Old 04-25-2014, 07:55 AM   #29
hamzam
Proud dad of 2 boys :)
hamzam's Avatar
Drives: Firestorm 6-MT
Originally Posted by yo joshman View Post
Glad its resolved
It's back.... unfortunately.
My brake lights work however. Nannies are off. No driving in rain for me
I have to wait for the dealer. Definitely going to make them replace the stuck brake switch located above brake pedal.
hamzam is offline   Reply With Quote
Old 04-25-2014, 10:19 PM   #30
yo joshman
yo joshman's Avatar
Drives: ae86/frs
Weird..keep us posted im interested to know what becomes of this problem
yo joshman is offline   Reply With Quote
Old 04-27-2014, 12:27 PM   #31
hamzam
hamzam's Avatar
I think I solved it
I installed front camber bolts yesterday, and noticed that the front sway bar bracket, right-side, front-bolt, was loose!
This also explained the creaking in the front right (going over bumps, pulling into a driveway on the right), which I dismissed for polyurethane bushings.
After testing the neg. camber up front around the neighborhood, everything torqued to spec :p, the squeaking was loud enough that I was not going to be taking the car anywhere knowing there was a bigger issue at hand.
And voila, under a hard brake to a full stop, the ABS / Traction Control lights both came on.
Then it hit me the play in the bracket was causing this light to come on as soon as there was enough load to jiggle it.
This morning, I removed the front sway bar, properly tightened the bracket bolt, and torqued everything else down to spec. as well, including rear sway bar brackets/endlinks.
After a rigorous hour in the twisties, I did not see the light go on. I even tested the brakes, (braking improved significantly with neg. front camber), coming to a full, hard stop several times.
No issues at all, I am happy to report.
Old 05-10-2014, 05:49 PM   #32
Tt3Sheppard
Tt3Sheppard's Avatar
Drives: Whiteout FR-S
After car wash wheels were sprayed and the same three lights came on again. I'm going to assume it's the wheel sensor again. Hopefully when it dries it will reset itself
2013 Ford Focus St
2013 Scion FR-S
2007 Honda Civic Si
2003 Acura RSX Type-S
1998 Ford Escort ZX2
Tt3Sheppard is offline   Reply With Quote
Old 05-26-2014, 04:50 AM   #33
DGMlJDlBRZ
DGMlJDlBRZ's Avatar
Drives: 2014 DGM BRZ
Anyone else have other ideas/opinions on what could cause the Traction light and ABS light to turn on?
It just happened to me tonight while coming to stop at a red light.
I figured instead of making a whole new thread with basically the same issue, I'd just post in here.
Anyways, the lights turned on while driving. I pulled over and shut the car off. Let it sit for about a minute and started the car up again. Lights went away, but shortly after taking off and stepping on the brake pedal, both lights came back on. I did this about three times on my way home.
When I got home, I noticed that my brake lights weren't working either. Parking lights, reverse lights, and turn signals all work fine. Checked the 7.5A brake light fuse underneath the dash, and it was blown. Replaced it with a new one, stepped on the brakes, and they still didn't work. Checked the new fuse, and it was blown as well.
My car does have JDM TOMS tail lights and the Valenti rear brake/fog light/reverse light (modified it for the triangle to stay off and flash/light up when brake pedal is pressed...V light works fine along with parking lights on taillights)
My driver side tail light connector wires on the car harness side had to be resoldered because they tore apart when I installed he wire tap connectors supplied with the Valenti light.
So I will have to check all connections, but wanted to know could a short in the taillights or Valenti light cause the ABS light and Traction light to turn on? I want to say it could be the brake light switch as well so I'll have to check it also.
DGMlJDlBRZ is offline   Reply With Quote
Old 05-27-2014, 11:25 AM   #34
Wilso
"Patience young Padawan"
Drives: 2017 Crystal White BRZ
Originally Posted by hamzam View Post
I think I solved it
Have these lights on now after I just installed my coilovers. No noise from the front but I'm getting it from the rear. Do you think something isn't tight enough? The noise was a lot less now than it was last night after install. Had to drive it to get to work.
Wilso is offline   Reply With Quote
Old 05-27-2014, 12:00 PM   #35
Wilso
Originally Posted by Kakawate View Post
FYI my issue was a the brake switch fuse was blown. Now everything is back to normal all lights off. Check your fuses!
Probably due to a bad led on my BC tail lights. Covered by warranty and will be fixed next week
Which fuse was this? The one you installed when installing your tail lights?
I have clear Toms on
Old 05-27-2014, 01:08 PM   #36
hamzam
hamzam's Avatar
Hard to say, some coilovers (B.C, for example) are known to make some sounds.
Also, ultimately, I had to change my brake light stop switch (above brake pedal) to fix my problem.
Subaru also has a TSB on it, but not Toyota/Scion.
The Following User Says Thank You to hamzam For This Useful Post:
Wilso (05-27-2014)
Old 05-27-2014, 01:09 PM   #37
Kakawate
Man-ape
Kakawate's Avatar
Drives: 2013 Buddy Club Scion FR-S
It's in the fuse box under the dash it's a 7.5 amp fuse and if you look at the lid to the box you will see one that says tail I believe. I could be wrong I lost the lid lol.
Kakawate is offline   Reply With Quote
Old 05-27-2014, 01:14 PM   #38
Wilso
I couldn't see a switch, I'll have to look harder when I'm done work. Tried to run out and look quickly
Old 05-27-2014, 01:15 PM   #39
Wilso
Where under the dash? I swear I'm blind as f**k
Old 05-27-2014, 01:21 PM   #40
OrbitalEllipses
Drives: Attitude
BRZ owner's manual page 327. Driver's side, left knee area under the trim - has a lid over it.
Wilso (05-27-2014)
Old 05-27-2014, 01:23 PM   #41
Wilso
faaaaaaaaack I pulled the cover off the side between the door and dash.. didn't think about the inside part.. thanks!
Old 05-27-2014, 02:24 PM   #42
Wilso
So my brake lights work.. signals n all. I had a similar issue before, but instead of ABS it was the engine light and it said "system too lean". do you think it could be the same thing? Or just improper alignment and my ass is sitting too low due to my coil overs?
Traction/VSC Setting Preference ashtray BRZ First-Gen (2012+) — General Topics 27 08-24-2018 03:39 PM
TPMS warning light **New Info** sdiver68 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 29 10-11-2012 07:25 PM
TPMS and Traction Control Mavrik Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 10 08-02-2012 01:50 PM
traction control issue *KID* Scion FR-S / Toyota 86 GT86 General Forum 13 07-08-2012 08:13 PM
Disabling Traction Control (TC) and Vehicle Stability Control (VSC) Completely BabyGodzillaGTi-R BRZ First-Gen (2012+) — General Topics 40 04-25-2012 11:20 AM
