Drives: S15 Silvia
LED DRL strip - DRLS stay on with headlights (but not using ACC/IGN wire?)
Hi All
Ive purchased and installed the DRL LED strips that replace the GT spec foglights, and as a result, my DRLs stay on as long as my headlights are off. When my headlights come on, my DRLS turn off (as per the expected behaviour of the old Foglights / DRLs) Id like to wire up the LED DRLs to stay on when headlights are on, but I dont really want to put a wire thru the firewall to access the acc/ign line of the car. I'm thinking I could connect an additional wire between the headlights and the foglight wire thats currently running my LED DRLs, so that when my foglights are off and no longer powering the DRLS, my headlights will power them instead. Altho this causes the complication that when my foglights are powered on, my headlights will try to power on (not good), so I'll need a diode on that connecting line between the headlights and the foglights, so power can only flow one way, i.e. from the headlight to the foglights.. Could anyone advise what kind of diode(s) I would need, or is there an alternate way to wire up the LEDs without going into the cabin (e.g. wiring into the fuse box etc?)? Thanks heaps in advance, Rob |
#2 |
Drives: 13 Asphalt FRS AT
Wasn't there an ECU update that includes the ability to adjust drl behavior?
Sent from my SPH-L710 using Tapatalk 2
| The Following User Says Thank You to pixel67 For This Useful Post: | kharn83 (03-23-2013) |
#3 |
Drives: S15 Silvia
yup thanks pixel for this info
i checked with my dealer and ur correct, then can set it so it stays on with my headlights thanks! no need for me to wire up more wires now, yay
#4 | |
Drives: Scion FRS 10 Series
I have a Series 10 FRS and I have been wondering about whether that was an option that could be programmed at the dealership. Do you have a confirmation about this, can you post a link? Thanks Pat |
#5 | |
Drives: 2013 BRZ Limited WRB
so dealer will charge a fee for it, some won't. They simply need to plug in the OBD2 using Techstream (if I'm not mistaken) but you could also do it yourself and any future personalization using a cable from Ebay and this software. |
| BRZ LED Strip in Headlights (bulb) | R0ME0 | Cosmetic Modification (Interior/Exterior/Lighting) | 15 | 05-26-2014 11:57 PM |
| OEM Europe headlights with LED DRLs? | FastLap | Cosmetic Modification (Interior/Exterior/Lighting) | 4 | 02-14-2013 02:49 PM |
| Difference Between $3 DRLS and $40 DRLS? | FR-S Matt | Cosmetic Modification (Interior/Exterior/Lighting) | 14 | 12-31-2012 05:05 AM |
| Wire LED DRLs to fog lights or headlights | Cameronghanson | DIY (Do-It-Yourself) Guides | 0 | 10-29-2012 07:52 PM |
| Reverse Wire Tap wire Location? | Norkoastal | Electronics | Audio | NAV | Infotainment | 2 | 10-19-2012 10:22 AM |
