Old 05-19-2013, 10:54 PM   #1
BlaineWasHere
Grip>Drift
BlaineWasHere's Avatar
Drives: FRS
Messed up stud!!!
When I was putting my DD wheels and tires back on this afternoon one of my lugs was SUPER hard to get off so new if was effed right away. Sure enough the threads are not happy (please see picture below). Mega bummer...
What's the best way to fix this, replace the stud? I've been thinking about getting extended studs, anything else to think about when doing that if I decide to upgrade?
What could have caused this? I've been autoXing for a few years and I've done plenty of wheel/tire changes and this has never happened before! Could the cheap lugs have contributed?
Thanks in advance friends!
Shitty cell picture:
Old 05-19-2013, 11:16 PM   #2
cnk
Drives: '13 DGM BRZ Limited
There's a post in the DIY forums on how to replace the stud. . .replacement or extended.
cnk is offline   Reply With Quote
The Following User Says Thank You to cnk For This Useful Post:
BlaineWasHere (05-19-2013)
Old 05-19-2013, 11:22 PM   #3
Squishy
Drives: 2013 WRB BRZ
Honestly I would think you should have no problems with the upgraded ARP studs.
The stock wheel studs seem weak. I see metal shavings constantly when taking my tires off when working on the car or changing suspension settings (only torquing at 80 ft/lbs). Stripping the studs over time it will just fail eventually. Never had this problem on any of my previous cars (97 turbo miata, 06 STI, 09 Z06). The miata stood up a lot better than I thought it would being an older car.
Squishy is offline   Reply With Quote
The Following User Says Thank You to Squishy For This Useful Post:
Old 05-19-2013, 11:37 PM   #4
Doborder
Godzilla Konvert
Doborder's Avatar
Drives: DMG BRZ Limited 6MT 2013
I did the exact same thing day 2 after owning my car
I just got a new stud at the dealership $20 plus new lug
http://www.ft86club.com/forums/showthread.php?t=35949
2013 Subaru BRZ Limited MT (DMG)
CO>CA Cartel
Doborder is offline   Reply With Quote
Old 05-20-2013, 07:25 PM   #5
BlaineWasHere
Grip>Drift
Drives: FRS
So I picked up FIVE studs from the Subi dealer for $2.17 each! Toyota wanted $7 each and they don't even stock them so 4 day lead time!
I assume Subi stocks them because they are the same as WRX studs, I also assume that's why Toyota charges more because I bet they buy them from Subaru.
I'm autoXing again next MONDAY so I wanted to get rolling on it ASAP!
Old 05-20-2013, 07:31 PM   #6
norsamerican
norsamerican's Avatar
Drives: WRB BRZ
If you used an impact gun and run the lug up quickly it is easy to cross thread or jump threads.
Too much torque caused by bouncing on a torque wrench or overtorquing can also stretch the lugs.
Old 05-20-2013, 07:39 PM   #7
BlaineWasHere
Grip>Drift
Drives: FRS
I'm 99% certain the later of what you described is what I did. I was just being quick and careless. Lesson learned.
Old 05-20-2013, 07:40 PM   #8
danthedirt
Hadouken
danthedirt's Avatar
Drives: Whiteout FR-S
Just curious what kind of lug nuts are you using?
Whiteout MT
Car Blog: downrightfrs.blogspot.com/
danthedirt is offline   Reply With Quote
Old 05-20-2013, 08:03 PM   #9
sw20kosh
Drives: 2013 Black FR-S
Yeah had to replace my studs with ARP extended studs after a track day. They were stretching. Stock studs are weak.
Old 05-20-2013, 09:17 PM   #10
mla163
Overthinking it
Drives: BRZ in CS
For the last few cars I've raced, I keep a few spare studs around just in case. Better to have them and not use them then need them and not have them.
mla163 is offline   Reply With Quote
Old 05-20-2013, 10:05 PM   #11
BlaineWasHere
Grip>Drift
Drives: FRS
Yeah, I'm gonna put these in so I can autoX Monday but I'm pretty sure I'm gonna order ARP extended studs soon. I wanna have the flexibility to run 5mm spacers for brakes or whatever going forward also.
Old 05-21-2013, 01:42 PM   #12
SeeSharkySwim
SeeSharkySwim's Avatar
Drives: Scion FRS
some aftermarket steel lug nuts are made of material often times stronger than the stud itself which can lead to strip/cross threading if installed improperly.
SeeSharkySwim is offline   Reply With Quote
Old 05-21-2013, 05:12 PM   #13
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
Did you have any anti-seize or lube on those threads? I don't see any.
Old 05-21-2013, 05:43 PM   #14
BlaineWasHere
Grip>Drift
Drives: FRS
I don't ever use any lube or anything on the threads. Last thing I need is lugs coming loose at autoX or the track!!
I Messed up my bumper, so I fixed it SkitterSkotter Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 54 03-25-2015 08:03 PM
Dealership messed up on radio ayliu Scion FR-S / Toyota 86 GT86 General Forum 20 10-25-2012 10:43 AM
Lug Nut Stud feldy Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 1 09-22-2012 10:26 PM
So the dealer messed up... koolhawk BRZ First-Gen (2012+) — General Topics 26 06-18-2012 08:19 PM
Messed up? You decide. Godzilla35 Scion FR-S / Toyota 86 GT86 General Forum 66 05-15-2012 02:20 PM
