#43 |
Garden variety obsessive
Drives: 2009 Sti Hatch; 2015 Audi RSQ3
Here you go guys, for B00C and B01C:
Code:
RAM_EngineSpeed FFF893F8 RAM_EngineSpeed_0 FFF8DB98 RaM_LTFT FFF8DB90 Ram_AFR_Sensor_Heating_Limit_Result FFF88478 Ram_AF_Correction_3_32bit_ECU FFF8A900 Ram_AF_Learning3_Percentage FFF8DC10 Ram_AF_Learning_3 FFF81640 Ram_AF_Sensor_1_Current FFF8932C Ram_AF_Sensor_1_Resistance FFF89344 Ram_Accelerator_Pedal_Angle FFF89230 Ram_Alternator_Duty FFF884A4 Ram_Atmospheric_Pressure_1 FFF89B94 Ram_Base_Pulse_Width FFF89744 Ram_Battery_Voltage FFF87C6C Ram_CFP_Delta FFF89048 Ram_CPC_Valve_Duty_Ratio FFF89CD0 Ram_CPC_Valve_Duty_Ratio_1 FFF8DC14 Ram_Calculated_Base_Pulse_Width_ FFF8A058 Ram_CoolantTemperature FFF890A4 Ram_Coolant_Temperature??? FFF87C74 Ram_Defogger_Switch FFF8939F Ram_ECU_volt FFF8DBD8 Ram_Engine_Speed FFF89570 Ram_Exhaust_VVT_Retard_Angle_Left_ FFF8C148 Ram_Exhaust_VVT_Retard_Angle_Right_ FFF8C144 Ram_Fuel_Injector_1_Pulse_Width FFF887D8 Ram_Fuel_Injector_1_Pulse_Width_4byteExt_E60??? FFF887F0 Ram_Fuel_Injector_2_Pulse_Width FFF887DC Ram_Fuel_Pressure_MPa FFF89378 Ram_Fuel_Pump_Duty FFF8B1B4 Ram_Fuel_Pump_Duty_0 FFF8BD38 Ram_Gear? FFF89395 Ram_Idle_Switch FFF8B5C6 Ram_Ignition_Total_Timing FFF8AE0C Ram_Ignition_Total_Timing_0 FFF8DBA0 Ram_Intake_Air_Temperature FFF87C64 Ram_Intake_Air_Temperature_0 FFF8DBA4 Ram_Intake_OCV_Current_Left FFF891B8 Ram_Intake_OCV_Current_Right FFF891AC Ram_Intake_OCV_Duty_Left FFF8C20C Ram_Intake_Temp FFF890B8 Ram_Intake_VVT_Advance_Angle_Left FFF8C100 Ram_Intake_VVT_Advance_Angle_Right_ FFF8C0FC Ram_Load FFF8DB84 Ram_MAF_Voltage FFF87CB4 Ram_Map FFF8DB94 Ram_Map_Delta? FFF8A234 Ram_Mass_Airflow FFF89118 Ram_Mass_Airflow_0 FFF8DBA8 Ram_O2_curr FFF8DBD0 Ram_O2_voltage FFF8DBC0 Ram_Rear_O2_Sensor FFF8DBB0 Ram_Roughness_Monitor_Cylinder_1 FFF8CEDD Ram_Roughness_Monitor_Cylinder_2 FFF8CEDE Ram_Roughness_Monitor_Cylinder_3 FFF8CEDF Ram_Roughness_Monitor_Cylinder_4 FFF8CEE0 Ram_SI_Drive_Mode_I3_S1_SSharp2_ FFF88999 Ram_STFT FFF8DB8C Ram_Throttle_Opening_Angle FFF8DBAC Ram_Vehicle_Speed FFF8DB9C Ram_Vehicle_Speed_0 FFF893D0 Ram_abs_load FFF8DBDC Ram_amb_press FFF8DBCC Ram_cat_temp FFF8DBD4 Ram_coolant_temp FFF8DB88 Ram_fuel_level FFF8DBC8 Ram_fuel_pressure FFF8DBB8 Ram_lambda FFF8DBBC E_AF_Correction_1_4byteExt_E81 FFF8A5EC E_AF_Learning_1_4byteExt_E48 FFF8A774 E_AF_Sensor_1_4byteExt_E91 FFF89330 E_CLOL_FuelingExt_E33 FFF8DC26 E_Closed_Loop_Fueling_Target_4byteExt_E121 FFF8A6D0 E_Engine_Load_4ByteExt_E32 FFF8914C E_Engine_Speed_Delta_E157 FFF89408 E_Feedback_Knock_Correction_4byteExt_E39 FFF8B0C4 E_Final_Fueling_Base_4byteExt_E123 FFF8A01C E_Fine_Learning_Knock_Correction_4byteExt_E41 FFF8B160 E_Fuel_Injector_1_Latency_4byteExt_E50 FFF8A05C E_Fuel_Injector_1_Pulse_Width_4byteExt_E60 FFF887C8 E_IAM_4byteExt_E31 FFF816F0 E_Idle_Speed_Map_SelectionExt_E49 FFF8B748 E_Ignition_Base_TimingExt_E53 FFF8AE88 E_Knock_Correction_Advance_4byteExt_E43 FFF8B0C0 E_Knock_Correction_Advance_IAM_onlyExt_E40 FFF8B134 E_Knock_Correction_Advance_Max_PrimaryExt_E118 FFF8B12C E_Manifold_Relative_Pressure_4byteExt_E113 FFF88F78 E_Manifold_Relative_Sea_Level_Pressure_4byteExt_E52 FFF88F74 E_Primary_Open_Loop_Map_Enrichment_4byteExt_E84 FFF8A988 E_Requested_TorqueExt_E56 FFF8B4A4 E_Target_Throttle_Plate_PositionExt_E57 FFF8B58C E_Throttle_Plate_Opening_Angle_4byteExt_E38 FFF89030 E_Tipin_ThrottleExt_E54 FFF89038 |
