Old 04-28-2014, 03:00 AM   #939
CSG Mike
CSG Mike's Avatar
Originally Posted by u/Josh View Post
I plan to start tracking my car fairly regularly (~1 per month) and Im considering buying an Essex sprint kit rather than just upgrading pads and fluids. I would be doing it purely for the decreased consumables cost.
The question I have is, I know the CSG car used to have a sprint kit, but I think the new car is using stock brakes with upgraded pads, why?
We may have upgraded to an Endurance kit...
YMWV (your mileage will vary), but at the pace we run our car, we WILL fade the sprint kit. Rather than using ducting, the superior solution is a larger brake system that will reach equilibrium without the need for ducts. Ducts will lower the equilibrium point, but at the cost of larger temperature swings, which cause rotors to crack when you're getting them glowing hot the way we are. The Endurance kit also includes duct openings, so if we DO need to add ducts later, the base points are already there and we just need to add tubing. #doublewinning
You are correct, the BBK reduces operating cost in the long term, significantly. Let us know when you're ready to purchase.
AZP Installs (04-28-2014), Chazzzy (09-14-2016)
Old 04-28-2014, 03:03 AM   #940
CSG Mike
CSG Mike's Avatar
Originally Posted by ZDan View Post
My same point still applies. With stiffer springs, you'll want *stiffer* sways, not NO sways, in order to sufficiently augment roll stiffness. That is, if you don't want the suspension travel you use in cornering to be greater than that used under braking.
No sway/anti-roll bars => you're either softer in cornering than ideal or stiffer under braking than ideal.
Remember that our range of articulation is significantly smaller
Old 04-28-2014, 10:16 AM   #941
Porsche
Drives: 2013 BRZ Ltd. MT
Originally Posted by solidONE View Post
Could this not be avoided by adding sufficient amount of camber?
I expect Mike can sell you the components to optimize the front camber to achieve the best balance of grip and tire wear.
You write very well, sir. Do you have a blog or something? Maybe you should consider, if not.
I do not have a blog. However, I appreciate this compliment. That was very thoughtful of you. Thank you.
And thank you, too, for not taking offense at my using you as a foil to make a few points that I think would apply to the majority of drivers first getting started in performance driving. Your experience and exuberant approach mirrors most drivers at the beginning of their careers.
I tend to think Mr. Rod Millen to be brave, skilled, and old in equal parts. lol
I hear ya. LOL. Pro rallying, racing though the woods inches from the trees and teetering on the brink of major drop-offs, not to mention Pikes Peak... Yikes! Those guys are not so much brave as downright CRAZY!
Real racing should have consequences. They have that in abundance in that domain, don't they?
I have huge respect for those guys.
And how about that Isle of Man TT? Now that's racing. That's like back in the "good old days." Dangerous as hell ... but I miss watching that.
Porsche is offline   Reply With Quote
The Following 3 Users Say Thank You to Porsche For This Useful Post:
CSG Mike (04-28-2014), kavanagh (04-28-2014), solidONE (04-28-2014)
Old 04-28-2014, 11:39 AM   #942
gramicci101
Off Topic
...which cause rotors to crack when you're getting them glowing hot the way we are.
Pics?
Old 04-28-2014, 12:29 PM   #943
orthojoe
Originally Posted by gramicci101 View Post
Pics?
Did someone say glowing stock rotors?
[ame="http://www.youtube.com/watch?v=FTtxaoL14oE"]Subaru BRZ at Laguna Seca - YouTube[/ame]
2013 Subaru BRZ
orthojoe is offline   Reply With Quote
The Following 10 Users Say Thank You to orthojoe For This Useful Post:
bedabi (05-02-2014), CSG Mike (04-28-2014), gramicci101 (04-28-2014), hyper4mance (04-29-2014), jonnyozero3 (04-28-2014), juliog (04-28-2014), Porsche (04-28-2014), solidONE (04-29-2014), troek (04-28-2014), TylerLieberman (05-25-2014)
Old 04-28-2014, 02:07 PM   #944
CSG Mike
CSG Mike's Avatar
Pics?
