CANADA Canada
Old 04-24-2014, 09:33 AM   #3543
jvincent
jvincent's Avatar
Originally Posted by PNA View Post
If anyone's interested in a fumuto valve let me know. I will place an order for myself and wouldn't mind splitting shipping costs.
I'm interested in the no-nipple version.
That said, in my searching I found what looks like a Canadian source at http://www.ezoildrain.ca/
They ship for free, and the valve looks the same.
Old 04-24-2014, 10:06 AM   #3544
PNA
Drives: 2013 BRZ Sport-tech
That have two different sizes advertised for scion vs subaru. Do you know which is the correct size?
PNA is offline   Reply With Quote
Old 04-24-2014, 10:07 AM   #3545
Simon99
Simon99's Avatar
Drives: 2013 BRZ Limited WRB
F108 is the correct size
Sent from my SGH-I337M using Tapatalk
Originally Posted by VesperLynn
This car has allowed car enthusiasts to come from all different walks of life, car cultures, and brands. Just as a panda is black, white, and Asian; the 86 is Toyota, Subaru, and downright fucking sexy.
Simon99 is offline   Reply With Quote
Old 04-24-2014, 11:02 AM   #3546
jvincent
jvincent's Avatar
Yup, I can't see the whole forum, but if you quote one of my posts or use @ to mention me, I'l get a notification, and I make it a point to at least read every notification I get.
Thanks for chiming in Mike. I've gone through most of your technical/track threads and they are a great help.
On the topic of oil, you guys have said that you use Motul 300V exclusively and made the comment, paraphrasing, that any good 0W20 synthetic should be OK but that you haven't tested it.
I was looking for something that was a little more readily available and ideally less expensive than the Motul since my track time is going to be a lot less than what you guys see.
I was specifically looking at the Quaker State Ultimate Durability. The specs look to be pretty close to the Motul from what I can see.
Old 04-24-2014, 11:08 AM   #3547
Slick
Slick's Avatar
Drives: FR-S Firestorm 6MT
Originally Posted by Pbrown View Post
When are you expecting your OFT to come in Andre? Probably ordering mine early next week. Buddy club tails are currently sitting in Los Angeles. Hope to have them by the weekend.
My OFT is in Canada! Woot! Maybe will get it tomorrow.
Slick is offline   Reply With Quote
Old 04-24-2014, 11:09 AM   #3548
jvincent
jvincent's Avatar
Yep, looking at the specs the EZ-108 and the F108 have the same thread pitch.
Old 04-24-2014, 11:18 AM   #3549
Pbrown
Drives: 2013 Scion FRS Raven
Oh Yeah well.....
My tails are ??????? Last update was April 22 in Los Angeles. Clearly I won't be seeing mine until next week. Very curious to see how your OFT writes as I believe you and I probably have the same ECU. Very exciting indeed.
Pbrown is offline   Reply With Quote
Old 04-24-2014, 02:51 PM   #3550
CSG Mike
CSG Mike's Avatar
What is the base type of the oil? The Motul is a Group V.
My S2000 actually sees virtually zero track time now, but I still use 300V. Between the long oil change intervals and improved mpg, it's totally worth it for me. My oil change interval (10k+) is determined by used oil analysis.
Old 04-24-2014, 03:14 PM   #3551
Slick
Slick's Avatar
10,000 miles @CSG Mike?
So that's 16,000kms, I'm still doing changes at 5000 kms here regardless, using Toyota 0W20 synthetic. I'll have to look into it based on your comment of the oil analysis.
In my day job, I manage a fleet of work vehicles and have found that the extended intervals are a bit too extended and leading to issues so we have reduced it to fixed 8000 km intervals on conventional oil, instead of going by duty cycle indicator (mostly Honda cars and Ford trucks).
So I guess I'm also a bit old school, which is why I do my own car every 5K.
Old 04-24-2014, 03:33 PM   #3552
jvincent
jvincent's Avatar
Hard to google on the phone, but I think the QS is Group V.
I looked at the spec sheets and the Mogul and QS numbers that they published were virtually identical, which is why I am interested in it.
Old 04-24-2014, 03:58 PM   #3553
Trac Toy
Trac Toy's Avatar
Personally I use the redline gl4 in the trans and the gl5 in the diff. We run the GL4 in the trans in the chumpcar and have had very good results with it.
.o0+Eric+0o.
2016 Chrysler 200S 3.6
2013 FRS 6MT
Trac Toy is offline   Reply With Quote
Old 04-24-2014, 04:00 PM   #3554
Trac Toy
Trac Toy's Avatar
.o0+Eric+0o.
2013 FRS 6MT
Old 04-24-2014, 04:05 PM   #3555
Simon99
Simon99's Avatar
Talking 'bout oil, I'm about to order that ! Amsoil is pricy for student me Too bad mississauga is 5 hours away, I could have saved on shipping by picking up ! Any recommendations before I pull the trigger ?
Old 04-24-2014, 04:07 PM   #3556
Slick
Slick's Avatar
Attachment 76077
I can get you some Amsoil from my contact in Toronto. Will be down there next week and back on the weekend.
Sorry, got confused with Motul. I can get you Motul if you need it (or pick up your Amsoil for you). Good thing is you can save as the same Motul lube is used in the Trans and the diff. And you need just over 2 litres for each. So with same type, you get 5 litres instead of 3 of each.
