Old 04-23-2014, 10:12 PM   #1
bvelna
Drives: frs
unichip p0172 engine code
I have unichip, and cai and getting check engine light for code p0172 too rich bank one code. Anybody else having issue with this
bvelna is offline   Reply With Quote
Old 04-23-2014, 10:41 PM   #2
6speed_Sam
Thumper
6speed_Sam's Avatar
Drives: 2013 FRS
I did once, but now I keep getting p219a
Car is gone - parts for sale
6speed_Sam is offline   Reply With Quote
Old 04-25-2014, 12:27 AM   #3
davidchoi
davidchoi's Avatar
Drives: BRZ - White Satin
I got that everyday for the lifetime of my Unichip. I found out the issue was my Injen cold air intake. After switching back to stock, I haven't had any issues.
p0172 has been etched into my mind
davidchoi is offline   Reply With Quote
Old 04-25-2014, 04:10 PM   #4
bvelna
Drives: frs
Yea I think it's the intake too.I talked to unichip and they said to call injen, injen said they had a defective tube called the "gen 1 " so I'm going back to stock temporarily to see if it goes away. Any good cai that won't give the same problems.. it's been driving me crazy I would have never thought a bad intake tube... p0172 will probably never get out of my head lol
Old 04-27-2014, 05:41 AM   #5
davidchoi
davidchoi's Avatar
No joke haha. P0172 has turned me off from ever trying cold air intakes again.
Old 04-27-2014, 02:26 PM   #6
jeffchap
jeffchap's Avatar
Drives: 2013 Scion FR-S Raven 6MT
Yes, see here: http://www.ft86club.com/forums/showthread.php?t=64286
Clean your MAF sensor, then reset the code. That fixes it for a few weeks. I'm still experimenting to determine the exact cause, but I don't see where the Unichip is at fault. I had it for 9 or 10 months, running the same map continuously, before this problem started. Failed MAF sensor, perhaps due to K&N and perhaps not, is my best guess at this time.
Stay squatchy, my friends
jeffchap is offline   Reply With Quote
Old 04-29-2014, 02:46 PM   #7
Opsfrs
Opsfrs's Avatar
Drives: 2013 Fire Red frs 6spd/ Honda S2k
Totally off topic but is the unichip worth it? Did yall see a difference in power, how it felt or sounded? I have a Injen intake cusco throttle body borla uel header perrin over perrin midpipe with high flow cat borla cat back.
Opsfrs is offline   Reply With Quote
Old 04-29-2014, 08:54 PM   #8
jeffchap
jeffchap's Avatar
Yes, in my opinion it is. The car has noticeably more pick up, and the torque dip is much less pronounced. I'm sure a full tune would be even better, but with a totally new motor, I was unwilling to jeopardize my warranty. Unichip was the best compromise, and I'd certainly do it again.
The Following User Says Thank You to jeffchap For This Useful Post:
Opsfrs (04-30-2014)
Old 04-30-2014, 02:29 AM   #9
l0aded
Addicted
l0aded's Avatar
Drives: 2013 Asphalt FR-S 6MT
Weird I had unichip with injen with no such problems. random.
Phantom Supercharger | Tsudo Cat-Back Exhaust | K&N Drop-in Filter | Winjet Headlights | Opti-coated | 35/20 Tint | Radar/Dashcam Hardwired | OFT tuned | OEM Audio+ Reference 400CF | Uber Sound Deadened | LED DRL strips | JPM Coachworks Kneepads
l0aded is offline   Reply With Quote
Old 04-30-2014, 09:38 AM   #10
phrosty
Sounds like a problem with intake oil, not unichip. I ran unichip for 1 year without any issues.
phrosty is offline   Reply With Quote
Old 04-30-2014, 09:44 AM   #11
neutron256
neutron256's Avatar
Drives: '13 GBS Subaru BRZ
I was having an assortment of CELs with my Unichip and rough idle/running and sometimes it would even stall. I have a unichip tuning license because I'm using it as part of my electric supercharger design. Reading through some of the tuning documentation It suggested if your having random CELs and other issues the first thing to do its try running a dedicated ground/12V to power the unichip. I reengineered the harness to do this, and since then it's running perfectly.
The Following User Says Thank You to neutron256 For This Useful Post:
bignrichlll (05-23-2014)
Old 06-25-2014, 02:41 PM   #12
davidchoi
davidchoi's Avatar
Can you elaborate on this? Maybe even a quick little DIY for a noob like me.
Old 06-27-2014, 06:30 PM   #13
Vole
Vole's Avatar
Drives: FR-S | Raven
I have 0 mods. I have the Unichip on the FR-S and the check engine light, traction control light & VSC mode light will turn on at some point. Also my cruise control will not work when the check engine light is on as well. If I do not disconnect the battery and reconnect it eventually there will be an idle issue that cause the FR-S to stall when at a red light and an impact to accelerating while driving or trying to go from a dead stop.
When I remove the Unichip the FR-S runs fine w/ no issues. I put the Unichip back on the FR-S and the problem returns.
I have tried to update the Unichip per the file online and also tried the following Maps but the problem returns when the Unichip is on the FR-S:
All Drop-in Filters +((Fuel ~, Timing ~))
Stock +((Fuel ~, Timing ~))
All Drop In Filters + ((Fuel +, Timing +))
Stock + ((Fuel +, Timing +))
All Drop In Filters + ((Fuel -, TIming-))
Stock + ((Fuel -, TIming-))
Valet 3500
I have reached out to Unichip for help, but if someone has any suggestions please let me know as I notice a difference in performance and would like the Unichip back on the FR-S ASAP.
Vole is offline   Reply With Quote
Old 07-01-2014, 11:48 AM   #14
SCharged
Drives: asphalt fr-s
Valet 3500
I have been having the same issue every once ina while when it is very hot and very humid outside.. My car has the latest oem flash, which was supposed to fix the idle dip issue.
Got a p0172 and p1170 yesterday.
SCharged is offline   Reply With Quote
Check engine light came on (p0172) milkesfrs Issues | Warranty | Recalls / TSB 5 08-17-2019 03:33 AM
Unichip Error Code Ingeberger Engine, Exhaust, Transmission 5 12-29-2013 01:09 PM
CEL code P0172 jonbonazza Issues | Warranty | Recalls / TSB 18 11-25-2013 08:35 PM
Engine Code: P0172 P117B *KID* Engine, Exhaust, Transmission 2 01-25-2013 04:23 PM
P0172 Code with Injen Intake, will EcuTek tune help? ron_jeremy Engine, Exhaust, Transmission 0 11-27-2012 11:22 AM
