Old 04-23-2014, 10:50 PM   #771
mit_peid
Boosted Noob
mit_peid's Avatar
Drives: '13 FRS MT KW SC, '05 4Runner 4WD
Where did you get that bolt? Can't be the one that came with the kit, right? I definitely would not run on that. If anything, i'd drop the washer to get a couple additional turns on that nut.
mit_peid is offline   Reply With Quote
Old 04-24-2014, 12:00 PM   #772
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
Originally Posted by post_break View Post
Looking at this bolt I shouldn't have an issue with the oil cooler. Then again I hope it doesn't fall off heh. Getting really excited to install this.
I think you will be fine with that bolt as long as you torqued it to spec. Perhaps some thread locker just to make sure. That apparantly is a factory KW bolt.
Old 04-24-2014, 12:01 PM   #773
King Tut
NASA SpecE30 Racer
King Tut's Avatar
I guess I'm trying to understand what's the difference between going with one vs two of the cans being offered here: http://www.radiumauto.com/Catch-Can-...Z-86-P374.aspx
I haven't seen anyone confirm that there is any significant oil that comes out of the front driver side breather. If you want to save some money, then just throw a standard small breather filter on the end of the hose and call it a day.
Old 04-24-2014, 12:28 PM   #774
KraftWerks
KraftWerks's Avatar
Drives: Kraftwerks BRZ
@KraftWerks can you comment on that bolt?
We're looking into this now, give me a couple minutes.
-B
KraftWerks is offline   Reply With Quote
Old 04-24-2014, 12:37 PM   #775
post_break
Professional Smartass
post_break's Avatar
Drives: White Out FRS
-B
If that washer is removed the thread goes the entire length of the nut. With thread lock I would assume that would be just fine.
post_break is offline   Reply With Quote
Old 04-24-2014, 12:38 PM   #776
post_break
post_break's Avatar
I think you will be fine with that bolt as long as you torqued it to spec. Perhaps some thread locker just to make sure. That isn't a factory KW bolt. He bought a shorter one to help with oil cooler clearance.
This is how the kit came. Didn't buy that bolt.
Old 04-24-2014, 12:44 PM   #777
captain_jack
captain_jack's Avatar
@KraftWerks Hey I've tried calling the last few days and gotten nothing but person not available message and I have questions concerning the grease residue pictures I posted here a few days ago. Can I get a heads up when a someone is available to chat.
may the schwartz be with you....
Old 04-24-2014, 01:14 PM   #778
KraftWerks
KraftWerks's Avatar
Did you leave a voicemail with your contact information?
We're pm'ing you now @captain_jack
Old 04-24-2014, 01:21 PM   #779
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Damn. I will edit my post.
Old 04-24-2014, 01:31 PM   #780
post_break
post_break's Avatar
No worries, I'll be switching to cogged pulleys hopefully.
Old 04-26-2014, 03:38 AM   #781
mit_peid
Boosted Noob
mit_peid's Avatar
Cogged pulleys are a lot quieter at idle. I thought I had grown to liking the louder whine of the smooth idlers, but now that I have the cogged idlers on I'm enjoying the other engine/SC/exhaust sounds a lot more. You can definitely still hear the whine at higher RPMs, but it is relatively tame (almost sleeper quieter) near idle.
Old 04-26-2014, 08:07 AM   #782
Model Citizen
Lacking brains
Drives: frz
so, are the cogged pulleys available for everyone now, or is it still in the tester phase?
Model Citizen is offline   Reply With Quote
Old 04-26-2014, 11:35 AM   #783
Zach3794
Drives: 2013 Scion FR-S, Raven, Manual
I was able to get mine set out yesterday when I called, KW should be more than willing to help out if you call them up during normal business hours
Tuned by Delicious Tuning
http://www.delicioustuning.com/node/209
Kraftwerks Supercharged
Zach3794 is offline   Reply With Quote
Old 04-26-2014, 05:00 PM   #784
captain_jack
Well after talking with Joe at kraftwerks, I will be pulling my blower off tomorrow as he said there isn't enough grease in the idle pulleys to cause what I have on mine.so I'm going to pull it to take pictures and see if I can trace it down. More then likely it will be going back to them. Sad Panda over here.
Kraftwerks Rotrex Supercharger Discussion nelsmar Forced Induction 697 01-18-2022 12:06 PM
All SUPERCHARGER kits compilation thread subatoy Forced Induction 76 03-10-2016 12:38 PM
Kraftwerks Supercharger?? umpadupa Forced Induction 1 08-05-2013 05:27 PM
