Old 03-10-2014, 09:31 AM   #617
tennisfreak
Drives: 2018 BMW M240i
@subiestyle
It is a rebranded K&N filter so if you buy their cleaning kit it should have the cleaner and oil you need to maintain it.
If I recall correctly it needs to be cleaned around 50k miles
Old 03-12-2014, 02:42 PM   #618
vtmike
vtmike's Avatar
Drives: Scion FR-S
Originally Posted by vtmike View Post
Attachment 69682
To give a little context. I removed the main resonator attached to the air box on the initial dyno that seemed to have an effect on the a/f ratio. Other 86's were run with that first dyno and a car on e85 tune with nameless exhaust (same as my set up) hit 180whp, and another with fa20club el header plus intake and tune hit 180whp. My car has nameless downpipe w/ high flow cat, and Axel back on both runs. What differs is Perrin inlet hose and drop in filter on one and TRD intake on the other.
The outlier is an auto FRS with only nameless axleback and drop in hit 167 whp. Search Richmond dyno day results for other dynos.
Sent from my XT1060 using Tapatalk
A couple things I forgot to mention, the dyno is a dynojet that's sae corrected and 4th gear pull.
Most likely, if it were std correction, like most other dynos here, and a 5th gear pull (4th gear dynos less and 5th is 1:1) it would have been well into the 180's whp.
Not too bad for a car with no header or tune.
vtmike is offline   Reply With Quote
Old 03-31-2014, 11:59 PM   #619
RacerX
Drives: Subaru BRZ
Question:
How long does it take the ECU to "relearn" the intake?
I installed mine today. I guess I didn't know what to expect, or maybe my expectations were misguided, but I really didn't notice any difference at all. The throttle response seems about the same. I only drove it about 5 miles or so around town so I can't speak for top end power gains. Low end gains may have been slight but I'm not sure if thats just the placebo effect. The cabin is a bit quieter with the resonator delete.
RacerX is offline   Reply With Quote
Old 04-01-2014, 12:05 AM   #620
torqdork
torqdork's Avatar
Drives: RV-7
1-2 full tanks. Give it WOT during the learning period and you'll notice the difference in improved throttle response and smoothed midrange torque curve at the (worthwhile) expense of fuel economy.
torqdork is offline   Reply With Quote
Old 04-01-2014, 01:06 AM   #621
RacerX
Drives: Subaru BRZ
^^^Good to know! Thank you.
I had no idea it took that much driving. I'll report back in couple weeks. I go through about a tank per week commuting back and forth to school.
Old 04-01-2014, 11:17 AM   #622
torqdork
torqdork's Avatar
Drives: RV-7
Glad to help. I'd add that if your engine is fully broken in, then make those WOT sprints to redline in lower gears and shift more often than usual.
It's been my experience that this method works well at track days when the day before the event I swap out batteries to a lightweight racing battery that resets the ECU. By the end of the track day the car is running much stronger than the beginning and not just from the fuel weight loss.
Also, a couple of weeks ago I replaced the stock intake before returning to the dealership for the crickets TSB. The reduced driveability and throttle response was very noticeable.
The TRD CAI might not produce much more power, but the other benefits including a quieter cabin are worth it.
Old 04-22-2014, 06:10 PM   #623
Near
Near's Avatar
Drives: Raven Black FR-S
Originally Posted by Thorpedo View Post
So I finally got the FR-S on the Dyno.
This was my procedure.
-Unhook neg terminal
-Wait 5 minutes or so
-Hook neg cable back up, run car for 5-10 minutes.
-Do 3 dyno runs.
-Install TRD intake
-Hook neg cable back up, run for 5-10 minutes
-Do 3 more runs
This way I believe to be the best, as it makes it so I am comparing apples to apples. My car has around 3500km on it, and it has the TRD exhaust as well.
First 3 runs are as follows:
1. 162.9hp - 133.52tq
2. 166.05hp - 136.51tq
3. 167.95hp - 136.73tq
After the TRD intake was installed (within an hour, so similar temp etc)
1. 174.39hp - 143.59tq
2. 175.6hp - 144.2tq
3. 170.02hp - 141.16tq - Something was up on this last run as I felt the car shift a bit on the dyno. I was satisfied with the figures so we just took it off.
Shitty pic of the graph, but as you can (kind of) see, it was a pretty even increase throughout the rev range with a decent peak at 4500.
(Will be posting pic, vid of gauges shortly)
The Red box is around the runs done with the TRD intake.
I see he his banned, but in closing I'd like to send out a big GFY to FR-S Matt!
Out of curiosity did you have any type of aftermarket exhaust on when you did the dyno?
(Sorry I read through the whole thread and couldn't find anything maybe i missed it IDK I rarely ever get on here
so im not too familiar with forums. I think the intake would make a great pair with the TRD Exhaust but that's just me.)
Near is offline   Reply With Quote
Old 04-22-2014, 09:26 PM   #624
Thorpedo
The SquadWhisperer
@Near that is with the TRD exhaust in both the before and after dynos
2013+14+15 Atlantic Region Motor Sports Autocross STX Champion
2013+14+15 Atlantic Region Motor Sports Overall Autocross Champion
2017 Bluenose Autosport Club Overall Rallycross Champion
Powered by Great North Performance, Jani-King Canada, and OK Tire.
Thorpedo is offline   Reply With Quote
Old 04-23-2014, 06:42 AM   #625
Near
Near's Avatar
Thanks for the speedy reply man, and I know the thread is a bit old but also thanks for the effort of getting a dyno man I appreciate it! :-)
Old 04-23-2014, 01:35 PM   #626
Thorpedo
The SquadWhisperer
No problem! I will be getting more graphs with other mods that I do as they arrive (and I have time)... I'll update this thread with them if I think of it.
Old 04-23-2014, 09:29 PM   #627
Near
Near's Avatar
Cool, I'll be looking forward to it if you do decide to! (Damn I just noticed that it does say you had the TRD Exhaust in your dyno post. I must've skim and scanned too quick and missed it.)
Old 04-24-2014, 07:57 PM   #628
Gundark
Drives: Scion FR-S
Just swapped out my aem cai for the trd and I'm completely happy. Butt dyno feels the same, and no more annoying trips to the dealership for them to lecture me about how my after market exhaust is causing CEL
Gundark is offline   Reply With Quote
Old 04-26-2014, 05:56 PM   #629
kosoku
Drives: 2013 fr-s
my boy helped me with his first install, TRD intake
first install by sektor 11
kosoku is offline   Reply With Quote
The Following 2 Users Say Thank You to kosoku For This Useful Post:
hur1ey02 (04-28-2014), Pseud0logik (05-03-2014)
Old 04-26-2014, 09:21 PM   #630
wootwoot
Drives: FRS
Awesome...
cold air intake vs short ram intake ? tnt Engine, Exhaust, Transmission 5 02-02-2014 01:43 AM
So cold air intake or air intake? bcmakesiteasy Engine, Exhaust, Transmission 12 02-01-2014 09:06 PM
HKS intake setup VS Injen intake,,,what are your thoughts? JDMrolla Engine, Exhaust, Transmission 4 10-11-2012 02:31 PM
