Old 05-21-2013, 05:48 PM   #15
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
Originally Posted by BlaineWasHere View Post
Last thing I need is a stripped stud at autoX or the track!!
Fixt. I have always used anti-seize on my studs on the racecar. Never stripped a stud. Never had a lug come loose.
CSG Mike (04-28-2014)
Old 05-21-2013, 10:53 PM   #16
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
On the flip side the only time I've stripped a stud on any of my cars is the one time I used anti seize lol
Oh and the arp studs are great. I have no worries with them installed and installing them is simple
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 04-28-2014, 09:04 PM   #17
ericmpena
ericmpena's Avatar
Drives: Subaru BRZ Limited
So, I don't take my wheels off often, but the last 2 times I've already had 1 stud break and today another stud stripped. Seems like the factory wheel studs are weak as hell. I can already feel some of the other studs getting stiff and there are visible metal shavings.
If I wanted to upgrade these studs so I can avoid running into this issue, what would you all recommend?
ericmpena is offline   Reply With Quote
Old 04-28-2014, 09:58 PM   #18
CSG Mike
CSG Mike's Avatar
ARP studs.
Are you using a torque wrench?
Old 04-29-2014, 08:15 AM   #19
ericmpena
ericmpena's Avatar
ARP studs.
Thanks. I don't have a torque wrench. I'll definitely be looking to invest in one since I've been needing to remove my wheels more often now. Up until now most of the time I've had a shop remove the wheels. I've only done it myself a handful of times.
Old 04-29-2014, 10:23 AM   #20
King Tut
NASA SpecE30 Racer
King Tut's Avatar
ARP makes the only aftermarket studs I have seen thus far. Using air tools to remove and install the lug nuts multiple times was most likely the cause. You definitely always want to torque them with a torque wrench as well. The shop should have been doing that as well.
ericmpena (04-29-2014)
Old 04-29-2014, 10:54 AM   #21
wparsons
wparsons's Avatar
^^ I've heard the Nismo studs will work as well.
flickr
Old 04-29-2014, 12:10 PM   #22
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
Vorshlag also makes extended studs (slightly shorter than ARP)
Old 04-29-2014, 12:12 PM   #23
Dezoris
Dezoris's Avatar
Knock on wood, have had OEM studs, had wheels on and off over 100x.
Impact off, hand thread nuts back on, then impact with tq stick to 60lbs, then torque wrench on. No anti-seize. Had oem nuts and now Mutegi SR48s.
The Following User Says Thank You to Dezoris For This Useful Post:
CSG Mike (04-29-2014)
Old 04-29-2014, 03:16 PM   #24
CSG Mike
CSG Mike's Avatar
Remember, a torque wrench is a precision tool. Always back it off when you're not using it, and keep it in its protective case. Don't drop it or expose it to any type of impact/shock load.
Old 04-29-2014, 03:16 PM   #25
CSG Mike
CSG Mike's Avatar
You're doing it right
Old 04-30-2014, 09:06 AM   #26
mla163
Overthinking it
Drives: BRZ in CS
I wipe anti seize on the threads of the stud and then wipe it off with a cloth. I know it will start some arguments, but I've never had a problem after lots of tire changes (every other week for 3 years during autocross on my old car).
These studs feel pretty weak and I am thinking about switching to something stronger.
mla163 is offline   Reply With Quote
Old 04-30-2014, 09:58 AM   #27
Rayme
The Answer
Rayme's Avatar
Drives: Mazda 2
i stripped a stud/nut using an impact to remove the nut. It was torqued to 90 lbs.. I'm not impressed...it was the first time I used an impact to remove the nuts and will be the last.
Rayme is offline   Reply With Quote
Old 05-01-2014, 12:49 AM   #28
trackjunkie
Drives: Subaru BRZ Blue
I had similar problems, breaking the stock studs. Changed to ARP extended studs, and problem solved. I use an impact drill, change them constantly, no issues. go with ARP extended studs. I do not use antiseize, the ARPs are just that good. They look solid compared to the stock ones.
trackjunkie is offline   Reply With Quote
I Messed up my bumper, so I fixed it SkitterSkotter Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 54 03-25-2015 08:03 PM
Dealership messed up on radio ayliu Scion FR-S / Toyota 86 GT86 General Forum 20 10-25-2012 10:43 AM
Lug Nut Stud feldy Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 1 09-22-2012 10:26 PM
So the dealer messed up... koolhawk BRZ First-Gen (2012+) — General Topics 26 06-18-2012 08:19 PM
Messed up? You decide. Godzilla35 Scion FR-S / Toyota 86 GT86 General Forum 66 05-15-2012 02:20 PM
