Old 04-29-2014, 11:38 AM   #43
radroach
Drives: car
I find the torque dip useful for comfortable driving cruising at 3k rpm / 55 mph, if you go over a bump on the highway and it shakes your foot it doesn't cause you to gun the engine
Old 04-29-2014, 11:42 AM   #44
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
Originally Posted by raul View Post
You're welcome for the free boost in you're thanks. I already know I can't spell for.
raul (04-29-2014)
Old 04-29-2014, 11:51 AM   #45
STV3
Señor Member
STV3's Avatar
What??? I've never hit a bump on the highway and then accidentally gunned the throttle. Even so not having the torque dip wouldn't make a slight blip of the throttle any worse. We aren't driving 500hp V8's
STV3 is offline   Reply With Quote
The Following User Says Thank You to STV3 For This Useful Post:
Bristecom (04-30-2014)
Old 04-29-2014, 11:58 AM   #46
Andrew025
Andrew025's Avatar
Drives: Neptune GR86
Must be some huge ass pot holes where you live.
Old 04-29-2014, 12:00 PM   #47
SloS14
SloS14's Avatar
Drives: 2013 FR-S whiteout
The GT86 designers engineered in the torque dip to keep the rear tires from breaking traction during acceleration at highway speeds from all that goddamn torque.
The Following User Says Thank You to SloS14 For This Useful Post:
STV3 (04-29-2014)
Old 04-29-2014, 12:32 PM   #48
Tromatic
I suspect twice the HP and torque would not make some of you any better drivers.
The Following 2 Users Say Thank You to Tromatic For This Useful Post:
skuts? (04-29-2014), strat61caster (04-29-2014)
Old 04-29-2014, 12:50 PM   #49
FlamingRectumSyndrome
Shriveled Old Member
FlamingRectumSyndrome's Avatar
Drives: 14 Hot Lava FR-S
I like some torque dip with my tortilla chips; guacamole gets boring after a while.
Re: the relatively broad torque curve this car has (despite the dip): surprised nobody has mentioned the square bore:stroke ratio (86mm X 86mm). This is the ideal compromise between a torque-heavy but horsepower limiting undersquare ratio, and the all top end, got no guts down low characteristics of an oversquare configuration.
FlamingRectumSyndrome is offline   Reply With Quote
The Following User Says Thank You to FlamingRectumSyndrome For This Useful Post:
Akari (04-30-2014)
Old 04-30-2014, 06:35 PM   #50
schmearcampain
Drives: 2014 Argento FRS 6MT
Originally Posted by tbertran View Post
You can if you want to. However, it's not necessary to remove the TQ dip (I can testify to that, as can a few other lucky FT86SF catted header owners )
So if just changing the header will remove the torque dip, what's the downside? Worse mileage?
I mean, it seems such a simple thing to change, there must be a tradeoff somewhere.
schmearcampain is offline   Reply With Quote
Old 05-01-2014, 12:14 AM   #51
Fortis
Fortis's Avatar
Drives: 2014 FR-S AT Asphalt
You won't pass smog and it's technically not street legal (even the catted options). You might also throw a CEL on stock programming. It will also make your exhaust system a bit louder and you may get some raspiness.
Fortis is offline   Reply With Quote
Old 05-01-2014, 05:29 PM   #52
schmearcampain
Wait, catted ones won't pass smog either? What's the point of adding a cat to it?
And the illegality is because they're too loud?
Old 05-01-2014, 05:44 PM   #53
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
Aftermarket exhausts that change the pollution control systems in any way must be CARB certified for California registration. Other states have different regulations that may require a catalytic converter hence the catted versions that are 49 state legal.
I haven't researched it but I'd be surprised if there weren't at least one or two certified aftermarket options out there.
http://www.ft86club.com/forums/showthread.php?t=17985
ineedyourdiddly
Old 05-02-2014, 05:22 PM   #54
CatDaddysBBQ
Drives: '13 FR-S
I think about this often - would I prefer less torque but a more linear delivery (a-la s2000 or rx8).
I think the times I am thrashing the thing, or autoX, whatever - I'd appreciate a more top end heavy trade-off...
BUT, this is my DD, and coming from a MUCH torquier history of cars before owning this one, i'll keep what it has.
CatDaddysBBQ is offline   Reply With Quote
What's the Purpose of WL Com C Top Mounts? gbgracer Tracking / Autocross / HPDE / Drifting 16 03-27-2013 01:52 PM
Thread with genaral purpose TIE Pilot Site Announcements / Questions / Issues 2 03-07-2013 03:13 PM
Purpose of alternator and a/c covers Turbowned Engine, Exhaust, Transmission 3 03-03-2013 04:54 PM
Purpose of oil catch can? denverizzles Engine, Exhaust, Transmission 1 06-28-2012 03:55 PM
What purpose or role will the FR-S / BRZ serve you? switchlanez Scion FR-S / Toyota 86 GT86 General Forum 139 03-27-2012 02:28 PM