Check out the CSG Facebook page... but here's a few from there.
This also illustrates brake balance adjustments via pad compound. The top car is running properly balanced pads, whereas the bottom car only has front race pads on (with a Sprint BBK).
The Following 3 Users Say Thank You to CSG Mike For This Useful Post:
Chazzzy (09-14-2016), gramicci101 (04-28-2014), WoOosOn (04-28-2014)
Old 04-28-2014, 07:40 PM   #945
solidONE
solidONE's Avatar
Drives: FR-S Whiteout
Well... there is some slop in the stock toe adjuster, so I wouldn't go as far as calling it useless. IMO It's more 'insurance' and getting rid of the redundant stock adjuster once you add toe arms.
Since I failed to measure the front height the last time I was checking the rear toe setting to account for the effect of change in rake I think I will make it a point to do some more experimenting and visit sears a few more times. Hurray for free alignment checks!
Drove my car to near empty to Sears and took out the spare and tools before getting my free check. This was came out of their machine this time.....
So much for getting free alignment confirmations from Sears...
Old 04-28-2014, 08:03 PM   #946
solidONE
solidONE's Avatar
No offence taken. It's true, I'd give my left pinkie if I knew that will shave a good 10-15 seconds off my average lap times. I'm just surprised that there are not more guys like me. I assumed all enthusiast to think much like I do. I openly acknowledged my level of "suckage" on the track even before I posted on this thread. The lack of budget, time, experience and budget puts me in position I'm in. I've worked with cars and car related stuffs for years hoping to get a chance/excuse to drive one on a racetrack. Thank God it has become so much more accessible now. I'm not as young as I may appear to be. Maybe just "young" in the bank account. lol
Isle of Man is for lunatics... I love it!
The Following User Says Thank You to solidONE For This Useful Post:
Old 04-28-2014, 08:14 PM   #947
gramicci101
Off Topic
That looks like so much fun! I can't afford to play those games.
Old 04-28-2014, 08:22 PM   #948
ayau
Drives: Some rust bucket
Track days are definitely not for your average budget even if you drive some beat up Civic. I think that's one of the reasons people do autocross instead even though the driving time is much less. It's still cheaper nonetheless.
Even karting can get pretty expensive depending how serious you want to get. Bottom line, all hobbies are a drain and a waste of money.
Old 04-28-2014, 08:46 PM   #949
krl
Drives: blue brz
Mike,
Got any suggestions for pads in rear stock brakes to match essex sprint kit up front with porterfield r4-s pads?
- Keith
krl is offline   Reply With Quote
Old 04-28-2014, 09:57 PM   #950
CSG Mike
CSG Mike's Avatar
Mike,
- Keith
Use the same compound in the rear... I'm not sure they make the fitment.
Old 04-28-2014, 10:27 PM   #951
gramicci101
Off Topic
If you're running something like a sprint or endurance kit in the front, is running the OEM rear setup with a matching pad compound really going to provide proper balance to the brake system?
Old 04-28-2014, 11:42 PM   #952
Porsche
Joe, your videos are some of the most thoughtfully edited and best assembled on the web. They are just marvelous and I always enjoy them. Not many videos are worth repeated viewings, but yours sure are.
Thank you for the effort that you put into these "professional" productions.
The Following User Says Thank You to Porsche For This Useful Post:
orthojoe (04-29-2014)
Simple question, hard to find answer... Mango22 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 5 05-16-2013 06:23 PM
Silly question about protecting track rims sw20kosh Tracking / Autocross / HPDE / Drifting 16 04-25-2013 12:34 PM
Asking the question that I already know the answer to. Are the engines the same? Bigmaxy Engine, Exhaust, Transmission 10 01-19-2013 07:47 PM
Random dog-related question for those who have their BRZ GMU-BRZ BRZ First-Gen (2012+) — General Topics 11 05-31-2012 07:48 AM
Got my answer - BRZ comes with HID headlights as STD Z_Rocks BRZ First-Gen (2012+) — General Topics 20 01-10-2012 09:54 AM
