Old 04-19-2014, 12:34 AM   #1
major quicknap
Drives: blue sardine
Slotted vs Plain Discs
From what I have read on the infonet the reason for slots have been the same since forever. After reading through this thread http://www.ft86club.com/forums/showthread.php?t=62847 I'm wondering if the use of slots in discs is an anachronism from when materials weren't as advanced as now or if the slots still have a benefit on discs that see a hard time.
Captain Snooze sends his regards.
major quicknap is offline   Reply With Quote
The Following User Says Thank You to major quicknap For This Useful Post:
ZionsWrath (04-19-2014)
Old 04-19-2014, 08:24 AM   #2
wparsons
wparsons's Avatar
IMO, 99% of people are better off with plain solid rotors and the few that could actually benefit from slotted or hooked rotors know why and are fine with the potential downsides.
flickr
The Following 2 Users Say Thank You to wparsons For This Useful Post:
Mikepage (04-22-2014), ZionsWrath (04-19-2014)
Old 04-19-2014, 09:26 AM   #3
ZionsWrath
Thanks
ZionsWrath's Avatar
I see many posts similar responses equating to "if you have to ask you probably don't need it". That's cool and maybe true, but maybe explain why we don't need it?
Please elevate our knowledge to the 1%, even if our skill is in the 99%.
The Following User Says Thank You to ZionsWrath For This Useful Post:
major quicknap (04-19-2014)
Old 04-19-2014, 09:33 AM   #4
STV3
Señor Member
STV3's Avatar
I've read an article where they tested plain vs slotted vs slotted and drilled and the plain face rotors performed the best and the slotted and drilled performed the worst. IIRC the rotors that were just slotted performed about the same as the plain faced ones with no added benefits.
STV3 is offline   Reply With Quote
The Following User Says Thank You to STV3 For This Useful Post:
Old 04-19-2014, 09:35 AM   #5
STV3
Señor Member
STV3's Avatar
I'll admit I like running slotted rotors because they look cool and are a lot less prone to cracking than slotted & drilled are
The Following 2 Users Say Thank You to STV3 For This Useful Post:
Freeman (04-21-2014), ZionsWrath (04-19-2014)
Old 04-19-2014, 11:45 AM   #6
gramicci101
Off Topic
Slotted and drilled rotors were originally created back in ye olden times when brake pads would create significant amounts of gas as they heated up. It was known as off-gassing, and had the potential to trap pockets of gas between the pad and the rotor, effectively neutralizing your braking ability and making for a much more eventful drive. The slots or holes were cut as a way for the gasses to escape, which allowed you to smoothly brake to a stop with a confident smile on your face instead of careening wildly into your girlfriend's parents. New pads don't have the same off-gassing problem, so that need for slots or holes has been removed.
People will say the slots or holes will allow heat to escape, but they're wrong. A rotor is a massive heatsink, and by removing rotor material you're removing material available to absorb heat. Heat escapes through the rotor's interior vanes as air from your brake ducts flows across them. You have installed brake ducts, right?
Track junkies have noticed that slotted rotors will give more bite to the pads, because you've got that nice sharp machined edge of the slot digging into the pad, instead of the flat shiny surface of a blank rotor. I can't comment on that, because I'm just not that cool.
Drilled rotors (or cast with holes, for you pretentious types) are there because they look cool. Or so the driver of the '95 Honda Civic thinks. Drilled or cast holes provide a convenient location for cracks to start, as they create a stress point on an otherwise serviceable rotor. I've never heard of anyone sticking a stainless steel pin into the drilled holes as a prank, and most certainly have never done so myself. Ever. Because that would be wrong.
The Following 3 Users Say Thank You to gramicci101 For This Useful Post:
FRS-HHH (04-20-2014), mikepaul21 (04-19-2014), ZionsWrath (04-19-2014)
Old 04-19-2014, 12:02 PM   #7
supramkivtt2jz
PROUD OF BOXER
Drives: Raven FR-S
This thread is vomit inducing.
supramkivtt2jz is offline   Reply With Quote
The Following User Says Thank You to supramkivtt2jz For This Useful Post:
Old 04-19-2014, 01:09 PM   #8
2point0
2point0's Avatar
Drives: '13 BRZ Ltd WRB
I suppose it could be argued that since slotted rotors have more surface area, they make a marginally better heatsink. But really, it just looks neat.
2013 BRZ Limited - SOLD
2008 Forester XT Sports
1967 Mustang Coupe - 289 V8
2point0 is offline   Reply With Quote
The Following User Says Thank You to 2point0 For This Useful Post:
ZionsWrath (04-20-2014)
Old 04-19-2014, 01:30 PM   #9
wparsons
wparsons's Avatar
It would be really interesting to see how the added surface area balances with the removal of mass with regards to thermal capacity.
flickr
The Following User Says Thank You to wparsons For This Useful Post:
Old 04-19-2014, 01:36 PM   #10
mikepaul21
mikepaul21's Avatar
Drives: 2013 Subaru BRZ
not questioning your reply (I just learnt everything you just stated) but why do so many exotic car companies that are always competing for the best track performance use drilled and slotted rotors on their vehicles.
mikepaul21 is offline   Reply With Quote
The Following User Says Thank You to mikepaul21 For This Useful Post:
Old 04-19-2014, 01:42 PM   #11
2point0
2point0's Avatar
Yeah, I can't believe it would be vastly different, but I also wonder how the air gaps within the slots affects heat transfer.
Old 04-19-2014, 01:56 PM   #12
zooki
Drives: waiting on a 2021...
Now most of them use carbon- ceramic or carbon-carbon brakes.
2016 4Runner Tail edition
2020 Camry 2020 RAV4
2013 Chevy 3500 4x4 Duramax
1999 Ford F250 Powerstroke, the tow rig
1969 Mustang, the fast car....(:
zooki is offline   Reply With Quote
The Following User Says Thank You to zooki For This Useful Post:
Old 04-19-2014, 02:43 PM   #13
gramicci101
Off Topic
I honestly don't know. I know a lot of them use carbon ceramic brakes (Z06, Porsche GT3, Ferrari F430 Challenge, etc...) so that may have something to do with it. Interestingly, the Porsche GT3 Cup uses steel rotors cast with holes, not drilled. Here are two pictures of GT3 Cup rotors starting to crack at the holes: 1, 2. I did find that holes help a little with bite and a little with cooling at the extreme top end of the temperature range, but that's a heavy track usage thing. And race cars' rotors will be replaced long before cracking becomes an issue.
I know GT-R owners have problems with their rotors cracking at the holes too. This thread has some pics of pretty sketchy rotor cracks originating at the rotors' holes. It also has pics of the elusive "spatula" brake cooling mod, which I found interesting. Remember kids: if it's stupid but it works, it might still be stupid. But hey, it works!
The Following User Says Thank You to gramicci101 For This Useful Post:
Superhatch (04-21-2014)
Old 04-19-2014, 03:10 PM   #14
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
Dude, that is epic. Good to know even GT-R and Lambo owners know how to ghetto rig. Haha
Brake Discs Rusting FRSNewb Suspension | Chassis | Brakes -- Sponsored by 949 Racing 27 04-02-2014 09:49 PM
dislike your plain Toyota key? check my custom flip tibsy92 AUSTRALIA 38 02-22-2014 09:24 PM
Endless Discs OnionTou Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 11-25-2013 11:54 AM
10 series after trading in plain-jane FR-S NetMagi Scion FR-S / Toyota 86 GT86 General Forum 84 11-05-2013 04:12 PM
Gt to gts brake discs acro AUSTRALIA 2 11-09-2012 05:04 PM
