Old 04-24-2014, 11:17 PM   #15
Chaetagnath
Drives: Whiteout FRS
Actually I just saw in another thread (http://www.ft86club.com/forums/showthread.php?t=31690) that there is an ECU setting which will keep the DRLs on with headlights. If that is the case, you can just wire the DRL to the LED, and they would stay on. Dealership should be able to change the setting for you, or you can do it yourself with a techstream.
Chaetagnath is offline   Reply With Quote
Old 04-25-2014, 03:21 AM   #16
kincito
Drives: Raven FRS
Just ordered techstream. Doesn't the frs come with the drl setting ion from factory?
kincito is offline   Reply With Quote
Old 04-26-2014, 04:54 PM   #17
Chaetagnath
It does come from the factory with it on. However, I plugged my tech stream in yesterday to look and see if there was an option to keep it on with headlights. There is a straight up on/off setting, and thereI were illumination settings that said normal, dark 1, dark2, light 1 or light2. I'm not sure what those do, so I cannot confirm if that will work or not (it's always useful to have a tech stream anyway though). However, I have read elsewhere that he LED is too bright at night and should be dimmed anyway if used with headlights. So, I think your best option is to wire with the DRL power as previously described (you don't use the parking voltage wire). Then use a resistor connected from the low beam power to the LED to light it up at a reduced power when the headlights are on. See this thread http://www.ft86club.com/forums/showthread.php?t=44066, there is someone who makes and sells a resistor just for this purpose. This is for people who have 10series/monograms already, but it should work just the same with a regular FRS with 10 series lights installed, if you are using the DRL power source.
Old 05-03-2014, 10:56 AM   #18
FRSHunter
Drives: Asphalt FRS
Any updates?
FRSHunter is offline   Reply With Quote
Installed 10 Series Headlights Today Calavera Cosmetic Modification (Interior/Exterior/Lighting) 58 02-15-2024 03:18 PM
Monogram/ Series 10 Headlights fitcious Cosmetic Modification (Interior/Exterior/Lighting) 130 06-10-2016 10:07 AM
Scion 10 series headlights gusbarragan Cosmetic Modification (Interior/Exterior/Lighting) 19 04-20-2014 11:26 PM
10 series headlights retrofit with regular frs need help! bdanisi Cosmetic Modification (Interior/Exterior/Lighting) 5 11-21-2013 05:37 PM
86 Headlights (10 Series) $656 Each at www.onlinetoyotaparts.com YMMV Calavera Cosmetic Modification (Interior/Exterior/Lighting) 42 08-21-2013 06:54 AM
