Old 04-22-2014, 12:56 PM   #29
OrbitalEllipses
Drives: Attitude
Originally Posted by JRitt View Post
Hi Guys,
Here is something I wrote for our blog a while back:
Drilled vs. Plain vs. Slotted brake discs
I think that summarizes it pretty well.
Would you mind expounding upon us the pros and cons of external vs internal fluid crossover tubes?
Old 04-22-2014, 02:04 PM   #30
Mikepage
Mikepage's Avatar
Drives: Scion FR-S 2013 Raven
Slotted vs Plain Discs
Formula 1 use plain disk http://www.formula1.com/inside_f1/un...port/5284.html
I know they are in fibre composite but anyway...
o= FR-S =o
Mikepage is offline   Reply With Quote
Old 04-23-2014, 08:36 AM   #31
JRitt
JRitt's Avatar
Drives: 2012 BRZ Premium WRB 6MT
Sure.
External crossover tubes / pipes
Pros
  • Easier to bleed- air bubbles don't get trapped as easily inside the external pipes
  • Caliper can be easily swapped to leading or trailing (switch the pipe with the bleed screws).
  • Caliper is less expensive to manufacture and machine with external tubes
  • Easy to repair if damaged- remove the pipe and replace it
  • If debris gets inside, it's easy to remove- take the tube off and clean or replace
Cons
  • More parts (and part numbers) add to the complexity of the caliper...basically more bits and pieces to be broken and replaced
  • Since it is exposed, pipe can get damaged during a wheel change, or by road/track debris (rocks, pieces of other cars, etc.).
  • Adds a slight amount of weight
  • limits caliper design to a more conventional rectangular shape
Internal crossover tubes / pipes
Pros
  • Allows for asymmetrical caliper design (AP Racing Radi-Cal is a good example)
  • Reduces possibility of crossover being changed during a wheel swap or by debris (this is one of the reasons why you see internal in a race series with frequent wheel changes (NASCAR), or in rallying).
  • Reduces weight- Also critical at the higher levels of racing
  • Reduces number of spare parts to hold on hand
Cons
  • Can be more difficult to bleed- air bubbles can get trapped in the recesses of the calipers, and generally tougher to get that air out
  • Caliper is more intricate and expensive to manufacture
  • Can't easily be swapped from leading to trailing.
  • Would be more difficult to remove any contaminants if they got inside
  • Caliper is trashed if crossover section gets crushed
Essex Parts Services- AP Racing / Ferodo / Spiegler / Versodeck
Jeff Ritter|Mgr.- High Performance Division
www.essexparts.com
JRitt is offline   Reply With Quote
The Following 4 Users Say Thank You to JRitt For This Useful Post:
2point0 (04-23-2014), major quicknap (04-24-2014), OrbitalEllipses (04-23-2014), Shankenstein (04-23-2014)
Old 04-28-2014, 01:54 AM   #32
PoWn3d_0704
PoWn3d_0704's Avatar
Drives: 1990 BNR32 GTR
I bought a BBK from Wilwood and really wanted the drilled rotors for the bling, but y'all convinced me that they crack, so I settled for slotted rotors for just a bit of bling, while staying as stong as possible.
I really like the idea of using the slots as a gauge for rotor replacement.
Picked up my BRZ on 6/11/13.
Build Album:
PoWn3d's BRZ Pictures
Build Thread: PoWn3d's BRZ
PoWn3d_0704 is offline   Reply With Quote
Old 04-28-2014, 06:25 AM   #33
Model Citizen
Lacking brains
Drives: frz
Instead of asking "blanks vs slotted/drilled", ask yourself why you think you need to upgrade/change your rotors.
What are you trying to achieve?
All I know is, I'm buying some spatulas now.
I had a hard tim tracking down the specific silicon ones locally.
Ended up finding at bed bath and beyond $10 each.
Didnt like how all the walmart ones couldnt be bent as desired
Model Citizen is offline   Reply With Quote
Old 04-28-2014, 05:42 PM   #34
Andrew025
Andrew025's Avatar
Drives: Neptune GR86
I just ordered some replica ebay spatulas.
Full review in 60 days when they get here from China.
Old 04-28-2014, 06:26 PM   #35
2point0
2point0's Avatar
Drives: '13 BRZ Ltd WRB
Will you be making pancakes? I want pancakes!
2013 BRZ Limited - SOLD
2008 Forester XT Sports
1967 Mustang Coupe - 289 V8
2point0 is offline   Reply With Quote
Brake Discs Rusting FRSNewb Suspension | Chassis | Brakes -- Sponsored by 949 Racing 27 04-02-2014 09:49 PM
dislike your plain Toyota key? check my custom flip tibsy92 AUSTRALIA 38 02-22-2014 09:24 PM
Endless Discs OnionTou Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 11-25-2013 11:54 AM
10 series after trading in plain-jane FR-S NetMagi Scion FR-S / Toyota 86 GT86 General Forum 84 11-05-2013 04:12 PM
Gt to gts brake discs acro AUSTRALIA 2 11-09-2012 05:04 PM
