Old 04-24-2014, 12:11 AM   #603
cslntuee
Drives: Subaru BRZ Limited
Originally Posted by krayzie View Post
Honestly I recommend doing the flexible tower bar first and then the springs. I didn't like the handling with the springs installed first, just me.
I did pink springs (more rotation) -> flexible tower bar (quicker turn-in) -> flexible draw stiffener (corners on rails) -> will get the pillowball trailing and lateral link kits installed next week (the catalog says this provides more rear end grip on uneven surfaces, I've already spent $60 bucks on non-reusable nuts and bolts at Subaru ugh).
Every part seems to change the steering response a little bit.
I think the next route is to get all of the hard rubber mounts and bushings but I can't imagine the labor costs.
What's the material for STI flexible draw stiffener (ex. steel, aluminum..etc)?
Thanks.
cslntuee is offline   Reply With Quote
Old 04-24-2014, 05:03 AM   #604
Khazzy
Khazzy's Avatar
Drives: SWP Subaru BRZ
Great...just ordered some more interior goodies...I need to stop
Said no one ever
2013 SWP BRZ full STi Lip kit installed. Tons of other mods from interior to exterior. One of the cleanest BRZ's around in the midwest! Enjoy the build thread below.
Full of pictures, exhaust clips, garage shots, and walk around video encasing its beauty.
The Following 2 Users Say Thank You to Khazzy For This Useful Post:
chanomatik (04-24-2014), Createddeleted (04-25-2014)
Old 04-24-2014, 05:03 AM   #605
krayzie
Drive From Home
krayzie's Avatar
Drives: BRZ STI Performance
Thanks.
Stainless steel length adjustable rods and lock nuts, damper units are aluminum housings with elastomers, rubber bushings for the screw attachments at each end. The attachment brackets are painted black steel, and two slightly longer unpainted steel replacement bolts at the subframe attachment points (to accommodate for the increase in thickness with the added bracket).
The fine length adjustments are in millimetres (mine are adjusted exactly the same on both sides because my chassis was relatively new during install, I think the design allows for 13mm in length adjustment iirc), the draw stiffeners are designed to have about 3mm of damper travel during use. The Japanese instructions specifically warned to have the lengths adjusted properly to avoid chassis damage during use. However, it never explained why the damper units are at opposite ends for left vs. right side on the BRZ (maybe it did as I don't know Japanese - knowing Chinese helps with understanding the kanji characters), with the other models in the line-up left and right sides are mirrored instead (the Forester chassis is stiff enough to not require draw stiffeners).
This is a very tricked performance part once you realize the installation instructions.
krayzie is offline   Reply With Quote
The Following 2 Users Say Thank You to krayzie For This Useful Post:
chanomatik (04-24-2014), cslntuee (04-24-2014)
Old 04-24-2014, 07:32 AM   #606
ricerocket93
More tease
http://www.japanparts.com/db/parts_d...&SEARCH_page=2
ricerocket93 is offline   Reply With Quote
The Following 2 Users Say Thank You to ricerocket93 For This Useful Post:
lxs (04-28-2014), mister.bond (04-24-2014)
Old 04-25-2014, 12:59 PM   #607
BRZtoni
Turbo E85
BRZtoni's Avatar
Drives: 13 wrb brz
^^OMG!!!!!!!!
BRZtoni is offline   Reply With Quote
Old 04-27-2014, 12:41 PM   #608
AznBRZer
Drives: 16 CBS WRX Limited
For those that have a CBS BRZ and got the new tS fender garnish, are any of you looking to get rid of the original ones with out the chrome? I'm looking specifically for the driver's side. A body shop bent mine and I honestly don't feel like going back there again. I figure it's easier just to deal with this myself. I'll take the pair if the price is right.
AznBRZer is offline   Reply With Quote
The Following User Says Thank You to AznBRZer For This Useful Post:
Kostamojen (04-28-2014)
Old 04-28-2014, 07:26 AM   #609
mister.bond
Drives: BRZ Subaru
Can anybody
(ok, one person must not , he do not like to answer my questions )
explain to me these NEW listed Parts, please ????
I do NOT understand the functions of them !
Japanparts Link to the new Parts :
http://www.japanparts.com/db/parts_d...&SEARCH_page=1
mister.bond is offline   Reply With Quote
Old 04-28-2014, 09:21 AM   #610
Beyer Subaru
Drives: 2013 BRZ SWP 6AT Ltd
Originally Posted by mister.bond View Post
Can anybody
Those are prolly necessary to install the STi Steering Rack Bushes - http://www.japanparts.com/db/parts_d...=16&submit.y=4
Beyer Subaru is offline   Reply With Quote
Old 04-28-2014, 11:48 AM   #611
Createddeleted
Drives: 2014 BRZ - 2004 GLI
Can anybody
I requested this to be added. You're welcome
These are the bolts to stiffen up/ reinforce the rack. Basically the bolt threads all the way in and goes through a spacer on the other side of the subframe.
Comparison to OEM bolt
Location of bolts
Parts you will need
Installed pic
Here are some sites that helped describe all of this:
http://minkara.carview.co.jp/en/userid/237585/blog/
http://ameblo.jp/zn6-86-fa20/entry-11811708796.html
http://minkara.carview.co.jp/en/userid/769683/car/1310119/2692460/note.aspx
Createddeleted is offline   Reply With Quote
The Following 15 Users Say Thank You to Createddeleted For This Useful Post:
Beyer Subaru (04-28-2014), chanomatik (04-28-2014), cslntuee (01-19-2015), FearBoy (07-08-2014), Fly Guy (05-17-2014), Guillaume (04-29-2014), Hanakuso (05-19-2014), illmatic (04-28-2014), krayzie (04-28-2014), RiskyTrousers (05-18-2014), SpeedyJay (05-16-2014), switchlanez (04-28-2014), Totality (07-12-2014), troek (06-24-2014), unsurety (06-18-2014)
Old 04-28-2014, 11:55 AM   #612
Createddeleted
By the way, this could probably be done for much cheaper (if you didn't care about OEM) as the bolt size is given on the package and the nut is a standard Subaru part. I only need to see the sizing on the spacer.
Old 04-28-2014, 01:50 PM   #613
Beyer Subaru
You just gotta make sure it's at least a Grade 8 Bolt you're using.
Old 04-28-2014, 01:58 PM   #614
switchlanez
Glorious BRZ Master Race
switchlanez's Avatar
Drives: Subaru Libird
Whoa seems like a simple mod that may make a HUGE difference in steering
Old 04-28-2014, 02:04 PM   #615
mister.bond
Drives: BRZ Subaru
THANK YOU; but please excuse me about asking again.....
what is the result when i buy and install the stuff ????
what happens to my steering then ????
Old 04-28-2014, 03:21 PM   #616
Createddeleted
Stiffer rack = steering that gives more feedback/ feels more direct.
Can't say if you will actually feel a difference or not. Depends how you drive your car.
The Following User Says Thank You to Createddeleted For This Useful Post:
Trap63 (04-28-2014)
it sucks to be broke, sti omg!
WTB: Parts for my FR-S hyperpunx Interior Parts (Incl. Lighting) 1 03-05-2013 05:28 PM
[Group Deals] SoCal Subaru BRZ parts or Any Parts Giccin Southern California 25 08-26-2012 10:30 AM
