#4300 |
Lap time enthusiast
Drives: Asphalt '13 FR-S 6MT
| The Following User Says Thank You to raul For This Useful Post: | Ryan@Nameless (04-23-2014) |
#4301 |
Drives: Scion FR-S/Toyota Yaris
As far as supercharger vs nameless header, I honestly plead to supercharger owner to install a catless header. It is just asking for trouble running a supercharger without a free-flowing header, just think about it.
2013 FRS Argento Silver 6MT
Mods: Clear fender side lights Tactrix ZA1JB01C 2014 Calib |
#4302 |
Drives: toyota mr2/ Toyota GT86
are we all done talking about this header now its here then?
#4303 |
Drives: 2013 BRZ Sport Tech White Pearl
#4304 |
Fanboy
Drives: 2013 ultramarine frs
I'm still happy with mine and have no leaks since doubling my overpipe gasket. I just think the gasket I got with the header was too soft for the task, (stock op is tiny) but adding a grimmspeed gasket on the op side resolved it.
Sadly I never baselined my car and don't plan to dyno until I get a few more goodies and have the money for custom tuning, so I can't say more than I'm very satisfied.
I'm done helping those who won't help themselves.
TL;DR: ![]() -Duke |
#4305 |
Twin Screw You
Drives: 2013 Supercharged Whiteout FR-S
Anyone else who is untuned having issues with the CEL even with the O2 sensor spacer? I guess it won't matter for me because I'm gonna reflash my car tomorrow but my car always had the CEL even with the spacer.
#4306 |
Fanboy
Mine threw p2096 with or without the spacer so I turned it off in my tune. It threw the code on stock tune and my stage2 oft tune. Kinda blows, but life goes on.
#4307 |
Drives: Pavement MT GR86
Hhhhmmm I've put a couple thousand miles on mine with the OFT EL stg2 map and no codes or issues... Just the dumb civic noise.
GR86 MT premium
| The Following User Says Thank You to StormTrooper For This Useful Post: | raven1231 (05-03-2014) |
#4308 |
Fanboy
It's the reason I found my initial exhaust leak, but even after fixing it (and checking it to verify it was fixed on several consecutive weekends) the code continued to crop up every few drive cycles.
#4309 |
Drives: '13 6MT Raven FRS
Done about 2000km and no CEL here. OFT should be here next week anyways if it does pop up.
| The Following User Says Thank You to verts For This Useful Post: | Lawnik (05-03-2014) |
#4310 |
This is why a tune should be a requirement with any header. Spacers don't always work and everyone's ECU isn't the same.
I had P0420 disabled on mine which is the rear O2 sensor fault when it reads the same as the front during closed loop mode. You'll normally see it when cruising down the highway with cruise control on. Sometimes I could go 40 miles, other times 200 miles before seeing it and clearing it till I finally just said, time to disable this. |
#4311 |
Drives: BRZ m/t
I used the my OEM Axleback Gasket to seal this header to my OEM overpipe and leaks went away completely
#4312 | |
Drives: GT86, AUDI RS2, VW T5 R32 Vortech
Look to me that their is only in the range of 4200rpm to 6200 rpm where the nameless make a couple more whp. In the deep the Nameless just get killed by the other uel one at top end also. http://www.ft86club.com/forums/showp...postcount=1644 |
| Tags |
| 21 months no dyno, 22 months no vendor dyno, 22months4rattles&leakssmh, amazing warped qualiy, y u no tag |
| Nameless Performance BRZ Axleback Exhaust | ESBjiujitsu | Engine, Exhaust, Transmission | 1377 | 04-21-2020 02:23 AM |
| Nameless Performance Axleback is available for pre-order. | Nameless Performance Inc. | Engine, Exhaust, Bolt-Ons | 114 | 07-23-2012 10:38 PM |
| Nameless Performance Downpipe is available for pre-order. | Nameless Performance Inc. | Engine, Exhaust, Bolt-Ons | 4 | 07-12-2012 04:57 PM |
| We are Nameless Performance. | John@Nameless | Announcements, Contests, Giveaways | 22 | 06-18-2012 11:32 PM |
| Nameless Performance is here. | Nameless Performance Inc. | Engine, Exhaust, Bolt-Ons | 16 | 06-06-2012 04:32 AM |