#44 | |
Drives: FT86
If you guys on B01C or B00C roms can test them out by substituting in the new ram addresses (scaling is hopefully the same) then post up a B series logcfg.txt I will add that to post as well Thanks |
| The Following User Says Thank You to steve99 For This Useful Post: | ML (04-23-2014) |
#45 | |
Drives: 13 White MT FR-S
| The Following User Says Thank You to ML For This Useful Post: | steve99 (04-23-2014) |
#46 |
Drives: FT86
#47 |
I havn't got to test it yet, but I updated all the hex addresses.
#49 |
Steve, also - people must use this 32bitbase.xml for Ecuflash - the most up to date, if you could edit the OP:
https://raw.githubusercontent.com/TD.../32BITBASE.xml |
#50 |
Drives: 2013 Subaru BRZ
Ok so I had previously flashed my car successfully with the OFT stage 1 ROM. This morning I installed the OFT headers and went to flash their stage 2 ROM, but everytime I try to read or write this happens:
[16:36:31.871] using metadata XML ID read_subarush72531brz from file C:/Program Files (x86)/OpenECU/EcuFlash/rommetadata/read templates/read_subarush72531brz.xml [16:36:31.885] J2534 API Version: 04.04 [16:36:31.885] J2534 DLL Version: 1.01.4035 Dec 16 2013 23:12:40 [16:36:31.885] Device Firmware Version: 1.14.4010 [16:36:31.885] Device Serial Number: TAn8SKIw [16:36:37.608] reading vehicle info... [16:36:37.617] CALID : ZA1JA01C [16:36:37.619] CVN : 8349A8FB [16:36:37.624] VIN : JF1ZCAB17D1611837 [16:36:37.624] starting programming session... [16:36:37.626] turning off DTCs... [16:36:37.964] turning off unnecessary communications... [16:36:38.066] unlocking ECU... [16:36:38.066] Requesting Seed... [16:36:38.069] interface close [16:36:38.081] interface close Anybody have any ideas? |
#51 | |
Drives: FT86
#52 | |
Drives: FT86
Just updated 32bitbase file link in original post see Td-d post above. |
#53 | |
#54 | |
Drives: frs
As tou your problem, I would also suggest rebooting your laptop and/or trying a different usb port. Also make sure you've waited after initial bips at least 5 seconds. |
| The Following User Says Thank You to vgi For This Useful Post: | reardrv (04-25-2014) |
#55 | |
#56 | |
Drives: FT86
I was talking about logging to Tactrix SD card using logcfg.txt files :-) good to hear its all sorted. |
| Tags |
| ecuflash, tactrix, taxtrix, tuning |
| ECUFlash - Getting close! | xjohnx | Software Tuning | 698 | 03-22-2015 12:10 PM |
| EcuTek Flash finished but now it shows only a Partial Flash... | Cross | Software Tuning | 32 | 02-12-2014 10:55 AM |
| Tactrix Openport | jamesm | Engine, Exhaust, Bolt-Ons | 1 | 01-28-2014 08:27 PM |
| Visconti Tuning - Latest BRZ Flash Info | Visconti | Software Tuning | 6530 | 12-24-2013 10:18 PM |
| Overboost Protection With OFT/EcuFlash? | FrX | Software Tuning | 9 | 10-23-2013 07:27 AM |
