Old 09-01-2013, 10:03 AM   #29
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Bumping this up with new Pump Install Video by Tony @FA20Club.com added to OP and here
[ame="http://www.youtube.com/watch?v=GLTP7KxgjPs"]FA20CLUB FR-S BRZ Fuel Pump Install Guide - YouTube[/ame]
Old 09-01-2013, 10:42 AM   #30
chewbacca
Drives: Frs-t
Pump install details
Hello
I have found usefull a heat gun or something warm to loose up the black rubber mounting silicone for the cap. Then use wax paper to wrap the black silicone to prevent skin, tool and seat spread. Also place a 45 gallon bag on floor too.
The second item is using a big oil filter wrenchfor the outer ring.
The third one, if is not being said before, the fuse in the engine fuse box and disconnect the pump fuse before uninstall.
Also the fuel sock...
This one is a doble edge knife.
In my FI set up i had to remove the fuel sock from its attachment place. The fuel was cloggin the fuel flow and starved the fuel feed.
The plastic elbow was kept and was drilled to port and aid the flow into the pump inlet and to keep it from falling off the outlet port.
I have nothing else to say about the pump. Although i have a bunch to say about the AT transmission and the forging of it by SSP. Later to this.
Lastly hope to report on my forged motor by Dan Benson, Crawford, Ferrea, and other parts from Fullblown and Dynosty.
Talk later
chewbacca is offline   Reply With Quote
Old 04-16-2014, 09:17 PM   #31
Sportsguy83
Drives: Limited BRZ
@mkivsoopra
Old 04-25-2014, 10:54 AM   #32
SmsAlSuwaidi
Boosted
SmsAlSuwaidi's Avatar
Drives: Not a supra....yet
Well my car is currently leaking fuel like crazy
Old 04-25-2014, 12:09 PM   #33
Sportsguy83
Drives: Limited BRZ
I already gave you the solution... "There's no crying in baseball"
Old 04-25-2014, 02:24 PM   #34
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
Did you let @Visconti drive it?
Old 04-25-2014, 11:24 PM   #35
Element Tuning
Drives: Hydra EMS Powered FRS Raven Black
Originally Posted by cf6mech View Post
I'm assuming the sending unit is in the canister,..if so the orientation of the arrow and dots makes sure your quantity reads correctly right?,...I have an issue with that.
Just noticed your question...many months later Yes but also lets you know the lid is sealed correctly. It can be tight an leak like crazy so you have to have all marks like up.
Ok on the level, even if you get it all right I think the transfer hose can get caught on the level sensor. This hahappened to me but there is no way I'm cracking that lid seal again. LOL!
Element Tuning is offline   Reply With Quote
Fuel pump upgrade install (Visconti 290lph) jet86 DIY (Do-It-Yourself) Guides 44 01-04-2018 07:56 PM
FS: Visconti Fuel Pump Sportsguy83 Engine, Exhaust, Bolt-Ons 0 03-31-2013 04:45 PM
Fuel pump issue. sevi21 Issues | Warranty | Recalls / TSB 13 02-01-2013 09:57 AM
Car fuel pump on... Genomaxter Engine, Exhaust, Transmission 5 11-29-2012 10:06 AM
Dynosty FR-S/BRZ Fuel System Upgrades! Deatschwerks DW65C Fuel Pump Dustin@Dynosty Engine, Exhaust, Bolt-Ons 3 08-21-2012 04:53 PM
