Old 06-25-2013, 04:39 AM   #1
ceebo
Drives: 2013 frs
rear rattling/clunking suspension noise
I just put on agency power rear lower control arms and got my alignment done so I wouldn't have tire wear. now the rear is making rattling noise on the passenger side. The funny thing is I hear it even when im going like 10 mph, but when I go on the freeway theres no noise. I never had this noise before I put the control arms on. anyone experience this problem? I wonder if I got crappy coilovers.
ceebo is offline   Reply With Quote
Old 06-25-2013, 11:59 AM   #2
ric342
FR-S driver
ric342's Avatar
Drives: ULTRAMARINE Scion FR-S
i have not put on coilovers yet but i had that clunk too the rattle is from the spot welds that are in the trunk just spray some wd40 and it will go away... it did for me
ric342 is offline   Reply With Quote
Old 07-24-2013, 05:07 AM   #3
ceebo
Drives: 2013 frs
thanks, i'll try that but it just don't make sense as to why the noise started only after i put the control arms on. In fact the noise is getting even worse
Old 07-24-2013, 05:13 AM   #4
nzer
nzer's Avatar
Drives: 2012 Grey TRD GT86, 2015 VW Golf R
Try this too - worked for me!
http://www.ft86club.com/forums/showthread.php?t=42065
nzer is offline   Reply With Quote
Old 07-25-2013, 04:10 AM   #5
ceebo
Drives: 2013 frs
The rear rattling noise is actually coming from the passenger side it sounds like my coilovers is hanging loose. its not rear deck noise, its coming from under the car. I just went to a shop and they said they couldn't figure it out cause they tightened whatever bolts they could find pertaining to the suspension. by the way what rear lower control arms are you running/
Old 07-25-2013, 04:49 PM   #6
x96nax
x96nax's Avatar
Drives: 96 Black MX5
Maybe there's some give in the control arms you installed?
Life's too short to dwell on the past, let that turbo spool and never turn back
x96nax is offline   Reply With Quote
Old 10-26-2013, 11:17 PM   #7
Figo
Figo's Avatar
Drives: Vortech Supercharged FR-S
I think I got the same problem as u had.
Coilovers, lcas, and toe arms installed.
I'd rather lose by a mile because I built my own car,
than win by an inch because someone else built it for me.
Your car is your story, so don't let someone else write the book.
( White Tiger ) - FiGo's 車誌.
Figo is offline   Reply With Quote
Old 04-25-2014, 09:21 PM   #8
5150unltd
Drives: 2013 Rally Blue Subaru BRZ Limited
So what was causing the noise im havsame issue
5150unltd is offline   Reply With Quote
Old 04-25-2014, 10:00 PM   #9
Figo
Figo's Avatar
The spring on one of the coilover was not at the correct position when the shop was doing alignment. It was a quick fix.
But anyway coilovers will have some noise.
E-Brake issue "clunking noise" when pulling the e-brake while rolling. Kinzo Suspension | Chassis | Brakes -- Sponsored by 949 Racing 55 06-20-2018 10:14 PM
Rattling noise under the hood during engine braking at low RPM Sigh-on-Rice Engine, Exhaust, Transmission 60 07-28-2013 07:48 AM
Rattling Noise on acceleration Naughty AFRICA 2 05-14-2013 11:17 AM
Rattling rear license plate bracket lucius AFRICA 11 12-03-2012 02:28 AM
rattling noise in the trunk ayetothejay Scion FR-S / Toyota 86 GT86 General Forum 2 06-26-2012 11:19 PM
