that you had your cable hanging in the front of the dash. I have the cable for mine dressed behind the dash so that it comes out of the gap behind that little panel between the dash and the door. That panel comes off easily and gives you access to the area behind the gauge cluster, and putting it there allowed me to be able to open and close my door without removing the cable. The OFT cable looks too big to run there without some cutting, but a small notch out of that panel should give you plenty of clearance to dress that cable out of your way.
Eventually I'm planning to run my cable into the door and out the little hole at the top of the door panel so that it's dressed and hidden all the way up to the mount.
The Following User Says Thank You to extrashaky For This Useful Post:
mweidner311 (04-29-2014)
Old 04-29-2014, 03:11 PM   #13
mweidner311
Drives: N/A
WOW! That is awesome and yes you are correct after looking a little further no way in hell the TC bracket will work for us so.... looks like ill be stealing your idea
Love the tablet how did you do that??? is there dedicated software for it then plug into the OBDII port? I'm familiar with rooting droids but never really looked into live engine software like that.
That sir is sick
Old 04-29-2014, 03:22 PM   #14
extrashaky
That's the Torque Pro app.
http://torque-bhp.com/
You don't actually have to root the phone to use Torque, but I am using a couple of other apps for startup and shutdown that need root access to work properly. You can use Torque on just about any Android device, rooted or not. It not only gives you engine monitoring, but it will also run emissions checks to show you whether you'll pass inspection if you live in a nanny state, and it will read and clear codes if your check engine light comes on.
Torque connects to the engine via a Bluetooth OBDII adapter. I have used this one:
[ame="http://www.amazon.com/BAFX-Products-Bluetooth-diagnostics-Android/dp/B005NLQAHS/ref=sr_1_1?ie=UTF8&qid=1398799050"]BAFX OBDII Bluetooth Adapter[/ame]
But I'm now using this one:
[ame="http://www.amazon.com/gp/product/B00H9S71LW/ref=oh_details_o00_s00_i00?ie=UTF8&psc=1"]ScanTool 427201 OBDLink LX Bluetooth OBD-II Scan Tool Interface[/ame]
The first one is pretty cheap, but it worked just fine. I bought the more expensive one because it has an automatic shutoff to save the car battery. There are even cheaper ones available and some low-profile ones that don't stick out as far.
center, console, holder, middle, phone
Phone holder Tim_Asphalt_FRS Cosmetic Modification (Interior/Exterior/Lighting) 79 04-02-2016 03:28 PM
Pro Clip phone holder NEW jack43 Audio/Visual, Electronics, Infotainment, NAV 6 04-04-2014 09:38 AM
Anyone using a universal cell phone holder? swift996 Electronics | Audio | NAV | Infotainment 4 12-16-2012 06:13 PM
DIY request: Middle Console Panel mbh1101 DIY (Do-It-Yourself) Guides 3 11-07-2012 06:57 AM
Phone holder for track days BAE Tracking / Autocross / HPDE / Drifting 12 08-27-2012 01:12 PM
