Old 03-30-2012, 08:51 AM   #1
ft86Fan
ft86Fan's Avatar
Drives: FR-S, Exige S, Miata
Which oil filter for the FA20?
Does anybody know which oil filter they will be using for the FA20? I want to get some Mobil 1 oil filters so if we know which Subaru oil filter they use we can find the comparable Mobil 1 filter. Thanks.
'13 Scion FR-S (Whiteout)
'07 Lotus Exige S (Aspen White) Touring, Traction, Starshield
'95 Miata (Montego Blue)
ft86Fan is offline   Reply With Quote
Old 03-30-2012, 12:47 PM   #2
old greg
Rocket Surgeon
Drives: PSM GGA OMG
Looks like the larger ~80mm filter, M104 in Mobil1 parlance.
Are they on sale for 50% off or something? Why not just wait and know for sure?
old greg is offline   Reply With Quote
Old 03-30-2012, 12:54 PM   #3
ft86Fan
ft86Fan's Avatar
Thanks old greg. Haha, no they are not 50% off but I need to get oil for my BMW and I usually get the Mobil 1 5qts + oil filter deal. The BMW uses paper filter so I usually get the oil filter for other cars.
I wish it would be the M104. I still got a bunch of them for the S2000 that I've sold.
Old 03-30-2012, 01:39 PM   #4
Calum
That Guy
Drives: 2013 asphalt FRS MT
I've been waiting for this info as well. I'd like to know so I can talk to CM filters about a paper filter setup that will work with the recessed filter location. If anyone has a firm answer please post up.
Old 03-30-2012, 05:18 PM   #5
old greg
Rocket Surgeon
Drives: PSM GGA OMG
After squinting at some engine bay pics, the P/N appears to be 15208AA130 which is the filter that comes from the factory on the FB motors.
Old 03-30-2012, 05:26 PM   #6
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
That would be awesome if it's the M104 size. I have plenty for the Integras sitting around (that and the K&N version, since both are made by the same company). That'll be a lot easier to stock filters when advance does their sales.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 03-30-2012, 05:48 PM   #7
Ryephile
Hot Dog
Ryephile's Avatar
Drives: quicker than arghx7
I would expect the oil filter to have a check valve installed [like the VW TSI 2.0T] so it doesn't spill any oil as you unscrew it. Not having something like that would be asinine with regards to the inverted positioning.
"Wisdom is a not a function of age, but a function of experience."
Just Say No to unqualified aftermarket products.
Ryephile is offline   Reply With Quote
Old 03-30-2012, 05:52 PM   #8
GrimmSpeed
GrimmSpeed's Avatar
Drives: '13 BRZ, '12 WRX
Send a message via AIM to GrimmSpeed Send a message via MSN to GrimmSpeed
Definitely would be nice to have some sort of valve, but not end of world if it doesn't....just got to slow your unscrew at the end.
Justin
GrimmSpeed is offline   Reply With Quote
Old 03-30-2012, 06:15 PM   #9
Draco-REX
Corner Junkie
Draco-REX's Avatar
Drives: 13 BRZ, 11 STI, 99 RS
There is a lip around the base of the filter. It essentially sits in a cup.
Old 03-30-2012, 06:24 PM   #10
Ryephile
Hot Dog
Ryephile's Avatar
I guess time will tell if they made oil changes clean and tidy or an under-engineered mess [i.e. Miata].
Old 03-30-2012, 07:09 PM   #11
ft86Fan
ft86Fan's Avatar
Checking the Mobil web site the Impreza uses the M108 so I guess thats what the FA will use :-( Hope they let me change the M104 to M108. I got like a case of them.
http://www.showmetheparts.com/mobil/
Old 03-30-2012, 07:48 PM   #12
old greg
Rocket Surgeon
Drives: PSM GGA OMG
It's definitely not going to be the M108, the new style filters are much larger than the old ones, which themselves are much larger than the M108.
Shitty old-school Honeywell (Fram) blue OEM EJ filter next to a shiny, well made Tokyo Roki OEM FB/FA oil filter (PN: 15208AA130) in Black .
And while I was digging around, I found this. It's an FB25 with a K&N HP1004 (equivalent to an M104).
That said, you're probably better off sticking to the OEM filter once you use up your stash of M1's. Tokyo Roki makes high quality filters and Subaru specifies a stupidly high bypass valve pressure, meaning that aftermarket filters will be allowing a lot more oil to bypass the filter element than Subaru recommends. The Tokyo Roki OEM filters are valved to Subaru specs, are very solidly built and they're only ~$6.50.
The Following 11 Users Say Thank You to old greg For This Useful Post:
baldolera (06-16-2012), Bristecom (06-28-2012), Dr.Science (05-12-2012), Extreme86 (05-31-2012), Fly Guy (05-19-2012), houseofsuffering (05-30-2012), hyper4mance (06-11-2012), kwood9000 (05-30-2012), lordtakuban (06-25-2012), phm14 (06-16-2012), TwinscrollGT35R (05-30-2012)
Old 03-30-2012, 09:57 PM   #13
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Toyo roki filters are awesome. I'll probably use it on my Hondas too since Honda switched to junk fram filters as well. I, or someone else should cut one of these open to see how it compares to the old good toyo roki Honda filters
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 03-31-2012, 11:53 AM   #14
ft86Fan
ft86Fan's Avatar
Old Greg, you are absolutely right. I've done some research and the new FB25 engine uses the Tokyo Roki OEM oil filter (PN: 15208AA130). This is the filter used in the 2011 Forester 2.5X models equipped with the FB25 non-turbo engine. The turbo still uses the small blue crap filter. Our FA engine will also be using this new Tokyo Roki oil filter (PN: 15208AA130) and the equivalent Mobil1 oil filter is M104. Now that you mentioned that Tokyo Roki oil filters are better than the Mobil1 filters I might have to take your advice.
Early proposal: FA20 with a FB25 shortblock, .5l more displacement anyone? Kostamojen Engine, Exhaust, Transmission 90 03-20-2022 06:05 PM
FA20 OEM pistons, are they Forged or Cast ? adprokid Engine, Exhaust, Transmission 54 10-11-2014 05:51 PM
Turbocharged FA20 targeted for 270hp. Confirmed for next gen WRX Hachiroku Engine, Exhaust, Transmission 50 12-10-2011 01:23 PM
FA20 for sale coyote AUSTRALIA 1 12-01-2011 12:53 AM
